07-19-2010, 05:11 PM | #51 |
67cheby
Re: The Fuse is Lit...
boy if only that truck had some Coys on it....im just saying
07-19-2010, 11:42 PM | #52 |
You have a darkside...you know that? lol
Rex |
07-21-2010, 12:00 AM | #53 |
Okay after some trial and error and error and error, I think I have the tank close to where I want it.
I put the bed frame on to help me with the height and placement. New steel and bolts were from GMCPauls. I cut both back crossmembers out, here is the pic of the second to last brace. I still need to fill in some rubber so the metal does not rub. More pics coming soon.
Rex |
07-21-2010, 03:23 PM | #54 |
My frame was tweaked a little, droping one side about 1/2" lower than the other in the rear. I used a flat piece of 1/4" steel to brace it back up and then slid the tank to the steel.
I will have to modify the steel piece in order for the inside back bumper bracket to work. I will also fab some hinges for the tank straps and mount them to the steel piece. As you can tell I gained quite a bit more space by moving the tank back. Before After
Rex |
07-21-2010, 07:24 PM | #55 |
sweet progress my friend. i am utilizing a 90 s10 blazer tank in mine. bit smaller than the fullsize blazer tank. just fyi
07-21-2010, 10:44 PM | #56 |
Still Learning
Looks like there may be enough room for the panhard now. Nice work. I would like to see some more pics of it from the rear.
07-22-2010, 12:09 AM | #57 |
I did gain alot of space but I am still gonna have issues with the panhard bar. I would be glad to get those pics for ya. Thanks for looking
Rex |
07-22-2010, 10:01 PM | #58 |
Got the straps welded on.
I must say first that I completely unashamedly stole this mounting idea from Rokcrln. The major difference is that his looks about 1000x's better than mine. But I did get it to work. I took 1/2" tubing and put a 3/8" bolt through it with a lock nut on the end. Took a small piece of 3/16" steel and welded it to the hinges. I took the original blazer straps, cut off the ends and welded one end to the middle hinge piece and a 8" long 5/16" carriage bolt on the other. Then took some 1/8" strap, fabbed and welded it to the back new crossmember Make sure everything lines up... Ready for a test fit
Rex |
07-22-2010, 11:52 PM | #59 |
VA72C10
nice progress
Looking for a 67-72 swb or blazer project in or around VA. |
07-23-2010, 02:02 PM | #60 |
Got the tank in and fitted, everything seems to fit pretty good. I now need to put something between the metal and the tank to keep them from rubbing. I have some wide nylon strap, I wonder if that would work or just put felt back on it.
Any suggestions? Mcbassin, here are some other shots you requested, let me know if I can get some more for ya.
Rex Last edited by RocketKing; 07-23-2010 at 02:02 PM. |
07-23-2010, 02:06 PM | #61 |
67cheby
man that tank sets in there nice the only thing that could make that pic look any better is ?????? oh ya wheels
07-23-2010, 02:32 PM | #62 | |
Lol, hey don't be hatin' on my "5-star" rimmies man!
Rex |
07-23-2010, 05:57 PM | #63 |
6>8 Plugless........
Nice work on getting the tank mounted in there!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
11-17-2010, 01:04 AM | #64 |
Man, it has been awhile since my last update... if I would stop changing my mind and redoin' stuff things would go alot faster. lol
Anyway, I am test fitting the engine. LQ4 with the #2 adapters the are shown on glock's thread. The only problem is in order to keep the A/C in the factory location you have to trim the passenger adapter plate (also on glock's thread) and move the motor mount back. Then take the frame tower (these are original 6 cyl towers on the rear holes) and add 2" toward the rear and drill a new hole to attach the motor mount, the hole we drilled is 1 3/4" from the original. backside clearance shots with A/C oil pan
Rex |
11-17-2010, 08:52 AM | #65 |
Still Learning
Nice work on fitting the engine mounts! Can you get some picks of the whole engine from the sides or front. I'd like to see how the gap is on the firewall. thanks,
11-17-2010, 10:18 AM | #66 |
VA72C10
nice progress! Keep plugging away at it!
11-17-2010, 10:30 AM | #67 |
67cheby
and just when i thought you had forgotten you had a truck !!!
11-17-2010, 10:43 AM | #68 |
Sorry, but the cab is not on the frame yet, give me a few weeks, I hope to have it on and I will be glad to help you out.
Rex |
11-17-2010, 10:47 AM | #69 |
Well, I kept tripping over this thing in the garage and lo and behold it was a truck!!!
Actually, I took the gas tank out and replaced the original bracing, I just did not like how low it hung below the frame, and then I replaced all my springs with some a little looooower.
Rex |
11-20-2010, 01:28 PM | #70 |
Has more rust than truck...
Subscribed! Nice work, Thanks for the info about the 6 cly stands.
11-20-2010, 02:31 PM | #71 |
Thanks for the compliment! Let me know if I can help with any more questions you might have.
Rex |
11-24-2010, 12:24 AM | #72 |
In case anyone is looking at exhaust manifolds instead of headers I thought I would show you a test fit of TBSS manifolds.
DRIVER SIDE PASSENGER SIDE
Rex |
11-24-2010, 09:19 AM | #73 |
Still Learning
Are you planning on running A/C on your truck? Will you be able to install and remove the compressor with this setup? Looks great! where did you score the TBSS manifolds?
11-24-2010, 10:59 AM | #74 | |
I got the manifolds from TBSSowners.com, the guy gave them to me free, I just paid shipping. ($30) Some people over there try to sell them for $100 bucks but some will just give them away. As a matter of fact, I had two different guys that I contacted about giving me their manifolds, if your interested I will give you the name of the person with the other set. LMK Rex
Rex |
11-24-2010, 11:22 AM | #75 |
67cheby
looks great for those of us who dont know what is TBSS ??
