Old 12-22-2010, 04:52 PM   #51
blitz'd
vintage car junkie
blitz'd's Avatar
Re: project: WTF did I get myself into 50 chevy
I still need to do that, I never mocked up the radiator support so im not sure how much to cut off yet. If you look close at the picture you can see they didnt get painted.
1950 chevy truck, s10 swap, bagged, v8, 18s
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=392761
blitz'd is offline   Reply With Quote
Old 12-22-2010, 05:21 PM   #52
Fat Mike
Fat Mike's Avatar
I did notice that they were not painted and I was told to cut them 1/2" past the steering box.
Fat Mike is offline   Reply With Quote
Old 12-22-2010, 05:50 PM   #53
MrDude_1
because of the steering box, you're limited on how far back you can cut it.
the way ive seen almost everyone else do it is exactly what Fat Mike just said.. about a 1/2" from the steering box bolt.. you cant go any closer without effecting how the steering box is mounted. (plus any closer, and the box itself would be in the way)
you will still have to trim the inner fenders to fit.. so dont worry about cutting it "too far back".. you just trim all you can, then mod the fenders for the rest.
MrDude_1 is offline   Reply With Quote
Old 12-22-2010, 06:07 PM   #54
blitz'd
vintage car junkie
blitz'd's Avatar
Ive seen that in other peoples builds but that is another problem...no steering box yet.
Old 12-23-2010, 09:33 AM   #55
BlueJeep
BlueJeep's Avatar
You don't need a steering box, just go off the forward most bolt hole. I cut mine right up to the sleeve in the frame for that bolt, then cut the other side to match.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 12-24-2010, 06:06 PM   #56
vintage_car
How did you make firewall so clean?
vintage_car is offline   Reply With Quote
Old 12-26-2010, 10:02 PM   #57
hotrodjoe1952
hotrodjoe1952's Avatar
This is killing about about what frame to use on my build, it is a 52 long wheel base truck, original frame is still under it and i am thinking i will reuse it but this s10 conversion is so inviting to me lol...this is my first build involving frame/suspension work and i need some help understanding, would i need to move the rear axle to center the wheels in the wheel well opening? i was told the A-Arms need to be changed as well to give it a wider stance in the front, please someone help me with these questions so i can sleep better lol...thanks!
Here is a picture of what i am building.
hotrodjoe1952 is offline   Reply With Quote
Old 12-27-2010, 12:16 AM   #58
OrrieG
OrrieG's Avatar
hotrodjoe - I think you will get more answers if you post your question as a new thread instead of in the middle of someone else's.
OrrieG is offline   Reply With Quote
Old 12-27-2010, 11:03 AM   #59
hotrodjoe1952
orrie, i can't figure out how to start my own thread lol...
Old 12-27-2010, 11:30 AM   #60
blitz'd
vintage car junkie
blitz'd's Avatar
Welded up 50 somthing holes then a lot of body work. I re-did the passenger side and got rid of the heater hole while my cab was off. Next time I will cut out the whole thing and weld in a new firewall though. Way too much work the way I did it.
Old 01-05-2011, 11:16 PM   #61
RCbowtie69
RCbowtie69's Avatar
love the color, need more pictures
RCbowtie69 is offline   Reply With Quote
Old 01-06-2011, 10:50 AM   #62
blitz'd
vintage car junkie
blitz'd's Avatar
Thanks, im still iffy on the paint. I keep thinking I should wet sand the whole thing and use real clear.
Old 01-06-2011, 03:40 PM   #63
texas56
texas56's Avatar
Good Lookin Truck!
1955 First Series Thriftmaster
Blown 355 TH400, S10 Chassis,narrowed 9 Inch rear, air ride, 4 wheel disc brakes, 20s and 22s,
texas56 is offline   Reply With Quote
Old 01-08-2011, 09:41 PM   #64
50Bow-tied GMC
Sweet looking truck! I really like the color. I would like to shave the seam on my hood but have yet to find a good way to do it. How did you do yours?
50Bow-tied GMC is offline   Reply With Quote
Old 02-16-2011, 02:34 PM   #65
Kabwe
Certified Car Nut
Kabwe's Avatar
The truck is looking really nice and I agree with everyone on the color. I like the color a lot.
Kabwe is offline   Reply With Quote
Old 02-16-2011, 04:36 PM   #66
GhostTown
GhostTown's Avatar
Could you elaborate more on the width problems of your Camaro clip? What year Camaro was the clip from, problems you had, etc.?
GhostTown is offline   Reply With Quote
Old 02-17-2011, 10:30 AM   #67
blitz'd
vintage car junkie
blitz'd's Avatar
It was a 73ish clip, front steer. It might have been fine with the 6" wheels and skinny tires in front but these 18x8s were a no go. I had no steering without the tires rubbing the fenders. When I bought it the truck had stock camaro wheels in front with a 195/65 and it only rubbed when going into driveways while turning. Getting into my driveway tore up the passenger fender pretty bad.
I need to post up more pictures, ive been taking my sweet time mocking up the motor and tranny. Ive never done this before so im being extra careful. Measure 25 times weld once!
Old 02-17-2011, 03:20 PM   #68
Kabwe
Certified Car Nut
Kabwe's Avatar
Yep 2nd Gen Camaro is too wide, if you had a 1st Gen Camaro or a 68-74 Nova clip you would have been fine. I thought I would just share that info for those that may be thinking of going that route. Sorry If I'm out of place.
Old 02-17-2011, 07:04 PM   #69
AceX
>130dB Moderator
AceX's Avatar
Moved to Projects and Builds area.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 02-17-2011, 07:09 PM   #70
blitz'd
vintage car junkie
blitz'd's Avatar
Yep, they are a little narrower.
Thanks AceX!
Old 02-23-2011, 04:06 PM   #71
blitz'd
vintage car junkie
blitz'd's Avatar
Re: project: What did I get myself into 50 chevy
Frame and engine are together again. Still have not decided on what headers, brakes or control arms im using yet but here it is. Putting the cab and front clip on next.
Engine mounts
Old 02-23-2011, 04:13 PM   #72
bjcaldwe
bjcaldwe's Avatar
Looking good.
My AD Truck Build Thread
52 GMC one day laying on the running boards
2004 Chevy Crewcab. 3/5 and notched
bjcaldwe is offline   Reply With Quote
Old 02-23-2011, 07:15 PM   #73
Kabwe
Certified Car Nut
Kabwe's Avatar
Everything is looking really nice. Good job now keep the pics coming.
Old 03-02-2011, 10:21 AM   #74
blitz'd
vintage car junkie
blitz'd's Avatar
Mounted the cab last night but I didnt realize how much these mounts moved the engine up. I might have to tunnel the floor for the driveshaft.
Old 03-02-2011, 11:03 AM   #75
hotrod1
56 - autocross
hotrod1's Avatar
The lower your motor the better it handles.
hotrod1 is offline   Reply With Quote
