Old 05-13-2011, 08:09 AM   #51
rollinrooster
rollinrooster's Avatar
Re: '49 chevy with s-10
Originally Posted by MrDude_1 View Post
another quick question... how low is your cab mounted to your frame? looking at that, if the back is layed out on the runningboards, your cab would probably be almost flush with the framerails....?
I made my mounts about 3.5" off the frame so that i didnt need a driveshaft tunnel. My truck wont lay the runningboards because of the wheel tire setup i'm using. At the back of the cab i've got close to 2" from the cab to the frame.
rollinrooster is offline   Reply With Quote
Old 05-13-2011, 08:13 AM   #52
rollinrooster
[quote=1lo67;4676891]Was hoping to be ready for Nashville Goodguys.. but i got a small job to do...money first you know.[/quote
I know what your saying about the money. Seems like i stay BROKE!!
Old 07-10-2011, 03:23 PM   #53
Leroy-B1
Interested in what you have done and don't live to far away.....what s-10 frame did you use and what all did you have to do to make it work? I'm looking at a 48 to do something similar too
Leroy-B1 is offline   Reply With Quote
Old 07-10-2011, 03:58 PM   #54
KQQL IT
At the body shop.
KQQL IT's Avatar
which s-10 chassis is it?
ive a 2000 regular cab short bed.
And i like to get a 49ish body for it.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is online now   Reply With Quote
Old 07-11-2011, 07:45 AM   #55
rollinrooster
I used a 1989 regular cab long bed.
Old 07-11-2011, 07:56 AM   #56
rollinrooster
I used an '89 model standard cab longbed.(bought the whole truck running with a 4.3 for $150.00) I will say that there is more fabrication work involved than what i originally thoughtbut have friends that have subframed thier trucks and they tell me that there is alot of fab work if you go that way to. You're welcome to stop by anytime.
Old 09-13-2011, 09:12 PM   #57
rollinrooster
Just finished stripping my frame down to the metal and filled most of the holes that wont be needed Now time to get the frame and all the suspension parts painted.
Old 09-19-2011, 11:42 AM   #58
texas56
texas56's Avatar
LOokin GREAT!
1955 First Series Thriftmaster
Blown 355 TH400, S10 Chassis,narrowed 9 Inch rear, air ride, 4 wheel disc brakes, 20s and 22s,
texas56 is offline   Reply With Quote
Old 09-19-2011, 04:00 PM   #59
rollinrooster
Originally Posted by texas56 View Post
LOokin GREAT!
Thanks, it means alot to me to have someone with as nice of a truck as you have to say that about mine.
Old 09-22-2011, 08:38 PM   #60
lo72
Truck Junkie
lo72's Avatar
This is one fine truck! I've been following your build and I must say it is basically a plan for my 52. I have the s10 frame and I'm collecting parts to get a head start. I believe you said your gonna run re6s on the front, could you take some up close pics of where you cut the pocket out to clear the bags. Any help in that area would make it easier when I start. Thanks and keep up the good work and of course lots of pics to follow along with.
lo72 is offline   Reply With Quote
Old 09-25-2011, 03:48 PM   #61
rollinrooster
Thanks for the nice words. On the front if you use re6's you dont have to open the pocket up. I opened the front pocket up on mine because alot of my friends have airride equiped trucks and cars and they all say that with my truck down to the bare frame that i should go ahead and open them up. (This gives you more options for bags re6's, re7's or 2600's) later if i decide to change to something different. I included some pictures of the pockets opened up.
Old 09-25-2011, 09:23 PM   #62
MrDude_1
if you stick with something like Slam Specalties RE6 or SS6 bags, you only trim a tiny amount of the spring pocket lip.
you dont have to massively cut your frame.
dont touch your frame until you have bags in hand. that way you dont over cut it.
MrDude_1 is offline   Reply With Quote
Old 09-25-2011, 10:21 PM   #63
rollinrooster
I have to agree,and so i used a set of 2600's to let me know how much to cut. I will say that re6's and re7's dont seem to ballon as much as 2500's and 2600's. I believe that no two setups are the same and when i had re6's in the front of my truck i could air it up and down with plenty of room without trimming the pocket. But like MrDude said, just wait till you can buy or borrow some bags.
Old 09-25-2011, 10:25 PM   #64
Layedoutsonoma91
Layedoutsonoma91's Avatar
I strongly recommend going with a bigger bag. I had re-6's in the front of my s10, which has a v6 and weighs a lot less than your truck will. It takes twice the pressure to get full lift than a size bigger bag, and will ride a lot better than re-6's. They take way too much pressure to lift an s10 much less a 49 chevy. You will be swapping them out in the future if you don't now, and cutting the pocket more. I would run re-7s in front and back, possibly re-8s in the back depending on clearance of your tire.
Edit: Slam bags do not balloon as much as airlift and other bags, so you can cut less and have a larger bag.
Layedoutsonoma91 is offline   Reply With Quote
Old 09-26-2011, 02:36 PM   #65
lo72
Truck Junkie
lo72's Avatar
Thanks for the input I'm sure it will save me time and headaches when I start the plan is re7s on the front and 9000s on the rear with a tri 4 bar. Thanks again!
Old 09-27-2011, 06:49 PM   #66
not2oldchevy
Super good looking truck!! What did you use to clean the frame with? Thanks Bill
not2oldchevy is offline   Reply With Quote
Old 09-27-2011, 07:12 PM   #67
Kabwe
Certified Car Nut
Kabwe's Avatar
Great looking truck. Really nice.
Kabwe is offline   Reply With Quote
Old 09-27-2011, 08:54 PM   #68
rollinrooster
Bill, i just used 2" roloc disks and alot of elbow grease.
Old 09-29-2011, 08:15 AM   #69
rollinrooster
Thought i would get a few shoots of my little helper.
Old 09-29-2011, 09:14 AM   #70
oldman3
oldman3's Avatar
Good to get them started young, frame and parts look good....Jim
oldman3 is offline   Reply With Quote
Old 12-05-2011, 05:03 PM   #71
rollinrooster
Finally finished painting all the suspension parts. Now time to get this thing put back together!!!
Old 12-05-2011, 05:46 PM   #72
oldman3
oldman3's Avatar
Chassis looks good....Jim
Old 12-05-2011, 06:14 PM   #73
Kabwe
Certified Car Nut
Kabwe's Avatar
It sure does.
Old 12-05-2011, 07:37 PM   #74
xpickup
xpickup's Avatar
rollinrooster, The frame looks great and it is good to see that you have a helper also. Great job.
Shannon
xpickup is offline   Reply With Quote
Old 12-05-2011, 09:28 PM   #75
BlueJeep
BlueJeep's Avatar
How wide is your 9"? I assume it's narrowed since it's the later housing.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
