Old 12-07-2011, 01:12 AM   #51
baggedbigblock
Re: My Build: Home Depot Machine
My first attempt at bondo work. The deepest area is the thickness of the sheet metal. I ground down all the welds until flush and then filled with bondo. I built up more so I could sand it down, but damn it is tough to sand. I am going to do some more research on body work and try to save myself time and energy. I also test fit the new alternator, the other one didnt fit. I will paint this one once all the fab work is done. I also finished the rear fuel cell support, redid the rear axle and painted the rear back setup. Still more X bracing to do in the rear for shock mounts and the 2" rear blocks are still being mailed. I also test fit my gilmer drive setup and my new headers, and amazingly I can fit the steering rack in there!!!
needs a shorter belt
baggedbigblock is offline   Reply With Quote
Old 12-08-2011, 03:17 PM   #52
hopped up
hopped up's Avatar
Can't wait to see the seat And the wheels on there. Keep it up
hopped up is offline   Reply With Quote
Old 12-13-2011, 10:13 AM   #53
baggedbigblock
Still waiting on the driveshaft and shocks to come in. So this a free labor week.
Stripping pain down to bare metal.
just signed up to instagram so I am messing with the photo editing
Old 12-13-2011, 06:30 PM   #54
E911manager
Very nice build. Love the shift knob.. I remember a truck my brother had, Three on the tree with a 8 ball for the knob. It was so heavy that is would shift from 2nd to third just by pushing in the clutch. That part was cool everything else sucked..
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice
http://67-72chevytrucks.com/vboard/s...d.php?t=492640
E911manager is offline   Reply With Quote
Old 12-14-2011, 09:58 PM   #55
baggedbigblock
Thanks, My Lokar has a shift lockout so I am hoping I dont shift gears when hitting speed bumps!
Old 12-14-2011, 11:35 PM   #56
McMurphy
McMurphy's Avatar
Hehehe thanks for this!
Note to self:
Go easy on the bondo, or work the rest of your life sanding! LOL
You are looking good so far, your engine has my attention now too!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 12-18-2011, 11:17 AM   #57
protrash64
Resistance is Futile
protrash64's Avatar
BBB.......dont know what product you are using for body filler, but some are light weight and much easier to sand. For instance, Rage Gold as opposed to Rage.
I sometimes use a palm sander to get down to where I need to start hand sanding to save some time/elbow-grease.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 12-19-2011, 02:14 AM   #58
baggedbigblock
I am using regular bondo.
Before
After
Also I started the short bed process. 20" shorter by manana.
Old 12-19-2011, 11:28 PM   #59
baggedbigblock
Well I will keep this post short. Like 20" short!!!!!!
Truck has been shortened to factory shortbed frame and wheel base length. 8" out of the back frame 12" out of the frame before the back tires.
Boxed on the inside, vertical weld was were the battery tray was and will go back.
Rear shortened
Long bed
Short bed
Front of long bed
front shot of short
Engine is out for firewall finishing.
5 min job, will do more sanding and blocking later
Front and rear bumpers strpped to bare metal, etched, high build for now, then matte white next week
Old 12-20-2011, 12:09 AM   #60
E911manager
Nice work!!! Like'm low!!
Old 12-20-2011, 01:57 AM   #61
VA72C10
VA72C10
VA72C10's Avatar
NICE progress!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 12-20-2011, 04:30 PM   #62
McMurphy
McMurphy's Avatar
I just got some bondo this week, going to spread some mud this weekend!
Looking good man!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 12-20-2011, 07:08 PM   #63
baggedbigblock
Well I am no pro, but I hated the bondo so much that I went to a body shop supply store, spent about $280 but got everything to do it right. Sticky backed 180 & 320 paper, wax and degreaser, Rage Gold Extreme filler, etching primer, high build primer, better filler blades and mixing plate.
Old 12-24-2011, 02:19 PM   #64
baggedbigblock
Picked up some higher quality body work materials from a body shop supply store
Fvck Bondo, Rage Gold Extreme (under non retail name Smart)
Sanded down all my work and redid it.
The whole truck is being stripped to bare metal and dents filled, etching primer, high build primer, guide coated and blocked then painted a 2 stage flat black. It is taking forever to do. I should have soda blasted,but I knew stripping by hand would have no chemical reactions to the paint.
Old 12-25-2011, 08:57 PM   #65
McMurphy
McMurphy's Avatar
Coming along real nice man!
Your firewall really came out good.
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 12-25-2011, 10:34 PM   #66
Narxoleptic Customs
Coming along great! Firewall looks awesome but that toe-in is gonna ruin tires, lol...
Narxoleptic Customs is offline   Reply With Quote
Old 12-27-2011, 08:53 PM   #67
McMurphy
McMurphy's Avatar
Heyyyyy look at what I found at the bone yard this weekend !!!
I have no real use for it, but it was in great shape and was too good to pass up.
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 12-27-2011, 11:05 PM   #68
allaboutchevelles
allaboutchevelles's Avatar
firewall looks good. keep up the good work, keep the pics coming.
69 chevelle malibu, 64 C-10 shortbed
allaboutchevelles is offline   Reply With Quote
Old 12-30-2011, 10:40 PM   #69
baggedbigblock
Moar Moar Moar Sanding Stripping and body work. Mocked up fenders and had to due some trimming. Rear tires will be flush with rear rolled fenders but up front I already cut 1" from the fender. Any more and the hood wont cover it. Here are a few more pics. Stripping the whole truck to bare metal sucks!!!!
Wiring, reinstalling the drive train, and replacing rusted panels will be next. I pray 6 weeks and it will be done
Old 12-31-2011, 12:45 AM   #70
McMurphy
McMurphy's Avatar
I like your shop by the way !!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 12-31-2011, 02:53 AM   #71
C@rnut001
Looks good...keep it up and thanks for sharing updates
C@rnut001 is offline   Reply With Quote
Old 01-01-2012, 04:41 PM   #72
VeronikA
VeronikA's Avatar
Dope project! And very cool pics! Also love the place where you work. Good luck homie! Really looking forward to the final look!
VeronikA is offline   Reply With Quote
Old 01-01-2012, 04:45 PM   #73
coulter
coulter's Avatar
if you get all that done in 6 weeks you will be the MVP!!! lol great work so far!! starting to look really cool
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
coulter is offline   Reply With Quote
Old 01-03-2012, 01:19 PM   #74
baggedbigblock
Thanks guys! I ordered all the new sheet metal, Truck must have been parked on a slope on the passenger side is rusted. New rockers, 1 cab corner, front cab floor supports, 1 lower door patch, floor pans. Going to wait on the fenders for some $$$. Removed all the paint on the whole hood and cab, removed the windshield and its looks brand new in there. Was painting my steering rack when the hook broke and it fell on my windshield. Well the inside was milky white, so time to buy a windshield!
I haven't put the drive shaft back in, but I wonder is it possible to fit an X pipe under the truck? I have the tubular rear crossmember so I can pass the pipes through that.
One pic of me having fun stripping the last door.
Old 01-13-2012, 11:57 PM   #75
baggedbigblock
A few more pics. I modified the trans crossmember so now the front is 3/4" lower, if you look close from the pics before you can tell. More paint stripping and body prep. Going back Monday to finally work on new sheet metal, no more rust. The Firewall has been notched for the tires to clear, pics on that monday as well. Just a few more. May not look like much but there is 18 more hours in there.
Motor and trans go back in monday as well and install the rear lowering blocks to get it fully on the ground front and back.
Pics!
Satin brake booster and master
Heavy Metal!
