Old 12-13-2011, 09:06 PM   #51
docrock
docrock's Avatar
Re: My 54 GMC Build
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344
1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494
R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438
1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250
docrock is offline   Reply With Quote
Old 12-13-2011, 09:13 PM   #52
docrock
docrock's Avatar
Re: My 54 GMC Build
this is going to be a great motorName:  12 cylinder falconer.jpg
Old 12-14-2011, 03:40 PM   #53
docrock
docrock's Avatar
Re: My 54 GMC Build
Size:  51.8 KB engine compartment is close to completion. I am going to take the serpentine belt of and detail all the parts in front. Today working on paint prep of the cab, hopefully by Saturday it is ready to paint. next week will be interior work, steering column needs to be modified because it is 4 inches to long, got to figure that out, change glass and weather strip on passenger door, ebrake, speedo modifications, heat and ac modifications.
lots to do. Doing good on the budget for this build, 2000 is it. 500 for the 54, 700 for the 93, and 200 for the radiator. Spent 200 hundred for paint supplies. The bed I am sure will eat up the rest of the budget.
Old 12-14-2011, 04:20 PM   #54
Spackle100
Re: My 54 GMC Build
Looking good!
Spackle100 is offline   Reply With Quote
Old 12-15-2011, 12:04 AM   #55
upon1
upon1's Avatar
Re: My 54 GMC Build
It's coming out great! Especially with that budget. Can you give me more details on the brake booster/mc and your pedal setup.
"Lifes to short to drive an ugly truck."
Project 55 To Life
http://67-72chevytrucks.com/vboard/s...d.php?t=432994
upon1 is offline   Reply With Quote
Old 12-15-2011, 12:48 AM   #56
docrock
docrock's Avatar
Re: My 54 GMC Build
master cylinder and booster are from the silverado. I cut the pedal hangar from the donor truck too. I cut the firewall out of the silverado and then attached panel sections of it to the original fire wall where I needed to attach late model parts
Old 12-15-2011, 03:20 AM   #57
tomsprojects
tomsprojects's Avatar
Re: My 54 GMC Build
Looks good Dave!!!
tomsprojects is offline   Reply With Quote
Old 12-17-2011, 12:45 AM   #58
docrock
docrock's Avatar
Re: My 54 GMC Build
got the rust patched spent the last two days sanding filling and sanding some more. Might shoot color tomorrow
Old 12-17-2011, 02:07 AM   #59
tomsprojects
Re: My 54 GMC Build
It looks good Dave , get her done.
Old 12-17-2011, 07:34 AM   #60
OKGMC4
OKGMC4's Avatar
Re: My 54 GMC Build
Man I love these kinds of projects. Using stuff you have, making what you don't. Anyone who has a ton of money can throw the checkbook around and get results. This takes skill and thought. Can't wait to see this done!
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 12-17-2011, 02:19 PM   #61
docrock
docrock's Avatar
Re: My 54 GMC Build
thanks guys for the encouragement. I could not do this without this Forum. There are a lot of talented guys on here.
Old 12-17-2011, 03:07 PM   #62
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: My 54 GMC Build
Looking good man.
BTW I heard you mention (in another thread) you were thinking about buying a tig welder. I love my miller diversion 180. It does AC/DC welding, runs on 110 and 220, comes with a foot pedal and a torch wheel, weights in under 50 pounds, and can handle anything you will need done on a car.
Kabwe is offline   Reply With Quote
Old 12-17-2011, 03:16 PM   #63
docrock
docrock's Avatar
Re: My 54 GMC Build
Thanks Bud,
Yours is a real inspiration.
I will check out that welder
Old 12-17-2011, 03:26 PM   #64
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: My 54 GMC Build
Your welcome man. You may be able to find a nice use tig also. But remember you may have to give up size. The older tig machines are transformer machines and they are heavy but last forever basically. The newer machines are inverters and that is the reason for the compact size. If size is not an issue you may be able to find a nice used transformer machine cheaper than the diversion. Size was a issue for me I work in a 2 car garage. I paid 1600 for my Miller Diversion 180. I'm sure you could find a older machine much cheaper.
By the way, once you tig body panels man you will never go back.lol But you will always have use for you mig. I find I love them both and the both have their uses.
Old 12-19-2011, 07:29 PM   #65
docrock
docrock's Avatar
Re: My 54 GMC Build
still blocking
Old 12-19-2011, 11:24 PM   #66
xpickup
xpickup's Avatar
Re: My 54 GMC Build
docrock, Looking good. Good to see one on a budget. Do you have any pictures of the tin woody on your avatar. I really like them.
Shannon
xpickup is offline   Reply With Quote
Old 12-20-2011, 08:03 PM   #67
docrock
docrock's Avatar
Re: My 54 GMC Build
Size:  22.4 KB this is a 49 Olds Woodie. Its not a Tin Woodie, it has real wood. I am building one of those but it is a long process and has to wait till I finish the truck
Old 12-24-2011, 09:53 PM   #68
docrock
docrock's Avatar
Re: My 54 GMC Build
Finally got the cab painted
Old 12-24-2011, 11:48 PM   #69
Wybrow
Re: My 54 GMC Build
That's an awesome color! Looks almost like clear-coated raw.
Wybrow is offline   Reply With Quote
Old 12-25-2011, 02:54 AM   #70
tomsprojects
Re: My 54 GMC Build
You have been buisy, I wish I could paint like you.
wow, three pages and your all most done, 7 pages and I havnt even started on mine yet.
Old 12-25-2011, 07:29 PM   #71
docrock
docrock's Avatar
Re: My 54 GMC Build
YOU are the Master Painter, I am just lucky sometimes
Old 12-26-2011, 02:12 AM   #72
tomsprojects
Re: My 54 GMC Build
I cut mine up today.
Old 12-28-2011, 11:26 PM   #73
docrock
docrock's Avatar
Re: My 54 GMC Build
I started to install some new glass and weatherstripping and discovered that one of the wings had a little rust. Cut, tack, weld, grind, paint, ready for a new strip Name:  001.jpg
Old 01-04-2012, 12:05 AM   #74
docrock
docrock's Avatar
Re: My 54 GMC Build
Size:  49.7 KB column is too long
Old 01-04-2012, 12:07 AM   #75
docrock
docrock's Avatar
Re: My 54 GMC Build
Size:  43.0 KBtrying to deside to use a different one or just cut the donor
