12-11-2011, 06:18 PM | #51 |
Re: Sacto67 Build diary
The truck sat for 11 years before I bought it a few months back. It has new fuel lines, new fuel pump, a new HEI distributor, new plug wires/plugs, and the carb was rebuilt. It will idle but will not accept throttle backfiring through the carb and then quitting. I would love to keep this truck but without knowing why it will not run to fix it and with no funds to replace the engine with a V8 . It is a base model truck, 3 speed manual on the column, 4 wheel disc brakes, and no power steering.
It has the normal rust spots for the truck but it is complete. I bought an entire front sub-frame from a 84 Suburban which came with Bell Tech drop spindles, lowering springs, and shocks. The sub-frame has the power steering box, sway bar, and I have a power steering pump for it. I have the front brake lines and proportioning valve from the burb too. I have a power brake booster, pedal assembly for converting it to an automatic, and an automatic cross member. I bought a seat from a 2004 Chevy truck which has the shoulder seatbelts. It is two buckets with the jump seat in the middle. These are all thing that come with the truck but are not installed. The original seat was reupholstered before it was parked 11 years ago and is in great shape besides needing a good cleaning. I stripped the interior when I first got the truck so the cab floors are bare. I also stripped the rotted wood from the bed and it all needs replaced. Anyways this is a great short bed project truck with a lot of potential.
1968 Chevy SWB stepside original USAF truck http://67-72chevytrucks.com/vboard/s...d.php?t=483462 Last edited by 70cst; 12-17-2011 at 01:00 AM. |
12-16-2011, 09:27 PM | #52 |
Not for sale..........................
1968 Chevy SWB stepside original USAF truck http://67-72chevytrucks.com/vboard/s...d.php?t=483462 |
12-16-2011, 09:40 PM | #53 |
67-72 parts collector,…
Did you sell this truck?
12-16-2011, 10:56 PM | #54 |
Nope wife decided she wanted to let it sit around not running for a few more months. This WAS supposed to be my daily drive but now we are just gonna let it sit and be down a car.
12-19-2011, 07:12 PM | #55 | |
'69 Chevy SWB
Sounds like good news to me! I say hop on CraigsList and find a decent lower mileage small block and drive the wheels off of it.
Matt '69 Chevy SWB Fleet, Primer Black; Project No Name '06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold '08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!! '99 Dodge Dakota R/T, Intense Blue; DD, Sold Quote:
12-20-2011, 10:05 AM | #56 |
this truck was for sale on CL last week..... so are you selling it?
12-20-2011, 11:35 AM | #57 |
At the risk of sounding sarcastic..................
And, yes it was on CL last week.....but now it's not.
12-20-2011, 04:12 PM | #58 |
New to the board as of yesterday. Hello all. Don't want to steal anyones thread so I would like to know how to start my own as I need some help with back spacing for a new build. Thanks
02-23-2012, 02:54 PM | #59 |
So I have the hook up on a 12K mile 350 sb and 350 trans, exhaust, column, etc. but I have to wait for my taxes. In the mean time after talking with a few people I think the issue with the 292 is a vacuum leak. It makes sense since the timing is good before thottle is added and then backfires.
I replaced the vacuum lines already and the issue is still there. What are possible other areas for vacuum leaks?
03-17-2012, 07:28 PM | #60 |
425hp409
A vacuum leak will be more noticeable at idle, causing the engine to run rough. After reading all that you have done to the truck, I am leaning towards a valve problem or camshaft problem. The camshaft may be nearly flat on one lobe for an exhaust valve, which will let it idle OK, but then backfire on acceleration by not letting the exhaust gasses exit the cylinder quickly enough before the intake valve opens. I would suggest that you suck it up and take it to a mechanic and pay him to diagnose it once and for all and quit spending money on replacing parts that may not be needed.
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette Last edited by 425HP409; 03-17-2012 at 07:29 PM. Reason: Extra |
03-17-2012, 07:33 PM | #61 |
425hp409
If you take the six cylinder out of the truck, please keep all the Smog pump stuff with it as it is hard to come by. I am sure that someone would want it.
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
03-17-2012, 07:43 PM | #62 |
Thanks for the suggestion. I'm currently waiting for my tax return, then the motor will be removed and sold. Heck, I guess I could just post it for sale now........
05-02-2012, 01:49 AM | #63 |
Progress.......last week I pulled the new front crossmember apart for rebuild in preparation of getting the new engine and transmission.
Before picture:
05-02-2012, 01:51 AM | #64 |
Seeing how the tires on the truck are almost shot and the bolt pattern is soon to change I got some new shoes for the truck as well.
20" Coys
05-02-2012, 10:23 AM | #65 |
67cheby
nice upgrade !
05-05-2012, 10:24 AM | #66 |
I have a 68 partially disassembled if you would like to look at a xmember switchover.
68 Chevy l/b, 4 whl disc in the foothills of No Calif Last edited by fleetimus; 05-05-2012 at 10:35 AM. |
05-05-2012, 10:36 AM | #67 |
Thanks for the offer. I'll contact you if I need to check it out.
09-26-2012, 03:25 PM | #68 |
Pulled the engine today.
11-26-2012, 04:12 PM | #69 |
Front frame is ready for a good cleaning and paint.
11-26-2012, 04:17 PM | #70 |
Man of Mini-Talents
Glad you kept it.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
11-26-2012, 06:01 PM | #71 |
2007 VW GTI - SOLD, 2013 Ram 1500 Crew Cab Hemi 4x4 - TRADED (POS), 2006 Silverado 2500 Dirtymax, 2010 Kawasaki ZX-10R (wrecked), 2006 SV650, 2015 ZX-6R 1968 C10 CST LWB "..... Long beds are like the slightly chubbier sisters to the hot chick, still cute with a lot more to like. hahahaha!" - OrtegaMotor |
01-15-2013, 11:01 PM | #72 |
Yup, I'm glad I kept it. :-)
Finally had some time to put so work in on the project today. About 47% prepped for the cross member.
02-25-2013, 04:14 PM | #73 |
Finished up the driver's side rail and installed the subframe. It's sitting on all 4 tires for the first time in months.
02-25-2013, 04:21 PM | #74 |
Man of Mini-Talents
Progress!
Pretty fancy jack stands i must say.
02-25-2013, 04:41 PM | #75 |
Haha, that's how I roll. Unfortunately my other jack stands have been under another project for about 4 years.
