Old 06-29-2010, 05:31 PM   #51
spankbomb
Re: Triangulated 4 link
From what I understand, the lowers should be horizontal and the uppers should be slightly angled down.
As far as the pinion angle, from what I undertand if your trans output is at -3 deg, then your pinion angle should be +3 deg.
Building adjustability into your link system can help tune it.
http://67-72chevytrucks.com/vboard/s...=366409&page=3
Later,
Jon D.
Originally Posted by slimneverdies View Post
Ok Im reading this and still trying to decipher a few things. Does it matter which of the bars (either upper or lower) is parallel to the ground at ride height? Also do I set the pinion angle at 0* or the opposing angle of the trans output? I know I have to setup everything inside the frame but the pics are just a mockup
www.eastofaustin.com
spankbomb is offline   Reply With Quote
Old 06-30-2010, 04:25 AM   #52
slimneverdies
slimneverdies's Avatar
Later,
Jon D.
Thanks spankbomb, that shouldn't be to hard to accomplish. I guess I'll just set the rear at O* and make sure that Im able to dial in the wishbone a few degrees. I dont know where the trans will be set yet so better safe than sorry.
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
