#51 |
Re: M1009 with LQ9
Just read through your thread. Nice build.
I'm look at putting LS 6.2 in my 86 blazer. Any advise would be helpful. Looks like I will need motor mounts, a new crossmember, new fuel tank and sending unit for 87-91 blazer. Which fuel pump are you using, is it an in tank pump? I have a 700r4 so will I need an adapter to bolt it to the motor?
1986 K5 Blazer |
#52 | |
Re: M1009 with LQ9
#53 |
Re: M1009 with LQ9
No problem.
Things have changed some here too. Put an '07 5.3L/4L60E in it, almost have it done.
1986 K5 Blazer |
#55 |
Re: M1009 with LQ9
Thanks and yes
1986 K5 Blazer |
#56 |
Re: M1009 with LQ9
Nice truck, Teck! You should start up a build thread. Why the change of plans, jkade? Putting this drivetrain in another rig?
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
#57 |
Re: M1009 with LQ9
Changed because at the the time I could find a 6.2 I wanted, so I did the 5.3 just to get the swap worked out. As for the 4L60E I went with it because of the DBW, didn't want to change to cable gory to make the 700r4 work.
Here is a link to my build at CK5. http://coloradok5.com/forums/showthread.php?t=253165 Sometime I guess I should do one here.
1986 K5 Blazer |
#58 |
Re: M1009 with LQ9
#59 | |
Re: M1009 with LQ9
#60 |
Re: M1009 with LQ9
Anyone wanna buy it before I demod it? Fixing to pull motor and axles. I will take $7000 for it.
#61 |
Re: M1009 with LQ9
That's a decent price with all the trimmings. The road trip home would be a little long. Throw it up in the classifieds with some pics and a link to this thread.
#62 |
Re: M1009 with LQ9
i know this is old... but i have a question about the tank and the pump... can you explain what tank you are using and what pump setup? I am trying to get a 5.3L swap together on an almost non-existent budget....
"Live, Love, Build cool s***" Jesse Chapman, 2013 ![]() My Truck.. http://67-72chevytrucks.com/vboard/s...d.php?t=567219 |
#63 |
Re: M1009 with LQ9
tank and pump and sending unit from an 87 and after will work on a budget. If you arnt planning on putting any mods on it.
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) |
#64 |
I know the pieces fit
Re: M1009 with LQ9
I thought the newer stuff ran at much higher fuel psi than the old TBI?
#65 |
Re: M1009 with LQ9
it will suffice if you dont plan on any mods. which i figure he isnt since he is looking for a budget build.
