Old 07-25-2010, 03:01 PM   #51
tylordurben
tylordurben's Avatar
Re: 1948 Chevy Project
Originally Posted by BlueJeep View Post
So how close to the factory green is what you used, and what did you use? Thanks!
its single stage omi plus paint. took the cab and buffed out a small section behind the bed and simply color matched it with the computer scanner thingy. so its about the same, i guess.
tylordurben is offline   Reply With Quote
Old 07-25-2010, 03:02 PM   #52
tylordurben
wiring... rebel wire 9+3
Old 08-06-2010, 07:58 PM   #53
Groyd
Groyd's Avatar
Asked a question, but I saw where you had already answered it.
Thanks,
MG
1951 Chevy 3100/S-10:
http://67-72chevytrucks.com/vboard/s...d.php?t=406072
1957 Chevy 3200
1971 2WD Blazer - Sold
Groyd is offline   Reply With Quote
Old 11-07-2010, 11:22 AM   #54
Blanco
any updates on this truck?
Blanco is offline   Reply With Quote
Old 11-08-2010, 09:28 AM   #55
99 to Life
99 to Life's Avatar
where do you plan on putting your fuel cell? how big?
do you think it will interfere with running your exhaust as well?
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 11-11-2010, 10:53 AM   #56
tylordurben
sorry for the lack of updates. we are using the stock S-10 gas tank. it fits.
progress. well its been a while since i update this build, lots of wiring and finalizing loose ends ext. got some sheet metal on the truck along with a new grill and put her on the ground to check out the stance. i think its on the money.
cab corners needed repair...
hopefully soon all the other loose ends will be wrapped up and this thing will be running and driving around.
Old 11-11-2010, 11:04 AM   #57
Fat Mike
Fat Mike's Avatar
Do you have some closeup pictures of the part of the cab you cut and what it looked like behind that patch panel?
Fat Mike is offline   Reply With Quote
Old 11-11-2010, 11:04 AM   #58
99 to Life
99 to Life's Avatar
looking great. god I hope they never decide to paint it.
Old 11-12-2010, 12:27 PM   #59
skip99
skip99's Avatar
what do you use to raise and lower the front? is it air bagged also?
skip99 is offline   Reply With Quote
Old 01-12-2011, 01:07 PM   #60
tylordurben
been focused on my Shoebox and not really updating this build as much as i should. well the brakes are finished, the motor turns on so now we just need to fit the doors and hood along with putting a fan for the motor and install the driveshaft. front and rear glass is new and installed, once the doors are working they to get new glass and door seals. the interior work is about done; seat carpet headliner and door cards are all done up in matching green with contrasting white. the steering wheel is not shown in the pictures but its new and getting painted in white to match. the dash has all new gauges and chrome on the fresh paint so inside should be neat to drive around in.
Old 01-12-2011, 01:31 PM   #61
ratty 46
Nice progress ... did I see one of your other trucks up 4 sale on craig's list or ebay?? Looked like your work & in your area??
Ratty 46
ratty 46 is offline   Reply With Quote
Old 03-16-2011, 11:05 AM   #62
Layedoutsonoma91
Layedoutsonoma91's Avatar
Any updates on this?
Layedoutsonoma91 is offline   Reply With Quote
Old 03-16-2011, 07:55 PM   #63
tylordurben
been working on wrapping this truck up since i got back from my Cali trip.
stripped it down some and prepared it for a quicky paint job...
after sealing the truck with black epoxy primer, Leo sprayed it with a red oxide primer color, but its actually single stage paint color matched to look like primer...
then over it we sprayed the truck's original color...
because ever panel on the truck is banged up, we decided that a patina look would be the most effective way to finish this truck and make it enjoyable...
more pics coming soon. going to logo the doors with the owner's company and weather them to match.
Old 03-16-2011, 08:14 PM   #64
tylordurben
here is another one i just wrapped up. this time its a 50 long bed. the owner wanted to use it around the shop for deliveries. rewired the truck, made it 12 volt, installed new glass and seals along with a grill and some tailights, lots of little do dats. then we decided on making it a bit more uniform, so a patina style paint job using gray and blue was applied and now the truck has that old barn feel but its a solid driver to make the deliveries and use that he needs. door logos are next as soon as he gives me the layout.
Old 03-16-2011, 11:11 PM   #65
ratty 46
Patina, fake patina ... I don't care ... both are off the hook & look barn fresh!!
I love it.
Ratty 46
Old 03-17-2011, 07:19 PM   #66
troy54gmc
troy54gmc's Avatar
Dude u got the patina look down. very nice work.
troy54gmc is offline   Reply With Quote
Old 04-11-2011, 08:22 PM   #67
Layedoutsonoma91
any more pictures of the truck?
Old 04-17-2011, 10:45 AM   #68
RCbowtie69
RCbowtie69's Avatar
Just want to ask about your cab mounts,what did you use or is there kits out there?I'm helping a friend with his 50 5 window truck with S-10 frame build,your build is looking great.
RCbowtie69 is offline   Reply With Quote
Old 12-07-2011, 11:53 PM   #69
tylordurben
I love it.
Ratty 46
thank you!!!
just a few...
truck owner purchased an EZ kit. most of it was installed prior to my work.
unfortunately ive been sooo busy that ive let this thread fade away. then my laptop crashed and i lost all my pics since about early January 2011 till a month ago. so here is all i have to offer...
these pics are months old, the logo's have been "weathered" and the truck has gained a few thousand miles on it. the owner drives it almost if not everyday to work! he has a local tattoo shop and loves parking it on the busy street to attract more customers.
maybe one of these days when he brings it by the shop ill snap more overall pics.
thanks,
Yaril
Old 12-09-2011, 01:10 AM   #70
Laid_Out_50
Laid_Out_50's Avatar
Looking good
Laid_Out_50 is offline   Reply With Quote
Old 12-09-2011, 09:24 PM   #71
Rods57
Rods57's Avatar
what grit paper do you use on the top coat of paint?
Rods57 is offline   Reply With Quote
Old 12-10-2011, 08:50 AM   #72
tylordurben
it really depends, anywhere from 120 - 320. some areas you have to work lots of paint off and some areas i try and spray a little thing to make it easier.
Old 12-10-2011, 02:48 PM   #73
chevythechief
Love the patina paintjobs! Really, really nice
chevythechief is offline   Reply With Quote
Old 12-12-2011, 08:16 PM   #74
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Awesome work!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
