Old 10-20-2009, 10:16 AM   #51
Rack Man
Re: 1971 c-10 teardown & frame up resto
Are you planning on using a roller?.....
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288
Rack Man is offline   Reply With Quote
Old 10-20-2009, 10:32 AM   #52
skyreep1
yessir
skyreep1 is offline   Reply With Quote
Old 10-20-2009, 03:18 PM   #53
skyreep1
no mo interest eh?
Old 10-20-2009, 05:30 PM   #54
msgross
msgross's Avatar
Originally Posted by skyreep1 View Post
no mo interest eh?
http://www.maaco.com/
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 10-20-2009, 07:07 PM   #55
Rack Man
Originally Posted by msgross View Post
From what I understand the roller job takes 7-10 coats with days & days of sanding and 99% of them still look like crap!
Spend YOUR efforts getting the truck road worthy and safe!
RM
Old 10-20-2009, 07:16 PM   #56
Hooligan71
Hooligan71's Avatar
Roller jobs are very time consuming to do it right. You have to wet sand between coats and do 7 or more coats to get it right! I used a 96 cent per can of walmart rattle paint on mine. It looks great. I even primed and painted the vinyl dash pad and it looks brand new. I am going to do the door panel wrap thing it does sound very cool.
FastLane Choppers
Tucson,AZ.
www.FLCAZ.com
Garage Built and Keeping It That Way!!
Chop That Fer
Hooligan71 is offline   Reply With Quote
Old 10-20-2009, 08:33 PM   #57
skyreep1
Actually good news, I found a black harbor frieght 1 qrt 1.8mm spray gun BRAND NEW! in a bush today in the ghetto (prolly stolen). SWEET!!! okay so now I need some recommendations on paint... less than $150 preferably, including bc/cc hardener and activator etc.
Thanks so much guys
Should I just stick with summit's hugger orange?
It would be really cool if I could do a mettallic or a candy or pearl, or even a kameleon but im afraid all those would be waayyyyy expansive.
PS I still like the rustoleum idea... but I see you guys' points
Old 10-20-2009, 09:23 PM   #58
msgross
msgross's Avatar
Tractor Supply has Allis Chalmers Orange Enamel... $45/gallon and they sell hardener as well.
http://www.tractorsupply.com/paint/s...ration-3474339
The Garage:
Old 10-20-2009, 09:25 PM   #59
skyreep1
would that work well on a truck you think?
Old 10-20-2009, 09:32 PM   #60
msgross
msgross's Avatar
yep, one of the boardmember (samwise68) painted his Oliver Green.. you should read his build thread for a low budget build. He was in HS as well and did a pretty nice job with what he had...
post #140
http://www.67-72chevytrucks.com/vboa...d.php?t=242993
The Garage:
Old 10-22-2009, 09:54 AM   #61
skyreep1
Question Re: 1971 c-10 teardown & frame up resto
How can you tell if its a 307 or a 350?
All I know is that it's a V8 with a rochester carb.
How do I tell the difference???
Heres a picture of the block
Old 10-22-2009, 10:16 AM   #62
msgross
msgross's Avatar
check the glovebox SPID sticker first, then look for a stamping in front of the pass side valve cover on the flat deck of the block. Last set of cast numbers is behind the driver side head just above the bellhousing, hard to see without a mirror though.
You can then research those numebrs online..
The Garage:
Old 10-22-2009, 10:32 AM   #63
skyreep1
cool thanks! I'll do that this afternoon. Is there no way to tell vie looking at it? I think rochester only made 2 bbl for a 71 c10
Old 10-22-2009, 02:28 PM   #64
msgross
msgross's Avatar
2bbl's came on everything for every year (i think)... you need to decipher the block codes.
The Garage:
Old 10-22-2009, 04:05 PM   #65
culp7
HickTown
culp7's Avatar
http://www.valsparglobal.com/val/res...alspar_imp.jsp
Heavy duty tractor pain is that shizz, many diff. colors here
1993 Ford Mustang Vert w/ 2.3
1969 Chevy C/10 w/350
1968 Chevy C-20 w/250
1976 Dodge Aspen W/ 225
2000 Toyota Tundra w/4.7
1987 Dodge Ram D-100 w/360
255/70-15
___________
(oo)══╬══(oo)
culp7 is offline   Reply With Quote
Old 10-22-2009, 07:55 PM   #66
skyreep1
I think Kubota orange is just about a perfect match. Thanks for the help BTW. It's a 307 with a TH tranny and a 2bbl rochester carb. =]
Little weak for my liking but it'll do.
OH great news!
Theres a really cool man that my dad has known for about thirty years. He's about 80 and he has agreed to let me use part of his shop, tools, sandblaster, paint guns, etc. He makes show cars for a living. Like beautiful, off the assembly line 1930's model A show cars.
So many of my problems have just been solved!
Old 10-22-2009, 08:15 PM   #67
msgross
msgross's Avatar
Just be sure to be careful with his tools and to live it cleaner than you found it.... a guy like that could show you some great tips as well...
The Garage:
Old 10-23-2009, 09:33 AM   #68
skyreep1
Cool Re: 1971 c-10 teardown & frame up resto
Yeah thats what Im hoping for =]
Tommorow Im buying my parts for the engine since it'll turn over but wont crank.
Since it sat in the weather with the hood off for a while im thinking
8x Spark Plugs 2.10
1x Plug Wires 19.95
1x Distributor point and condenser set 9.95
1x Distributor Cap 7.95
1x Distributor rotor 3.95
1x Distributor coil 19.99
1x Distributor lead 6.99
And I already have an oil filter/oil
and antifreeze..
Think I have it covered?
Old 10-23-2009, 12:10 PM   #69
skyreep1
No engine help
Old 10-23-2009, 02:15 PM   #70
skyreep1
oooookay then....
Old 10-23-2009, 02:52 PM   #71
smn69
oooookay then....
Good spark and good carb. will take care of it barring any mechanical problems.
smn69 is offline   Reply With Quote
Old 10-23-2009, 03:01 PM   #72
Sinister
Between Trucks...
Sinister's Avatar
For the price of the parts on the points distributor you could order an E-bay HEI.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 10-23-2009, 03:07 PM   #73
smn69
Or keep your dist. and coil and replace the points and condencer with an electronic unit from like Crane Cams. Summit has them for well under $100.
Old 10-23-2009, 06:09 PM   #74
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
yea that has been beat to death with him .........
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 10-23-2009, 06:36 PM   #75
skyreep1
I know I know, im sorry. My dad refuses to let me though because hes all about completely stock. Id personally rather have performance but he's fitting the bill so whatever.
Any other reccomendations other than what I have listed? I'm gonna try to get a carb rebuild kit to but that may have to wait a couple weeks.
frame, kbs, paint, restoration, rustoleum
