Old 11-01-2009, 11:17 PM   #51
VA72C10
VA72C10
VA72C10's Avatar
Re: Project: Agent Orange
In
Looks like a cool project and great work so far!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 11-01-2009, 11:41 PM   #52
hgs_notes
GEARHEAD
hgs_notes's Avatar
The masking would probably be easier if you used plastic sheet instead of newspaper. I'm not saying, just saying, ya know...
Looks like a good result though, the name definitely fits the finish.
hgs_notes is offline   Reply With Quote
Old 11-02-2009, 12:17 AM   #53
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Plastic sheets are not the best for using as a masking barrier. Paint can "sit" on top of it unlike a paper barrier where it absorbs and dries. When you go to pull plastic off you can leave paint chips or even paint that isn't dry onto your new paint job. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 11-02-2009, 06:50 AM   #54
vtblazer
vtblazer's Avatar
Originally Posted by AJs72K5 View Post
Use the stock crossmember....just move it back 2.5 inches.
I had thought about using the cross member that was with the 241 originally but have both to try.
Lizardskin is looking good. A little more cottage cheese than I expected though.
It settled a lot over night as it dried, it's not exactly like Linex but not Rhino Liner either, I'm good with it.
We'll see what the ceramic layer does for it.
Papers free.
Your right, Lizard Skin...lol
New pics, same spot of what it's looking like this a.m. as it's drying, calming down a lot too.
vtblazer is offline   Reply With Quote
Old 11-02-2009, 09:09 AM   #55
msgross
msgross's Avatar
I feel sorry for the guy that has to scrape that off, in 100 years!
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 11-02-2009, 09:32 AM   #56
AJs72K5
AJs72K5's Avatar
That is a big difference. Looks smoother.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 11-02-2009, 09:35 AM   #57
vtblazer
vtblazer's Avatar
With luck, it'll be one of my great grand kids!
Never thought I'd do this to a truck but in this case, it made good sense for the intended use & abuse it's going to see.
Build em to drive em baby!
Old 11-02-2009, 09:37 AM   #58
vtblazer
vtblazer's Avatar
Yeah, it's all good IMO.
Old 11-02-2009, 09:38 AM   #59
lks dcvn
lks dcvn's Avatar
Looks good! What is the cure time on that stuff - does it need heat to dry out - since it isn't that warm here (or there) much longer -
lks dcvn is offline   Reply With Quote
Old 11-02-2009, 09:57 AM   #60
vtblazer
vtblazer's Avatar
First coat seemed to dry enough to spray over in a couple hours, heat was @ 65 degrees in the shop.
I used a heat gun a little bit to help it along so I could spray the 2nd coat before ending my day in the shop, only had to hit the nooks & crannies. the flats were dry.
I applied the 2nd coat really heavy and there's still a couple places were it hasn't dried yet and I kept the shop @ 60 degrees all night.
Going to leave the heat @ 60 with hopes of being able to apply the ceramic layer tonight after work.
Haven't decided if I'm going to apply color to this section while it's masked off or whether I'll continue onto the bed area with the liner, at least spray color on the firewall & under the dash to avoid over-spray later I'm thinking.
Old 11-02-2009, 10:33 AM   #61
Luba
Luba's Avatar
Does that stuff come in colors or is it only gray? Looks good VT!
Luba is offline   Reply With Quote
Old 11-02-2009, 11:13 AM   #62
litebulblsc
litebulblsc's Avatar
The thing that turned me off about the lizards skin is the fact that it is sandable. That just makes it sound like it wont last as long as bed liner.
litebulblsc is offline   Reply With Quote
Old 11-02-2009, 11:17 AM   #63
Burt4x4
Burt4x4's Avatar
AWESOME!!
So next winter I can drop of my K5 and pick it up early spring?
That should be enough time for you to LIZARDSKIN my rig hahhaaa
Too much again hehehe
One of these years I need to do something about my floor...it's not too bad but year after year I can see the rust taking it's corse...
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 11-02-2009, 01:27 PM   #64
vtblazer
vtblazer's Avatar
Just flat black when it's dry but it's paintable.
Not really being used as a 'bed liner' per say, plus it's not advertised as such, it's advertised as sound & heat control.
Two other things to consider though, #1 - it's paintable where others are not & #2 - it cleans up with water.
Originally Posted by Burt4x4 View Post
AWESOME!!
When we're done with Moab next year, tag along with Greg & I on the trip home and fly back to Cali leaving it here to be fixed up, then the following Sept. fly out and we'll pull a caravan out to Moab again!
See how easy...
Old 11-02-2009, 01:43 PM   #65
vtblazer
vtblazer's Avatar
Dried & outside in the sunshine.
Old 11-02-2009, 01:46 PM   #66
Burt4x4
Burt4x4's Avatar
hahaha
Looks like a great product!
Thanks!
Old 11-02-2009, 05:09 PM   #67
litebulblsc
I realize this. I was trying to say two things at once. In response to the people talking about the texture that it is sandable to where you can smooth it out and paint over it.
But for the people talking about it being hard to remove, it is not a bedliner, and thus would be easier to remove.
I do plan to try it out, but on a car where it will be covered by carpet.
Old 11-02-2009, 05:21 PM   #68
Luba
Luba's Avatar
How do you plan on using it VT? Just as it is, or are you going to cover it?
Old 11-02-2009, 05:29 PM   #69
vtblazer
vtblazer's Avatar
After seeing & feeling it dry, I agree with you, it wouldn't make a very durable bed liner for any kind of abusive use.
Painting over it in body color.
Going to use a base/clear system.
There is a noticable difference now when rapping on the metal, a fair amount more muffled.
Old 11-02-2009, 05:51 PM   #70
vtblazer
vtblazer's Avatar
Ceramic coat dried up.
Didn't really apply it "as per instructions" but I think it laid down better my way.
Old 11-02-2009, 06:11 PM   #71
turp mcspray
turp mcspray's Avatar
Whats the surface like after it dried? Is it hard, or more soft and rubber like?
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 11-02-2009, 07:36 PM   #72
swyfor5
swyfor5's Avatar
That really looks good dude!
swyfor5 is offline   Reply With Quote
Old 11-02-2009, 10:57 PM   #73
ChevyFan24
Junior Member
Looks good.
1967 Camaro (in pieces)
1972 Chevrolet K/5 Blazer
1969 Chevrolet K/5 Blazer
2000 Chevrolet K2500 Crew Cab 454
1999 Chevrolet Blazer
2008 Polaris Ranger XP Orange Crush
ChevyFan24 is offline   Reply With Quote
Old 11-03-2009, 01:05 PM   #74
vtblazer
vtblazer's Avatar
Some how seems brighter in the shop now...
Base coat, still wet but ya can get the idea.
Old 11-03-2009, 01:39 PM   #75
vtblazer
vtblazer's Avatar
Had to air out the shop...
