Old 06-09-2013, 12:53 AM   #51
68c10airstream
68c10airstream's Avatar
Re: LS376 / 480 With 4L80E
Go with a nippondenso gear reduction starter. Uses ball bearings for the armature (spins easier), it uses an adapter that allows indexing the main body just about anywhere, and the last detail that usually isn't posted is this; do you remember gm starters that just click, or do nothing hot? The nippondenso starters are wired this way; hot= less solenoid resistance= more amps draw, cold = more resistance, less amps draw. Gm is just the opposite= less amps draw when the engine is hot. So being able to index the solenoid away from the headers, and the nippodenso starter pulling harder hot versus cold, that's why i went with the nippondenso. Good luck, Brian F.
68c10airstream is offline   Reply With Quote
Old 06-10-2013, 09:48 PM   #52
BigShoe24
True Addiction
BigShoe24's Avatar
RCC
BigShoe24 is offline   Reply With Quote
Old 06-10-2013, 11:23 PM   #53
Bennett68C10
Bennett68C10's Avatar
Looks great
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 06-11-2013, 09:15 PM   #54
BigShoe24
True Addiction
BigShoe24's Avatar
Thanks, it's getting closer
RCC
Old 06-11-2013, 09:45 PM   #55
Bennett68C10
How much did you have to modify the cab floor to get that big ole 4L80E to fit?
Keith
66 Suburban
IG: bennett68c10
Old 06-12-2013, 10:16 PM   #56
BigShoe24
True Addiction
BigShoe24's Avatar
Pretty substantial, but I raised the tail shaft of the trans quite a bit so the motor sat more even.
RCC
Old 06-13-2013, 02:46 AM   #57
ripdog28
ripdog28's Avatar
Just make sure your driveshaft/ rear diff angles are acceptable while driving. Straight line can be bad. Here is some basic info if needed.
I really like the build so far.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 07-01-2013, 09:47 PM   #58
BigShoe24
True Addiction
BigShoe24's Avatar
Looking to by a set of the DD's VHX-1014's; anyone running them or have recommendations?
Thanks,
RCC
Old 07-02-2013, 01:28 AM   #59
mcmlxix
Collector of Projects
mcmlxix's Avatar
I just bought the carbon/red factory style setup for my 72' Blazer... not intalled yet but they look great... and you can add modules (compass/air temp, trans temp, EGT, PRNDL and others) Are you building a custom dash?
Rich
1972 K5 Blazer CST Click HERE
Old 07-02-2013, 10:39 PM   #60
BigShoe24
True Addiction
BigShoe24's Avatar
Just ordered a set; hopefully they'll be installed in the next few weeks.
RCC
Old 07-03-2013, 08:53 AM   #61
mej005
I have a set of the dakota digital VHX's for my 64-66 dash and they are awesome, especially for an ls swap. Setup was very easy to do, and all the adapters and sending units are there to mount them in whatever engine you have, and they have the modules to add just about whatever you want including the ODBII to run the gauges if you don't want to use the sending units.
mej005 is offline   Reply With Quote
Old 08-31-2013, 06:27 PM   #62
BigShoe24
True Addiction
BigShoe24's Avatar
So I've got everything wired and ready to rock. I'm adding fluids and am wondering if anyone could suggest what transmission fluid to use. I've read around a bit and it sounds like a Dexron 6 would be best but still unsure as to brand or if something else comes into play. I'm running a 4L80e.
RCC
Old 09-02-2013, 10:43 PM   #63
BigShoe24
True Addiction
BigShoe24's Avatar
Can anyone offer advice regarding oil priming? I read to pull the plugs and turn the motor over with the starter until I get oil pressure. I did this and am not getting any pressure. I also read that many times this method doesn't create enough pressure to get a reading and that the motor needs to start to get pressure. Any help would be tremendously helpful.
RCC
Old 09-04-2013, 10:37 PM   #64
BigShoe24
True Addiction
BigShoe24's Avatar
Sorry to keep posting but I'm not getting anywhere on the oil priming/pressure issue. I read of a few people putting something like 17 Quarts of oil in there to prime it and then drain and replace with correct amount. This seems a little ridiculous but I am getting a little worried about cranking on my motor multiple time without my gauges ever reading any oil pressure.
I'm sort of at a loss so any input would really be helpful. Thanks
RCC
Old 09-04-2013, 11:30 PM   #65
ls1nova71
ls1nova71's Avatar
Do you have a mechanical gauge or electric? If it's electric, make sure it isn't losing power during cranking and giving you no info. I have had to overfill an engine to get oil pressure before due to the fact that the oil pump is located up front of the engine, and with a completely dry pump, they can suck air rather than oil. Overfilling it submerges the pump in oil, so it can't suck air. 17 quarts sounds extreme though, I think I used 10 or 11, then drained it and put the plugs back in before starting.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 09-05-2013, 09:48 AM   #66
Jon01
Jon01's Avatar
Pop the sending unit and crank it. I bet you'll find that you're getting oil pressure but the gauge is switched off during cranking.
Jon01 is offline   Reply With Quote
Old 09-05-2013, 11:54 AM   #67
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I had the same problem when installing my "new" LY6 crate motor after cam change/removing VVT...even took it back out and pulled the pan to go over things. Finally took the advice of many and relied on the assembly lube and just fired her up. To my relief the oil pressure came up almost instantly.
If its a used one that's been sitting for a while there's no assembly lube to save it....so:
GM has a priming kit that's expensive I understand:
or if you see yourself doing more LSx swaps buy this for $79.95:
https://www.mdrtuning.com/content/x-...p-priming-tool
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 09-08-2013, 12:13 AM   #68
BigShoe24
True Addiction
BigShoe24's Avatar
So I finally got oil pressure! I also turned the motor over and got it to fire several times for 2 to 5 seconds but it kept quitting on me. Any ideas? Everything sounds good for those initial few seconds and then it just shuts off. I'm going to make sure all the wiring is good and my grounds are clean but other than that I'm not really sure.
As always, thanks.
RCC
Old 09-08-2013, 12:18 AM   #69
Last_Paladin
As always, thanks.
What tune do you have on the computer? VATS still enabled?
Last_Paladin is offline   Reply With Quote
Old 09-08-2013, 01:08 AM   #70
ls1nova71
ls1nova71's Avatar
I agree, sounds like VATS....
Old 09-08-2013, 10:00 AM   #71
BigShoe24
True Addiction
BigShoe24's Avatar
I purchased a complete harness from Speartech. After reading about VATS I would be surprised if that's what it is, or rather frustrated.
Any other thoughts? I'll keep at it and maybe it'll fix itself, lol!
RCC
Old 09-08-2013, 10:07 AM   #72
Last_Paladin
Harness doesn't mean they touched the computer. Did they do a tune on it? Why don't you tell us a few things, like is this a speed density tune, MAF with 02's, what?
Let's check the basics then: Do you have spark? Do you have fuel/fuel pressure? All the gauges reading correctly? All the senders there?
Do you have more than 11.4v in the battery? Is the alternator charging? Have good oil pressure?
Old 10-20-2013, 08:02 AM   #73
BigShoe24
True Addiction
BigShoe24's Avatar
Well fortunately it turned out to be from me running it with straight headers and no exhaust. I guess the ECU was making it run rich due to no back pressure and an inaccurate reading on the O2's.
Now on to the getting the power to the ground. What type of drive shaft are you guys running? My 4L80e came with a bolted on yoke and I am wondering if this can simply be unbolted to provide for a slip yoke style set-up?
Thanks,
RCC
Old 11-11-2013, 10:08 PM   #74
BigShoe24
True Addiction
BigShoe24's Avatar
So I believe I've found a good option for a Drive Shaft... Here is a link.
http://www.dennysdriveshaft.com/p136..._and_slip.html
RCC
Old 11-11-2013, 10:09 PM   #75
Jon01
Jon01's Avatar
Any driveshaft shop should be able to set you up but that seems reasonably priced.
