Old 07-18-2012, 09:24 PM   #51
Mikec10
Mikec10's Avatar
Re: Bagged or Lowered on 15" Rally wheels?
Mine, static drop, not rallies but still 15s on 235/75 tires, which are too fat, what offset/backspacing and tire combo can i run so i can turn lock to lock while tucking?
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears.
Mikec10 is offline   Reply With Quote
Old 07-18-2012, 11:11 PM   #52
Square_78
Square_78's Avatar
I love that old chevy light blue color.
Square_78 is offline   Reply With Quote
Old 07-19-2012, 10:16 PM   #53
Gryndar
My Junk. Current set is 3" drop arms, 1" drop springs in front and 4" shackle hanger kit in rear. 15x8, 4"bs corvette style wheels, police caps and 40s style trim rings front and rear with 295/50's at all corners no rubbing issues. plans are to drop 2 more inches if fron and drop rear to level it out. Plus adding 15x10 in rear.
Gryndar is offline   Reply With Quote
Old 07-22-2012, 02:40 PM   #54
robert_63
robert_63's Avatar
Here's my 85, djm tubular lower control arms with one coil cut from springs and flipkit on back. tires are a bit too tall but workin on it. currently have it dissassembled for a 5.3 swap.
robert_63 is offline   Reply With Quote
Old 07-23-2012, 11:27 AM   #55
made2drag
made2drag's Avatar
nice!
made2drag is offline   Reply With Quote
Old 07-28-2012, 07:50 AM   #56
i heart square bodys
i heart square bodys's Avatar
[00
i heart square bodys is offline   Reply With Quote
Old 07-28-2012, 07:55 AM   #57
Originally Posted by ymerej71 View Post
Here's a couple pics of my '79 GMC...
how did you get the rims widened and what size of tires are you running front and rear ? how wide are the back rims and where was the width added ? thanks !! ohh and is the box tubbed at all ?
Old 07-28-2012, 07:50 PM   #58
74 stepside
74 stepside's Avatar
Wheel Vintiques makes the ralley wheels in 15x10
74 stepside is offline   Reply With Quote
Old 07-28-2012, 09:47 PM   #59
yrusoslow
i run 15x10's all the way around with 295/50-15's
yrusoslow is offline   Reply With Quote
Old 07-28-2012, 09:47 PM   #60
yrusoslow
Old 07-29-2012, 08:10 AM   #61
flamingbig10
6.0 powered square
flamingbig10's Avatar
I'm running them on the back with drag radials
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 07-29-2012, 09:46 AM   #62
ymerej71
ymerej71's Avatar
I'm running 15"x8" wheels up front and 15"x10" (4.5" backspacing) on the rear. The rear wheels are wheel vintiques purchased from summitracing.com.
I've got 295/50/15 BFG T/A's on the rear, and 275/60/15 BFG's on the front. The front tires are a taller profile than the rear but I already had them on the truck and didn't want to buy new ones for now. With the front end sitting slightly lower than the rear the differences in the the tires isn't really noticable because the tops of the tires are tucked under the fenders... And no the bed is not tubbed. There's no need for it, the 295/50 plenty of room on a stock bed.
ymerej71 is offline   Reply With Quote
Old 08-22-2012, 01:34 AM   #63
low81
low81's Avatar
Bagged on rally wheels
low81 is offline   Reply With Quote
Old 08-22-2012, 12:47 PM   #64
bbbc10
Diggin The SquareLife
looks good...any more pics...wht is ur air suspension set up
bbbc10 is offline   Reply With Quote
Old 09-23-2012, 06:19 PM   #65
69BBsuburban
Right in front of you.
69BBsuburban's Avatar
Not bagged....
Pinstriping by Josh
'78 Chevy Silverado SWB (lowered, 454)
'90 Chevy Sport Truck
'68 Dodge Charger R/T
1930 Ford Model A
69BBsuburban is offline   Reply With Quote
Old 09-26-2012, 07:28 AM   #66
motornut
78K & 79C Jimmys
motornut's Avatar
I'm thinking to get 10s for the back,they look awesome here
would these be right?look like it
http://www.summitracing.com/parts/WV...5042/?rtype=10
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 11-10-2012, 08:12 PM   #67
Thanks!
I've got 295/50/15 BFG T/A's on the rear, and 275/60/15 BFG's on the front. The front tires are a taller profile than the rear but I already had them on the truck and didn't want to buy new ones for now. With the front end sitting slightly lower than the rear the differences in the the tires isn't really noticable because the tops of the tires are tucked under the fenders. I'm also a little hesitant to get lower profile tires for the front because, with the static drop, I have to watch where I drive now to keep from dragging the lower arms.
are the wheels the 5 inch back space ones or the 4.5 inch backspace ones ? haha i want to get them for my truck but i want to make sure i get the right ones so i dont have to do any modifying to make them work , thanks !
i was also thinking about running those rims with 245's but now that i see you have the taller tires im thinking 245's might look a little too small . thoughts?
Old 11-10-2012, 08:31 PM   #68
81Psychobilly
81Psychobilly's Avatar
Lowered, non bagged
81Psychobilly is offline   Reply With Quote
Old 01-05-2014, 02:41 AM   #69
BC10
BC10's Avatar
Originally Posted by Wet..Paint View Post
Where did you get your center caps?
x2 Those are NICE!
BC10 is offline   Reply With Quote
Old 01-05-2014, 05:35 PM   #70
Slammed66
Needs a Big Block
Slammed66's Avatar
Bagged
1964 Short box
On dropmembers and billets
1962 Suburban family cruiser
1972 K10
Slammed66 is offline   Reply With Quote
Old 01-05-2014, 06:14 PM   #71
BC10
BC10's Avatar
NICE! What is the backspace on those original rally?
Old 01-06-2014, 12:10 PM   #72
nico
nico's Avatar
Here's mine before I replaced the cut springs... 15x8 Rallyes with 255/70 BFG's.
nico is offline   Reply With Quote
Old 01-06-2014, 01:20 PM   #73
Malo83
Cruzzzn' Vet
Malo83's Avatar
This is my 83 with a 4/5 drop and 15x8 15x10 rallys
Malo83 is offline   Reply With Quote
Old 01-06-2014, 09:18 PM   #74
Lambchop76
Sorry for the delay... the back axle is flipped which equates to about 5", and the front has dropped spindles plus 1 full coil cut out of the springs which sets the front end just a tad lower than the rear. 15x8 rallys on the front, 15x10's on the back.
What size are the dropped spindles? Perfect stance on this and want my 87 to sit this way. I too have 8" and 10" truck rallies. 295/50s rear and going with a 255/60 front
Lambchop76 is offline   Reply With Quote
Old 01-06-2014, 10:02 PM   #75
Sodell
Sodell's Avatar
My 87[IMG][/IMG]
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
