Old 07-30-2012, 12:20 PM   #51
Mikec10
Mikec10's Avatar
Re: bags on stock LCAs
Well i ordered everything i need besides a compressor, what is the basic minimum compressor that i can run the d2600s with and a 3gal tank?
can i use a max of 130psi working compressor? or do i need a max of 150psi?
note its only for the front 2 d2600s
Cause i was wondering if 1 vair 100c would be fine and then eventually upgrading to 2 100cs, or should i just get a vair 380c? im trying to keep this a budget build that's why its taking so long, (in college lol)
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears.
Mikec10 is offline   Reply With Quote
Old 07-30-2012, 02:11 PM   #52
tubbedII
needs more $$$
tubbedII's Avatar
Make sure you plan out spots for 2) 3 gallon tanks if you plan on bagging the rear down the road. I think you should go with the biggest compressor you can afford like the 440 or the 380 at the minimum. I hate waiting on the tank to fill and the comp to turn off. Those 2600's are big bags and like a lot of air...
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 07-30-2012, 02:58 PM   #53
king-918
king-918's Avatar
Viair 444
king-918 is offline   Reply With Quote
Old 07-30-2012, 05:06 PM   #54
Mikec10
Mikec10's Avatar
vair 444 it is, might aswell do it right once
Old 11-25-2013, 10:27 PM   #55
Chrisxeasy
Chrisxeasy's Avatar
Does anyone have photos of the upper bolt on plate installed?
Chrisxeasy is offline   Reply With Quote
Old 11-26-2013, 11:09 AM   #56
PBFAB.COM
PBFAB.COM's Avatar
Here is a pic of our upper bag plates installed....
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
