Old 10-19-2010, 12:15 AM   #51
scotts62
One day...
scotts62's Avatar
Re: Project: Old Timer...
Not out there working on it?????
Scott
93 crew cab build
Project 62
Old 10-19-2010, 09:36 AM   #52
jwalk
What was I thinking?
jwalk's Avatar
O I will be trust me! Just waiting for the days to be longer. So I can make time.
Justin
'68 C/10 Custom Long wide bed
'78 GMC Sierra short wide
Project: Second time around...'68 short wide
http://67-72chevytrucks.com/vboard/s...d.php?t=423949
jwalk is offline   Reply With Quote
Old 10-19-2010, 10:01 AM   #53
ky_savage
Subscribed!! Great work so far.
ky_savage is offline   Reply With Quote
Old 10-24-2010, 04:37 PM   #54
jwalk
jwalk's Avatar
A little bit done this weekend. Got the rack notches welded in and the front dropmember bolted in (just loose).
Justin
Old 10-24-2010, 08:20 PM   #55
scotts62
One day...
scotts62's Avatar
Scott
93 crew cab build
Project 62
Old 10-24-2010, 09:32 PM   #56
jasonhall
jasonhall's Avatar
Any pointers on those rack notches?
jasonhall is offline   Reply With Quote
Old 10-24-2010, 10:25 PM   #57
jwalk
jwalk's Avatar
I marked the center of the notches. Then measured the 4.25 from the center of the forward crossmember mounting hole. Then the 2.5 down and just held the notch up to the frame. I outlined them and marked the bottom edge of each notch. Then ran a straight edge from one side to the other and marked the front and back of each notch. Then cut them out. I used a piece of square tubing and clamped the notches to it so they'll be straight with each other (look at my other project second time around). I hope that made since to you....
Justin
Old 10-24-2010, 11:25 PM   #58
soala70
soala70's Avatar
like the progress gonna hook on to see it completed
bogey5
soala70 is offline   Reply With Quote
Old 10-24-2010, 11:49 PM   #59
jasonhall
jasonhall's Avatar
Makes sence.. Looking at your progress helps me wanna get going on the front of mine..
Old 10-31-2010, 02:23 AM   #60
jwalk
jwalk's Avatar
Got a little bit done today or should I say yesterday. Pressed in the lower ball joints (a lot easier than the last ones I did.) Put the a-arms, bags, and spindles on. I need to buy a rack and some conversion axles. I think I'm going to buy some rotors for now, so I can get it rolling tell I can afford big brakes (if I'm still going that route?) Got a few other things put on (see if you notice...)
I cut the rear brace out and I needed something else to go back in there... so I had this tranny crossmember that I won't be using. I cut the trans mount off and smoothed it up and it worked perfect!
Justin
Old 10-31-2010, 02:35 AM   #61
jwalk
jwalk's Avatar
O yeah I also got a carrier bearing crossmember put in. Heres a couple more pics of it overall. Got a few more new parts to through in my stash from a fellow board member up north. Just a piece at a time.
Justin
Old 10-31-2010, 09:17 AM   #62
scotts62
One day...
scotts62's Avatar
Looking good as usual man
Scott
93 crew cab build
Project 62
Old 10-31-2010, 01:10 PM   #63
FnLow69
FnLow69's Avatar
looks good man...
FnLow69 is offline   Reply With Quote
Old 11-13-2010, 12:38 AM   #64
jasonhall
jasonhall's Avatar
Anything new?
Old 11-13-2010, 11:10 AM   #65
67cheby
67cheby
67cheby's Avatar
are the rear extensions on your frame the "Body Drop " ones ??
67cheby is offline   Reply With Quote
Old 11-13-2010, 10:29 PM   #66
jasonhall
jasonhall's Avatar
I did not see those... Thats bad a..
Old 11-13-2010, 11:04 PM   #67
jwalk
jwalk's Avatar
Naw man..... I haven't been able to work on it much. I've been pulling 12 to 17 hour days at work this past week and a half. Doing my job and then pulling some after hours work. I started a complete on a '90 chevy ext cab thats my dads.... so I have to get it done before I can do much to anything of mine.
I did take this weekend off and me and my little helper went out for just a little bit and installed my rack.... and we went to my grandpas to use a drill press to drill my spindles. Just couldn't use a hand drill... kept wanting to grab. I'll have to cut a little off the ends of the rack. I figured I'd wait tell it's rolling.
I bought another spotlight. Not for sure which one I'll run. I like the size of the first spot.
Justin
Old 11-13-2010, 11:12 PM   #68
jwalk
jwalk's Avatar
YES THEY ARE!......BUT, I'm still waiting on the fronts (I think there putting up a fight!). I'm sure he'll nip it in the bud pretty soon! I got the body and the bed mounts installed. Everything is nice as always!
Justin
Old 12-21-2010, 11:46 AM   #69
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Looks good 1st time I have seen the body drop mounts from nate..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-21-2010, 01:15 PM   #70
67chevy1series
67chevy1series's Avatar
so which one are you building
67chevy1series is offline   Reply With Quote
Old 12-21-2010, 03:05 PM   #71
jwalk
jwalk's Avatar
Eventually both.....I hope.
Justin
Old 12-31-2010, 09:32 PM   #72
mcbassin
Still Learning
mcbassin's Avatar
I don't know how I missed this one. Dang dude this is a sweet ride and project. Hey, what kind of gas tank are you gonna use? Subscribed!
mcbassin is offline   Reply With Quote
Old 01-01-2011, 05:20 PM   #73
jwalk
jwalk's Avatar
Thanks man! As far as gas tank goes...not for sure, something out back. I'll do a raised wood bed floor so I'll have room.
Justin
Old 01-02-2011, 12:53 AM   #74
scotts62
One day...
scotts62's Avatar
So.. what are you working on now..? Your as bad as me on keeping up with stuff
Scott
93 crew cab build
Project 62
Old 01-02-2011, 12:58 AM   #75
67chevy1series
why did you change your name and how?
