Old 09-11-2014, 02:46 AM   #51
1960chevypanel
Re: Factory Tow Hooks
Left side
1960chevypanel is offline   Reply With Quote
Old 09-11-2014, 02:48 AM   #52
1960chevypanel
Right side
Old 09-11-2014, 03:04 AM   #53
1960chevypanel
Hey 63-C10 do you know where I can find factory rear hooks for my truck? Same vehicle as above ('61 3/4 ton 4WD).
Also has anyone thought about adding a bracket to reinforce the frame area where these mount? I don't know what the last owner pulled with my truck, but the frame is buckled right at the hook mounting bolts... Might be a good idea to add a plate there.
Old 09-11-2014, 11:02 AM   #54
1963c-10
1963c-10's Avatar
Thanks for posting the pics of the tow hooks on the 3/4 ton, don't think we have those pics documented yet. I've got a set that I don't think I'm going to use (rear hooks). PM sent.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 09-16-2014, 08:27 AM   #55
1963c-10
1963c-10's Avatar
Some pics of the rear hooks I have
Old 09-23-2014, 01:05 PM   #56
1960chevypanel
Here are some pics of the mounting holes after I removed the hooks. Might help someone as a reference... These were a dealer installed item (not factory) so there were probably some variations in the mounting hole locations.
Old 09-23-2014, 01:08 PM   #57
1960chevypanel
Does anyone have a photo or diagram of the rear hook mounting location??
Old 09-23-2014, 01:17 PM   #58
1963c-10
1963c-10's Avatar
I'll look for factory diagrams.....as I've added a lot more literature to my collection from my same inquiry a couple of years ago....but this is what I found then.....
Link: http://67-72chevytrucks.com/vboard/s...d.php?t=526912
Old 09-23-2014, 01:22 PM   #59
1963c-10
1963c-10's Avatar
And Supermikes original thread on the rear tow hooks
link: http://67-72chevytrucks.com/vboard/s....php?p=5895780
Only factory diagram I can find and I can't enlarge it any more
Old 09-23-2014, 01:28 PM   #60
Budman56
Budman56's Avatar
Question Re: Factory Tow Hooks
so they look like they are mounted on the side of the rear portion of the frame?
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 09-23-2014, 01:32 PM   #61
1963c-10
1963c-10's Avatar
Not quite sure. Im trying to find a better image of the diagram. This pic is the only one I've ever seen with any factory diagrams. From what I've learned off the forum....they are obvious listed in the GM accessory books from 60-72....but no one has seen a factory 10-30 series install. Although they were dealer available to install from day 1. Most applications were med-heavy duty trucks. May also account for so little literature. I'm going to dig through my books tonight and see what I can dig up.
Old 09-23-2014, 01:41 PM   #62
Budman56
Budman56's Avatar
I have both sets front and rear hooks but haven't installed them because I wasn't sure where to put them and have been waiting for someone to show the correct factory locations. it looks like you guys are getting close.
MY 65 C20 BUILD
Old 09-23-2014, 01:51 PM   #63
1963c-10
1963c-10's Avatar
I know the 1/2 tons aren't drilled for them....at least the 2wd's. I installed mine where they fit best on the frame....plenty of pics earlier on in this thread. Haven't found any factory rear mounted trucks from 60-72 yet for 10-30 series.
The GMC factory hooks above in post 59 looks to be the old style GMC logo, which I believe ended around 59ish.......
Old 06-10-2015, 09:24 AM   #64
1963c-10
1963c-10's Avatar
Any new additions?
Old 09-29-2021, 11:56 PM   #65
Lokin4AReason
Lokin4AReason's Avatar
Does anyone have a template or measurement(s) of the hole(s) for the front hook(s) ?
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 09-30-2021, 12:19 AM   #66
1960chevypanel
What year are you working on?
Old 10-02-2021, 12:50 AM   #67
Lokin4AReason
64
Old 10-06-2021, 01:34 PM   #68
1960chevypanel
64
Checked my books, sorry no luck.. Maybe do a search here to see which members have them for 63-66?
