Old 01-13-2012, 05:40 PM   #51
_Ogre
_Ogre's Avatar
Re: Let See Seats On Your 55-59 Truck
these are out of an 07 ford fusion, did not like them sticking up in the back window.
i cut the backs down 6'' and removed the headrest, a friend recovered them in ultra suede
nice truck/interior Entourageguy
shop air compressor timer
Old 11-13-2012, 06:25 PM   #52
NEWFISHER
NEWFISHER's Avatar
I have read ( on a few forums) questions asked about " what to use when rebuilding a seat" This is just to document what I did to the frame/spings and build up with a cover pre cut and sewn ready to install.
I stripped mine down to the frame/springs, repaired any springs or bars that were damaged. I pulled/stretched all of the springs that had seen abuse over 60 years making sure that all of them looked even and square within thier individual area. I painted both halves of the seat-frame-springs then covered the bottom and back assemblies with burlap that I hog ringed to the spring retainer bars so it wouldnt slide around. I layed cotton batting over the burlap on the back portion and fit the cover. Anything thicker than the cotton will push you forward ( great for shorter people) I Stretched the cover around and hog ringed it down-forget about those factory clips, they tear the vinyl and are a p.i.a. rings work great. After the burlap secured to the lower section, I cut out a 2 inch slab of medium density foam and lightly glued it to the burlap with spray adhesive. Tossed the cover on, pulled the edges, hog ringed it on. I started in the middle of the seat and worked my way to the outsides both front and back of each seat halve together, pulled and ringed the sides last. Installed the base, slid it forward and installed the back. Slid it back and went for a ride....no bouncing, looks great ( some areas will relax a bit in the sun etc).
NEWFISHER is offline   Reply With Quote
Old 11-13-2012, 07:13 PM   #53
meter swinger
meter swinger's Avatar
Looks awesome. Nice work
meter swinger is offline   Reply With Quote
Old 11-13-2012, 07:39 PM   #54
ruby57
ruby57's Avatar
Originally Posted by Raymo View Post
I'm tired of sit'n on my weak spring pickup seat. Looking for newer seat choices. I guess I could rebuild it as the seat is in really good shape but can't find seat springs. The gentleman that had my 56 before I did was a little bigger than me so she's a little weak and a back killer after a 600 mile trip.
Lets see some of your seats with what they came out of.
Thanks,
Raymo
I don't know, Raymo, I've not taken mine on a 600 mile trip so can't say Ruby's bench seat is much better. -Doug
ruby57 is offline   Reply With Quote
Old 11-13-2012, 08:00 PM   #55
OrrieG
OrrieG's Avatar
Here's mine 07 Yukon third row with shoulder belts built into the seat.
OrrieG is offline   Reply With Quote
Old 11-14-2012, 12:14 AM   #56
Dan in Pasadena
Dan in Pasadena's Avatar
Originally Posted by NEWFISHER View Post
...This is just to document what I did to...a cover pre cut and sewn ready to install.
That looks SO good espcially consdering its on a stock seat. Who is the supplier of that presewn kit?
If it's as simple as you wrote I'll definitely being trying it if the price is reasonable. One quick question: the "cotton batting" you speak of; where'd you get it and how thick is it?
P.S. Is that a piece of matching vinyl, or paint on the door panel?
Dan in Pasadena is offline   Reply With Quote
Old 11-14-2012, 02:10 AM   #57
NEWFISHER
NEWFISHER's Avatar
http://www.ricksupholstery.com/CompletedTrucks.html
I also had them sew up a matching headliner and was $250 shipped for all 3 pieces. The door insert is hammerite spray bomb in a dark metallic gray not vinyl. The cotton batting is a really light and fluffy material that came on a roll from a local fabric/uphoulstery shop supplier. Its only about 1/2 mabey 3/4 but you can grab and pull it off the roll and make snowballs with it by wadding it up.
It really is simple but I had the same reservations too. Pm me and I can walk you through it or call you and explain it better than I type
Old 11-14-2012, 12:31 PM   #58
Dan in Pasadena
Wow. Thanks for the link. At the price you quote in definitely gonna try them. I expected little in the way of choice but I'm impressed with what they offer.
Old 11-14-2012, 12:54 PM   #59
mknittle
mknittle's Avatar
[QUOTE=NEWFISHER;5700824]I have read ( on a few forums) questions asked about " what to use when rebuilding a seat" This is just to document what I did to the frame/spings and build up with a cover pre cut and sewn ready to install.
may I add that you can make a plywood frame about 2 inches wide all the way around that screws into the bottom of the seat frame. this elimanates the hog rings witch are hard to get an even pull with.
With the wood strip you can staple the cover and get a nice even pull.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 11-14-2012, 01:28 PM   #60
NEWFISHER
NEWFISHER's Avatar
[/QUOTE]
With the wood strip you can staple the cover and get a nice even pull.[/QUOTE]
If your stapler is powerfull enough, it will shoot them directly into the lower seat pan also
Old 11-14-2012, 02:22 PM   #61
Dan in Pasadena
The staples won't just pull through and tear the vinyl/fabric? Interesting idea. I'm thinking the plywood would have to be at least 1/2-5-8" thick? Fairly close spacing on the bolts holding it to the seat frame(?)
Old 11-14-2012, 03:00 PM   #62
NEWFISHER
NEWFISHER's Avatar
The thin plywood is a great DIY. Shooting them directly into the pan requires a " webbing" or 1" seat belt type material to be sewn around the lower curtain and the staples secure through it. I had to do this on another truck when I couldnt get hog rings around any wires when the curtain/cover was too short to reach an area that would accept hog rings.
Pic stolen from another site, but shows the plywood technique
Old 11-14-2012, 07:05 PM   #63
mknittle
mknittle's Avatar
no hog rings will tear before staples will. I use staples on motorcycle and smowmoble seats. that is how most origanally were done. If you don't trust a stress point adda little 3w weather strip adhesive{good contactact cement}
Mark
My GMC build.
Old 11-14-2012, 07:06 PM   #64
mknittle
mknittle's Avatar
Yes that is exactaly what I ment.I think that belongs to Coralhead. It makes it so much cleaner lan stronger
Mark
My GMC build.
Old 11-14-2012, 07:17 PM   #65
mknittle
mknittle's Avatar
I bet by the end of next summer the cover will even out really nice. not that it dosent look really nice now it does.
Mark
My GMC build.
Old 11-14-2012, 07:21 PM   #66
NEWFISHER
NEWFISHER's Avatar
And the matching headliner installed at lunch, just need to trim the edge tonight.
Old 11-14-2012, 07:39 PM   #67
mknittle
mknittle's Avatar
looks great! sure makes a big difference.
Mark
My GMC build.
Old 01-24-2013, 07:40 PM   #68
starterman99
starterman99's Avatar
heres a late 80's seat in my 57
1950 5 window
starterman99 is offline   Reply With Quote
Old 01-24-2013, 08:30 PM   #69
NEWFISHER
NEWFISHER's Avatar
^^^comfy
Old 01-24-2013, 09:01 PM   #70
Choady
heres a photo of my factory seat and $20 worth of serape blankets.
A Sane Man in an Insane World
Choady is offline   Reply With Quote
Old 01-24-2013, 10:26 PM   #71
Dan in Pasadena
So the plywood is one piece? NOT four separate pieces, right?
Newfisher: I probably asked you this already but you just sprayed your door panel trim with metallic silver paint, right? That's what I did on my two tone door panels but I was just wondering. Pic of my door panel below.
Old 01-24-2013, 10:29 PM   #72
Dan in Pasadena
Attachment 1047527
In keeping with the Mexican blanket theme of your picture, I'll post this one. NOT mine, and I don't know if I'd do it, but I admit to REALLY liking it!
Old 01-24-2013, 11:16 PM   #73
NEWFISHER
NEWFISHER's Avatar
Choady....I'm a fan of the sticker
Dan.....4 seperate pieces of wood, easier to deal with. I've seen them screwd down and also through bolted then staple the seat material to the board. Hog ringing works just fine though. Throw away the c clips that the factory held the material with as they do more damage cutting the vinyl when installing them.
Yes, I'm a copy cat. I stole your metallic chrome bumper spray bomb technique. Pm me your paypal addy and I will tithe you the royalty
Old 01-24-2013, 11:38 PM   #74
butchp
Can you get me the paint code of that blue it just right.
butchp is offline   Reply With Quote
Old 01-25-2013, 12:26 AM   #75
Dan in Pasadena
... Pm me your paypal addy and I will tithe you the royalty
Oh, no charge. You couldn't afford it anyway - I think my ideas are priceless!
