Old 05-26-2013, 07:17 PM   #51
OrrieG
OrrieG's Avatar
Re: 59 Panelmania
Build is looking good. Check your calipers to make sure the bleeder is on the top. I could not tell from the photos but it looked like it might be on the bottom. They are interchangable from side to side, I found out the hard way.
OrrieG is offline   Reply With Quote
Old 05-27-2013, 02:04 AM   #52
arturo7
arturo7's Avatar
Re: 59 Panelmania
Thanks, Orrie. I'll check that out.
ever forward
build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542073
arturo7 is offline   Reply With Quote
Old 06-09-2013, 01:09 PM   #53
arturo7
arturo7's Avatar
Re: 59 Panelmania
You are correct, they are switched. Guess I should have paid attention to the R and L in the castings. What a kanucklckehead...
ever forward
Old 06-14-2013, 10:48 AM   #54
arturo7
arturo7's Avatar
Re: 59 Panelmania
Haven't done a lick of work on the truck this week. I've been obsessing on a new axe. New to me, anyway. It's an early 60's Harmony tenor guitar.
ever forward
Old 06-16-2013, 08:32 PM   #55
arturo7
arturo7's Avatar
Re: 59 Panelmania
Assembled the rear brakes and installed the rear axle.
I was having an issue with one of the hold-down pins, just couldn't get the spring compressed enough to get the retainer cup in place.
I even made a special tool:
Then I found the problem. Doh!
ever forward
Old 06-17-2013, 01:33 PM   #56
OrrieG
OrrieG's Avatar
Re: 59 Panelmania
Old school brake spring stretchers have a round on one handle end that lets you compress and turn the 1/4 turn in one motion with one hand so you can hold the pin head from behind with the other hand.
Old 06-17-2013, 04:01 PM   #57
Russell Ashley
Russell Ashley's Avatar
Re: 59 Panelmania
That round end on the tool shown is for removing and replacing the return springs. This is the tool you use on the hold down springs. This is from Summit and well worth the $12.97 price the first brake job.
Russell Ashley is offline   Reply With Quote
Old 06-17-2013, 11:50 PM   #58
arturo7
arturo7's Avatar
Re: 59 Panelmania
Thanks guys. I ended up buying a the tool in order to get the shoe springs installed.
ever forward
Old 06-18-2013, 01:26 AM   #59
OrrieG
OrrieG's Avatar
Re: 59 Panelmania
Darn, I've been using it wrong for 45 years...
Old 06-18-2013, 02:15 PM   #60
_Ogre
_Ogre's Avatar
Re: 59 Panelmania
not wrong, just under utilized
i use it for both purposes; unlocking the washer and installing springs
shop air compressor timer
Old 06-18-2013, 02:35 PM   #61
arturo7
arturo7's Avatar
Re: 59 Panelmania
Speaking of tools, I just tallied that column in my project spreadsheet. Yikes! It's more than I paid for the truck!
ever forward
Old 08-02-2013, 02:30 AM   #62
arturo7
arturo7's Avatar
Re: 59 Panelmania
What a day. Took all afternoon and part of the night to do a couple hours worth of work. Started with a bolt mishap that led to the motor falling off the engine stand. Fortunately, the fall was broken by the balancer pulley. Then the bolts I had for the flywheel were to long, thus trip #1 to the parts store. This was quickly followed by trip #2 to parts store for the forgotten Loctite.
I'm happy to report that the flywheel did finally settle nicely into it's new home, followed by the clutch and the bell housing.
Next up were the front motor mounts. The diameter of harmonic balancer was a bit large for the mounts. I figured it would be less hassle to alter the mounts rather than replace the balancer. A little cutting wheel, a little black paint, voila; customer motor mounts. I'm optimistic that I left enough steel for the mounts to do their jobs.
ever forward
Old 08-02-2013, 10:21 AM   #63
Kim57
Kim57's Avatar
Re: 59 Panelmania
Looks like your getting there.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 08-02-2013, 07:52 PM   #64
OrrieG
OrrieG's Avatar
Re: 59 Panelmania
I had to modify my mounts like you did too, does not hurt at all, I drove it for 15 years that way.
Old 08-02-2013, 08:06 PM   #65
Denee007
Denee007's Avatar
Re: 59 Panelmania
what, no self adjusters for your brakes?
'72 Ford Bronco project(July 17 2021-?)
https://67-72chevytrucks.com/vboard/...d.php?t=828015
59 Apache (sold 6-25-2021)
67 Ford Mustang (re-restored after Harvey)
1968 Jeep Cj5 (2-8-2020 to present)
1992 Jeep Yj (8-17-20 to present) (Jurassic build)
www.Classiccarsandtools.com
Denee007 is offline   Reply With Quote
Old 08-03-2013, 01:28 AM   #66
arturo7
arturo7's Avatar
Re: 59 Panelmania
Self adjusters, what? Is there such a thing?
ever forward
Old 08-03-2013, 01:42 AM   #67
arturo7
arturo7's Avatar
Re: 59 Panelmania
Productive day.
Mounted the motor...
...and the tranny. Couldn't quite get it with the hoist alone, so I enlisted the floor jack as well.
A buddy said he'd roll by to see if I needed a hand. His timing was perfect, he showed up while I was taking a burrito break in between the motor and tranny work. He was however, able to snap a pic. Here's me, ready for a test drive...
ever forward
Old 08-03-2013, 02:10 AM   #68
Kim57
Kim57's Avatar
Re: 59 Panelmania
Looking good.
Although you're sitting on the wrong side.
Kim
My build thread
Old 08-03-2013, 09:23 AM   #69
Denee007
Denee007's Avatar
Re: 59 Panelmania
I love it! I love to be able to actually see a member! Thank you!
I installed self adjusters on my truck.
Old 08-03-2013, 01:44 PM   #70
OrrieG
OrrieG's Avatar
Re: 59 Panelmania
Originally Posted by Kim57 View Post
Looking good.
Kim
Aussie envy....project is looking good.
Old 08-04-2013, 10:10 AM   #71
_Ogre
_Ogre's Avatar
Re: 59 Panelmania
looks good arturo
been so long since i saw something stock
almost forgot what everything looks like
almost
Old 08-05-2013, 01:37 AM   #72
arturo7
arturo7's Avatar
Re: 59 Panelmania
I'm considering running the vehicle on CNG. My biggest concern is the size of the tank(s). I laid in the drive shaft and used a 12" lid to approximate a tank diameter. A tank that holds the equivalent of 9 gallons is roughly 13" dia X 60" long.
If I use a firewall mounted booster instead of the frame mount, I could conceivably fit 2 of these tanks under the body. However, I would need to run the exhaust outside of the frame. Not sure how that would work.
ever forward
Old 08-25-2013, 02:32 AM   #73
arturo7
arturo7's Avatar
Re: 59 Panelmania
Fabricated a dolly for the body. If this board ever fixes the gallery, I'll post some pics.
ever forward
Old 08-25-2013, 04:29 AM   #74
Ferrofil
Ferrofil's Avatar
Re: 59 Panelmania
Your not happy about the image uploads either?! :-)
Good to see that your making progress!
Ferrofil is offline   Reply With Quote
Old 09-29-2013, 11:35 PM   #75
arturo7
arturo7's Avatar
Re: 59 Panelmania
It's been a busy coupla few days...
moved the body to my side yard
erected a canopy/paint booth
mounted the body on a rotisserie
started removing the floorboards
ever forward
