Old 12-14-2009, 09:17 PM   #51
'55Chevylover
'55Chevylover's Avatar
Re: '55Chevylover's 55stepside build up
This is what the rear end looks like after the finished installation.
God Bless America
'55 Shortbed Stepside
'79 C10
2010 Malibu
Not too proud of: 2011 Nissan Altima, (Not American made)
'55Chevylover is offline   Reply With Quote
Old 12-14-2009, 09:24 PM   #52
'55Chevylover
Well, wouldn't you believe it, when I went back out the next day to admire my work, I noticed a puddle of oil under the right axle housing. After I checked it out, I noticed it had a very small hole and was leaking the gear oil out. I tried to weld it up but had no success. Oh well, I guess all that work was in vane. I will have to go another route. I found a 9" Ford rear end that came out of a '98 Ford Explorer that was the right width.
God Bless America
'79 C10
2010 Malibu
Old 12-14-2009, 09:30 PM   #53
'55Chevylover
So I loaded all that stuff up on a trailer and took it to a hot rod shop in Waxhaw to get the frame sand blasted and painted.
God Bless America
'79 C10
2010 Malibu
Old 12-14-2009, 09:36 PM   #54
'55Chevylover
I also had them build their version of the Mustang II front suspension. They aked me if I wanted a drop built into the axle and I told them to put a 3" drop and they asked me if I was sure, that they had done a '56 Chevy truck and the front bumper was just about touching the floor. The owner of that truck had them change it to a 2". I told them to just make it straight. They told me that would still give me some drop to the front end.
God Bless America
'79 C10
2010 Malibu
Old 12-14-2009, 09:46 PM   #55
'55Chevylover
This is what the frame looked like after sandblasting and painting. I wanted it powder coated and they told me that powder coating had to be put on bear metal and any rust pits would really show up bad. They suggested they prime, sand and then paint it. So that is what I had them do.
God Bless America
'79 C10
2010 Malibu
Old 12-14-2009, 09:49 PM   #56
'55Chevylover
This is what their version of the Mustang II suspension looks like finished. I had them build me one with power steering.
God Bless America
'79 C10
2010 Malibu
Old 12-14-2009, 09:56 PM   #57
poncho_villa
poncho_villa's Avatar
Boy, are we ever glad you have a good camera and know how to use it. This build is sweet.
58 Apache short fleetside ona 64 chassis:
poncho_villa is offline   Reply With Quote
Old 12-14-2009, 10:06 PM   #58
'55Chevylover
In this photo you can see the axle installed on the frame. They also boxed in the part of the frame where the new motor mounts were welded on and the mounting bracket for the new dual master power brake assembly is going.
God Bless America
'79 C10
2010 Malibu
Old 12-14-2009, 10:13 PM   #59
'55Chevylover
This is the new 9" rear end. It also has the 4 link brackets welded on, sandblasted and painted. One also shows the new 3.90 positraction unit that will be used.
God Bless America
'79 C10
2010 Malibu
Old 12-14-2009, 10:17 PM   #60
hotrodrookie
hotrodrookie's Avatar
This is the making of a great build. I was wondering why you installed that 4 link when you mentioned you had a 9 inch. And how did you find a 9 inch in an 98 explorer?
Question: What are the sizes of your coilovers? Spring rate? And how far in from the inside of the framrail is the top shock mount in on that cross member?..
...I plan on building my own..
thanks
hotrodrookie is offline   Reply With Quote
Old 12-14-2009, 10:24 PM   #61
'55Chevylover
This photo show the new dual power master cylinder installed on the frame.
God Bless America
'79 C10
2010 Malibu
Old 12-14-2009, 11:10 PM   #62
'55Chevylover
These two photos show the disc brake converson kit that I installed on the new rear end.
God Bless America
'79 C10
2010 Malibu
Old 12-14-2009, 11:24 PM   #63
'55Chevylover
While the frame was in the shop being painted, I found out that I could buy a crate motor cheaper than I could build the motor I had. So I got this from Doug Herbert. It is a 383 crate rated at 425 HP. It also has the March cerpentine system with A/C, Generator and Power Steering pump. The original carb setup came with a single 4 barrel but I bought the Edelbrock Endurashine dual quad set up and had them use it instead.
God Bless America
'79 C10
2010 Malibu
Old 12-14-2009, 11:30 PM   #64
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
You have a crazy awesome build going on! Keep the pix comin'.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 12-14-2009, 11:34 PM   #65
'55Chevylover
I took the engine to the frame shop and had them put it all together. The engine and a 700R4 trans. Loaded it up and took it back home. It has a 2500 Stall converter from a Corvette. Trans is rebuilt and guaranteed for 3 years from the time I start driving it.
God Bless America
'79 C10
2010 Malibu
Old 12-14-2009, 11:48 PM   #66
'55Chevylover
Another engine shot and a pic of the frame.
God Bless America
'79 C10
2010 Malibu
Old 12-14-2009, 11:48 PM   #67
ya it is a classic
wow this is looking very good!!! how did you sand the paint to bare metal? i use a 6in da air sander but i cant get into the cracks like you do. keep it up!!!
ps my bro in law is from charlotte nc. kewl
ya it is a classic is offline   Reply With Quote
Old 12-15-2009, 12:07 AM   #68
'55Chevylover
thanks
I am not sure what the spring rate is. I ordered this kit from Classic Industries and everything was there. I can take some measurements on the shock mounts and see if I can find the spring rates and coil size and add that to this thread.
God Bless America
'79 C10
2010 Malibu
Old 12-15-2009, 12:15 AM   #69
'55Chevylover
I used an aircraft stripper and then I used a 4" shaft mounted nylon 80 grit abrasive circular brush that I bought from Harbor Freight item #91371. Put it in my 3/8 drill and went crazy. Of course I used several to get the whole cab done. They also have a 120 grit wheel that I used after the 80 grit.
God Bless America
'79 C10
2010 Malibu
Old 12-15-2009, 12:17 AM   #70
JML55
JML55's Avatar
Who did you get the 4 link kit from? Can you post a closeup pic of how the panhard bar is attached? My kit uses a different style panhard bar but i like yours much better.
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
http://67-72chevytrucks.com/vboard/s...d.php?t=316140
http://67-72chevytrucks.com/vboard/s...d.php?t=806011
JML55 is offline   Reply With Quote
Old 12-15-2009, 12:30 AM   #71
ya it is a classic
hay thanks! also did you spray paint the primer on the cab. thats what i did on my 67 gmc its rustoleum sandable automobile primer. its really nice but i can take my finger nail and just barely scratch it and leave a mark. its nice and durable though
Old 12-15-2009, 01:16 AM   #72
av8tr33337
av8tr33337's Avatar
Great build thread. I don't have the $ to do as nice a build, but I hope I can put the same touch on my metal work as you did. Can you elaborate on what you mean by aircraft sander??? I built Jets for Cessna here in Wichita and we used Dotco's with cut off wheels, sanding pads, and scotchbrite pads, quite a bit but not sure if thats what you mean.
av8tr33337
AKA Bartman Email av8tr33337@yahoo.com
Bartman's Ad-S10 Chassis Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=415418
My First Youtube Video
http://www.youtube.com/watch?v=B6hSt...eature=channel
More Pics of the 51 Project
http://s668.photobucket.com/albums/v...hassis%20Swap/
1951 3100 Pickup
av8tr33337 is offline   Reply With Quote
Old 12-15-2009, 11:31 AM   #73
ya it is a classic
its a aircraft STRIPPER not sander. i think its a liquid that like softens and eats away the paint. then you take a wire brush and pretty much wipe it away
Old 12-15-2009, 01:54 PM   #74
'55Chevylover
The frame was sandblasted. That is the only way to get into all the cracks and crevices. Any rust pits need to be filled and primed with filler primer and sanded down before painting.
God Bless America
'79 C10
2010 Malibu
Old 12-15-2009, 01:57 PM   #75
'55Chevylover
That is correct. It is a stripper that I bought at Lowe's. It does exactly that, it softens the paint, actually bubbles it up and seperates it from the metal, and then you just scrape it off with a putty knife. Then I used the sanding wheels to bring it down to the bare metal.
God Bless America
'79 C10
2010 Malibu
