Old 04-05-2011, 06:13 PM   #51
334scotia
Re: Officially a 1 ton
Thats a good looking truck, Im going to 3/4 ton axles myself on my 1970 k5. Still got some brake lines to run them i ll be on the road. How does yours handle?
1970 K5 Blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=401942
334scotia is offline   Reply With Quote
Old 04-05-2011, 10:23 PM   #52
NEKK5
NEKK5's Avatar
Nice looking blazer. Getting ready to swap out my 44s for 60s myself. Quick question: I know you mentioned perch width on the rear 44s but did you have to do anything on the front 60?
So many projects, so little time.
NEKK5 is offline   Reply With Quote
Old 04-06-2011, 12:06 AM   #53
NW_Ryker
Cool truck Drunkbus. Any reason you went with a single pipe instead of duals?
NW_Ryker is offline   Reply With Quote
Old 04-06-2011, 09:52 AM   #54
Burt4x4
Burt4x4's Avatar
The D60 will bolt right in
Driveline shorting may be needed.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 04-06-2011, 10:00 AM   #55
washington72
It looks realy good
washington72 is offline   Reply With Quote
Old 04-07-2011, 12:02 AM   #56
drunkbus
New Member
drunkbus's Avatar
It's dual 2.5" into the muffler and then single 3" out. There isn't a lot of room under these trucks to run dual all the way back and keep everything tucked up nice and hidden.
drunkbus is offline   Reply With Quote
Old 04-07-2011, 12:06 AM   #57
drunkbus
New Member
drunkbus's Avatar
Handles fine. A little rough riding as most lifted trucks are but I've driven it a 100 plus miles on the freeway at 70 MPH with no problems. Would probably ride even better if I swapped out the bias ply tires for some radials.
Old 04-07-2011, 04:14 PM   #58
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I'm sure it would. My old 88 F-350 with 36" goodyears was a unique feeling changing lanes with bias plies.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
