Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Suspension > Suspension Marketplace
Old 12-27-2012, 07:55 PM   #51
way2lo2
way2lo2
way2lo2's Avatar
Re: 13" and 14" Corvette Brakes for C10's
I've got nothing in a 13" single piston sorry
Dealer for Billet Specialties, Ridetech, Airlift, Vintage Air and others. Feel free to call, email, or PM for a quote.
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Way2Lo2@aol.com <----also my paypal
http://www.hubgarage.com/mygarage/way2Lo2
way2lo2 is offline   Reply With Quote
Old 12-27-2012, 08:38 PM   #52
skorpioskorpio
So what are the sliders in the first post, dual piston?
skorpioskorpio is offline   Reply With Quote
Old 12-27-2012, 08:48 PM   #53
way2lo2
way2lo2
way2lo2's Avatar
2 and 6 for the fixed calipers
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 12-27-2012, 09:48 PM   #54
skorpioskorpio
2 piston sliding or 6 piston fixed, correct?
Just looking for a good braking solution that if I decide to service brakes I can order parts on Monday and be doing them by Sunday without having to worry whether a single supplier has the parts in stock at the time.
Old 12-27-2012, 10:29 PM   #55
way2lo2
way2lo2
way2lo2's Avatar
yes, thats correct the standard c5/c6 stuff is on the shelf in 99.9 percent of autoparts stores today, so you should be able to buy parts sunday and service brakes sunday, not sure about the hawk stuff but believe it shouldn't be that hard to come by as it fits 1997-2016, over 15 year span of the same parts used
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 12-30-2012, 01:34 AM   #56
xtreamtoys
xtreamtoys's Avatar
Hi, Can this be used on the CPP Modular drop spindles? They are made for a bolt on bracket for the caliper. I need to keep my front end narrow for fender clearance. If so how much for the 13" 6 lug.
Thanks Tony
xtreamtoys is offline   Reply With Quote
Old 12-30-2012, 04:45 PM   #57
way2lo2
way2lo2
way2lo2's Avatar
Thanks Tony
I have not tested them on any spindles but our modified McGaughys.
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 01-02-2013, 12:55 AM   #58
wraprail
wraprail's Avatar
Did you ever come up with anything for the 2004-07 Cadillac CTSV Brembo caliper? (which is the same front and rear as the current Camaro is using) So much nicer than that sliding vette 2 piston.
wraprail is offline   Reply With Quote
Old 01-02-2013, 08:35 AM   #59
way2lo2
way2lo2
way2lo2's Avatar
If someone wants to send their caddy parts, I'll do the R&D for free if they buy the spindles,brackets and hubs, about $600
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 01-02-2013, 07:59 PM   #60
jimmydean
jimmydean's Avatar
If I end up with a set of the CTS-V brakes, I would love to send them to you for a mock up. Otherwise I will likely be buying your C5 setup sans calipers. I love this setup.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 06-07-2013, 06:54 PM   #61
Jonboy
Slots go on anything!
I have a pair of the new Camaro Calipers. If these will work, let's make them go.
Old 06-08-2013, 10:22 AM   #62
way2lo2
way2lo2
way2lo2's Avatar
I'm sure we can make something work if you want to send one up
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 06-10-2013, 05:56 PM   #63
Jonboy
The camaro calipers are the same as the Cadillac ones, right? Send me the address where they need to go and I will get it out this week.
Old 06-11-2013, 09:26 AM   #64
wraprail
wraprail's Avatar
If you make the 2004-07 CTSV front 4 piston calipers work (which are the same as the Camaro SS) then the 2009-13 CTSV 6 pistion calipers will also work.
Only change is a larger (14mm) mounting bolt.
The Cadillac uses a 14" rotor that is thicker than the corvette.
I have a set of cadillac rotors if you need or want any measurements
Old 10-08-2013, 10:15 AM   #65
68 Four on the Floor
68 Four on the Floor's Avatar
Im sure youve answered this somewhere on here but what can you do for a 13 inch 6 lug set up? redrill the rotors i assume but what about the hubs?
68 Four on the Floor is offline   Reply With Quote
Old 10-08-2013, 10:33 AM   #66
skorpioskorpio
Do remember that it takes at least a 17" wheel and maybe even 18" to clear a 13" rotor and caliper, so if you are thinking 6 lug to still use stock wheels, that isn't going to happen. I have 13.5" Z51 Corvette brakes and they clear my 18s by not much more than 1/8th of an inch.
Old 10-08-2013, 11:20 AM   #67
way2lo2
way2lo2
way2lo2's Avatar
I'll have to check the pad on the rotor but I'm thinking it shouldn't be a problem
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 10-10-2013, 07:44 AM   #68
Ive got the clearance I think
Old 10-30-2013, 10:37 PM   #69
JustN
id like the cts/camaro set up if ever get it
JustN is offline   Reply With Quote
Old 04-17-2014, 02:06 AM   #70
slimneverdies
slimneverdies's Avatar
Are these spindles the for the 1" rotor or the 1.25" rotor??
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
Old 04-17-2014, 08:49 AM   #71
way2lo2
way2lo2
way2lo2's Avatar
Originally Posted by slimneverdies View Post
are these spindles the for the 1" rotor or the 1.25" rotor??
1.25
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 07-13-2014, 09:29 PM   #72
sama lama
Could the bracket caliper mounting holes be moved out 1/2 inch. That should be enough run a 355mm rotor with a c6 2 piston caliper. Another company does it and calls it 355 hybrid kit for 4th gen f bodys. I think the rotor offset on 325mm and 355mm rotors are the same. Just a thought I have a set of zo6 wheels 18x9.5 so bigger brakes the better.
sama lama is offline   Reply With Quote
Old 08-30-2014, 11:26 AM   #73
low69chevy
low69chevy's Avatar
Post Re: 13" and 14" Corvette Brakes for C10's
Okay so how much would one of these kits cost me in a 6x5.5 complete and how much would it be if i buy the calipers in the 14" z06 style for the front of my 69 c10 thanks in advance, leo
low69chevy is offline   Reply With Quote
Old 08-30-2014, 01:27 PM   #74
skorpioskorpio
I'm just curious why you would go to all the effort of converting to an already expensive to maintain multi pad stationary caliper Z06 brake system and cripple yourself with custom drilled rotors?
In the long run it would be cheaper to just convert to the 5x4.75 bolt circle.
Old 08-30-2014, 01:51 PM   #75
low69chevy
low69chevy's Avatar
Your right but there's an explanation to that and that is that I already have the rear wilwood brake kit and the raceline wheels 20x12 and 20x8.5 in the front so I already spent some money on the wheels etc so I would have to sell everything and more than likely lose money I thought it was doable cause like on the nbs trucks (ss ) etc they use these z06 corvette calipers with a bear 15" rotor and has the same 6x5.5 bolt pattern as my 69 c10 and my 06 silverado I'll try to find a link so you can see what I'm talking about. Thanks, leo
