08-07-2010, 08:44 PM | #51 |
Grandpa in the rustmobile...
Re: Brakes sticking a lil do I have right prop. valve and adj. on brake rod?
One line was slightly kinked...well see...
(I forgot whether it was front or rear line though)
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
10-15-2010, 06:34 PM | #52 |
Ok update..
I installed a brass disc drum prop. vavle, thinking it would be the fix.. Wrong, They still hang, I really need to fix this before I put new shoes/rotors on for the 3rd time..rediclous! I DONT bench bleed my MC before installation is it THAT important (already bled again, duh stupid!) And, whats the button at the front of the Mc do? I pulled Mc from booster, and still have pressure on the calipers I run DOT 3 Brake fluid, 1 can said synthetic, 1 didnt say anything, just DOT 3 HELP!!
10-15-2010, 11:06 PM | #53 |
Anyone?
Could I possibly have 1.25" rotors, and calipers for the 1" rotor? Im stumped here... Thanks
10-15-2010, 11:09 PM | #54 |
Its a Truck Thing......
I always bleed my MC before putting them on, the button is suposed to be pushed in while bleeding. If you have a old shop manual it will describe in detail.....
How old are the rubber lines? Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time Last edited by 71meangreenc10; 10-15-2010 at 11:11 PM. |
10-15-2010, 11:34 PM | #55 |
New braided lines from ECE, made by inlinetube
I didnt use the button/bench bleed Is it that important??? Gotta be bad calipers, bad mc? (thats what my gf's dad keeps saying?) Or calipers/rotors not compatible Pretty sure there is 2 diff. sized rotors 1.25" and 1" thick rotors, are ther diff. calipers for each rotor diameter? Thanks guys im at my wits end No old shop manual here but will google
10-15-2010, 11:47 PM | #56 |
Bench bleeding is very important.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
10-16-2010, 04:45 AM | #57 |
67-72 parts collector,…
The calipers have to match the rotor width, and diameter.
The stock rotors are all the same diameter. Can youu run through your disc brake swap from the beginning? Or was it this way when you got the truck? When I do a disc brake swap from 6-lug, to 5-lug,... I always just use new parts. M/C, Prop valve, hoses, calipers and rotors. Which parts are new, that you put on?
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 10-16-2010 at 04:48 AM. |
10-16-2010, 10:32 AM | #58 |
I swapped to disc about 1 year after I bought the truck
So If i orderd rotors/calipers for 71 chevy truck c10 they all match no worries about getting wrong width? Ok, Im going thru my reciepts now (running #'s on internet website from store) Brake calipers-Orielly 1970 c10 advance-booster 1971 chevy c10 advance-brake master cyclinder-correct MC for 71 c10 (pic matches mine also, so does part number prop. valve (brass aftermarket disc drum) brake fluid-DOT 3 Synthetic (does synthetic matter?) calipers- (Cant find reciept) Advance rotors- 71 c10 hoses-replaced all 3 thru ECE, they get em thru inline tube. Inline tube ticket says 'drum drum'. ECE ticket says 67-70 disc drum conversion So idk there? autozone pads-71 c10
10-16-2010, 10:48 AM | #59 |
Oh, Just thought of something else..
My prop valve has 2 ports for the front brakes Im assuming to run 2 lines one to left front wheel other to right front wheel I plugged 1 port and ran 1 line to a T that went to each front wheel
10-16-2010, 11:03 AM | #60 |
Plugging one front port is fine.
Your above description says: Oreillys Calipers 1970 They didn't have calipers on trucks in 1970, so that must be a typo. Then below that you say you can't find the caliper reciept.
10-16-2010, 01:03 PM | #61 |
which wheels are sticking ... all ... both rear ... both front ... both right ... both left ... right rear ... left rear ... right front ... left front?
10-16-2010, 10:36 PM | #62 |
Yeah, sorry
I dont know the year or the calipers... I asked the guy at the parts house if there was 2 diff. size rotors, he said no just 1 ugh I know for a fact just front left, but think both fronts, will get exact facts tomorow after church.. Calipers-Unknown what they fit.. Everything else is correct (71/72chevy c10) Someone told me start from caliper and go up checking for fluid by cracking a a line somewhere to see if it releases pressure?...Idk,,thanks guys
10-17-2010, 10:39 PM | #63 |
Ok! Progress!
Bought new Mc from orielly today, looks just like factory ones disc drum with 2 clips instead of 1 bench bled MC bled brakes and there ALOT better so far.. 1 Side is still sorta hangin so imma replace that caliper (warranty) I will keep yall updated..
