Old 09-08-2009, 11:24 AM   #51
superflysteiny
superflysteiny's Avatar
Re: My 69 lonbed
I love the project, I don't know if this helps but the firewall on my 67 is smooth and I relocated the master under the dash, wilwood makes a side mount for under the dash really keeps the frame and fire wall clean. You most likly already know this but hope it helps. Keep up the great work
superflysteiny is offline   Reply With Quote
Old 09-11-2009, 01:29 AM   #52
brian69longbed
brian69longbed's Avatar
Re: My 69 lonbed
yeah i'll probably keep the master on the firewall just to ease the headache, im planning on using a hydroboost set up. there's very little modification on the mounting plate and the plunger only needs to be stretched 1". at least thats the plan for now. no work this weekend though... need to change rear main on my s10. its close to a c10 only in the title ha ha
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=354115
brian69longbed is offline   Reply With Quote
Old 09-13-2009, 11:13 PM   #53
brian69longbed
Re: My 69 lonbed
so i worked on my 2002 s10 4x4 zr2 this weekend. this just reminded me why i like old trucks. i needed to change my front seal. come to find out the front seal is part of the front cover. had to replace whole cover. cover has lip on bottom. need to remove oil pan. to remove oil pan you need to pull of front wheels, axles, entire front differential and remove bolts front steering box. plus remove battery, battery tray and vaccuum actuator. what a pain. also changed timing chain, water pump, belt, coolant and oil.
sorry for the long post but be happy for all your old truck builds... new crap sucks
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 09-13-2009, 11:41 PM   #54
VA72C10
VA72C10
VA72C10's Avatar
Re: My 69 lonbed
Well then stop working on the new junk and get us some more pictures of the 69....
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-13-2009, 11:55 PM   #55
brian69longbed
Re: My 69 lonbed
gotta show some love to the daily driver! plus i need money and parts! wanna sponsor me? ha ha
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 09-17-2009, 07:31 PM   #56
brian69longbed
Re: My 69 lonbed
i could really use some ambition.. can anybody spare any?
i'll start work again next check. tight month.. not happy about that. truck looks sad all dusty and neglected like.
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 09-18-2009, 01:34 PM   #57
superflysteiny
Re: My 69 lonbed
Some of the most unreal cars and trucks take years to build. Take your time the end result will be worth it.
Old 09-18-2009, 02:56 PM   #58
VA72C10
VA72C10
VA72C10's Avatar
Re: My 69 lonbed
GET TO WORK!
Old 09-18-2009, 02:57 PM   #59
VA72C10
VA72C10
VA72C10's Avatar
Re: My 69 lonbed
Did that work for you? I'm sure there are a ton of things you can be doing like cleaning parts, sourcing cheap deals on parts, and finalizing plans while you have down time. Is everything prepped for paint? Got any patch panels to make or weld on? Do the cheap/free/manual labor things while you wait for more money to shake out of the money tree...
Old 09-18-2009, 03:22 PM   #60
brian69longbed
Re: My 69 lonbed
im going to buy a presure sand blaster at the end of this month and a gallon of DTM primer. after all that i can really start getting busy.
thanks for the ambition. ha ha
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 09-18-2009, 04:00 PM   #61
brian69longbed
Re: My 69 lonbed
here is the engine for my truck. 79' 350 bored .030 over. this is going to be my 383 stroker.
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 09-24-2009, 09:32 PM   #62
brian69longbed
Re: My 69 lonbed
Name:  truck angle.jpg
no money had to work on pictures...
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 09-24-2009, 09:49 PM   #63
VA72C10
VA72C10
VA72C10's Avatar
Re: My 69 lonbed
Cool man, I like them.
Old 09-25-2009, 09:41 AM   #64
brian69longbed
Re: My 69 lonbed
i should have some progress pictures soon!!
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 09-27-2009, 06:34 PM   #65
brian69longbed
Re: My 69 lonbed
began sand blasting today
when i shave my cowl what happens to the mounting holes and the elongated holes for the spray??
this is my original glass for 1969! a little OOOO steel wool and glass cleaner! they look brand new!
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 09-27-2009, 06:40 PM   #66
VA72C10
VA72C10
VA72C10's Avatar
Re: My 69 lonbed
Looks good. Nice job on the glass. With the cowl, I am not running the sprayers. So those holes went away. THe mounting holes also are shaved. The biggest thing is to be sure to weld SLOWLY with lots of time in between for the metal to cool and switch back and forth from one side to the other. IF not, it WILL warp on you. And without the mounting holes, you won't be able to screw it down if it warps.
Old 09-27-2009, 07:16 PM   #67
brian69longbed
Re: My 69 lonbed
so you cover the mount holes and just use all the remaining holes?
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 09-27-2009, 08:11 PM   #68
VA72C10
VA72C10
VA72C10's Avatar
Re: My 69 lonbed
That's what we did...don't know any other way to do it honestly....THe only other way we thought was to screw in the panel and then grind off the screws and fill weld and grind them flush. But you'd never get the cowl off again if you did that.
Old 09-30-2009, 08:32 PM   #69
brian69longbed
Re: My 69 lonbed
WOO HOO PAY DAY!!! guess what im doing this weekend...
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 09-30-2009, 09:19 PM   #70
VA72C10
VA72C10
VA72C10's Avatar
Re: My 69 lonbed
Cool...is that primer for the frame or sheetmetal?....or both?
Old 10-01-2009, 12:28 PM   #71
68 Quad C10
68 Quad C10's Avatar
Re: My 69 lonbed
Attachment 500421
Attachment 500422
Attachment 500423
My suggestion on the smooth cowl mounting holes weld them up (only the ones that are on top of the cowl) and drill the hole in the firewall of the truck to fit a upholstery clip like this (see image) and then spot the upholstery clip on the cowl cover to line up with the original mounting hole then it will push in and hold nice and tight shouldn't rattle if you spray some rubberized undercoat on the bottom side of the cowl and the clips just a thought I have not done it yet but that was what I was planning.... i feel that would be better then no fastener in those locations but your call
http://www.tandscustomcars.com/
My Quad Cab build:http://67-72chevytrucks.com/vboard/s...d.php?t=352342
IT"S GOT A ROOF NOW WHOO HOO!!!!
65 GTO Build (If you wanna check it out) http://67-72chevytrucks.com/vboard/s...40#post4503040
68 Quad C10 is offline   Reply With Quote
Old 10-01-2009, 09:38 PM   #72
brian69longbed
Re: My 69 lonbed
cool thanks for the info! im still unsure exactly what im going to do
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 10-04-2009, 10:33 PM   #73
brian69longbed
Re: My 69 lonbed
blasted my cab today. 400 lbs of sand and 5 hours of work. reveled some rust but nothing serious
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 10-04-2009, 10:47 PM   #74
VA72C10
VA72C10
VA72C10's Avatar
Re: My 69 lonbed
Good work. Cab looks very good....wanna swap?
Old 10-04-2009, 10:52 PM   #75
nuke1
nuke1's Avatar
Re: My 69 lonbed
That cab looks super clean! I sure wish that they were that clean up here, also, wanna send up one of those cranes, i could use a new job and that looks interesting. hmmmm
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
