Old 02-05-2013, 02:17 PM   #51
cjohnson6772
cjohnson6772's Avatar
Re: And so it begins......
Originally Posted by Jon01 View Post
Well, looks like you'll be getting some higher compression pistons out of the deal.
CL motor I assume?
Yeah cl. Looking for new short block first
cjohnson6772 is offline   Reply With Quote
Old 02-05-2013, 02:19 PM   #52
Jon01
Jon01's Avatar
Local guy or a business?
Small claims court could be an option. Usually a summons/notification of pending suit gets people's attention.
You could get a few hundred out of that shortblock to someone wanting to build a stroker motor.
Jon01 is offline   Reply With Quote
Old 02-05-2013, 04:16 PM   #53
cjohnson6772
Yeah. Just hate the thoughts of small claims. Got a lead on another short block maybe and some people interested in mine. Guy who sold it to finally returned my text. Siad he heard the engine run before he pulled it. I'm calling BS.
Old 02-05-2013, 04:21 PM   #54
Jon01
Jon01's Avatar
I would agree, unless it sat for an extended period outside before you bought it there's no way he heard it run.
Have you tried turning it over with a wrench? As crusty as those bores look I wouldn't be surprised if it was stuck.
Small claims may be a painful venture but at least you'll make him face the music and recoup your $.
Old 02-06-2013, 02:24 PM   #55
Jon01
Jon01's Avatar
Here's an LQ4 shortblock for $500 in Jersey.
http://ls1tech.com/forums/parts-clas...hortblock.html
Old 02-09-2013, 03:21 AM   #56
mopar250
mopar250's Avatar
That sucks! If it makes you feel better, I think everyone involved in this hobby has a story like that. 10 years ago I bought a 454 out out of a tow truck that I heard run with my own ears. He pulled it and 2 days later I came back to grab it. Looked the same, and I had no reason to believe he had switched it or anything shifty had gone on. Smash cut to 4 months later I'm throwing it in my truck and we fill the radiator full of water and...... it comes running out of the oil pan. Yea. Nice. Huge crack in the block. Never could track the guy down again.
mopar250 is offline   Reply With Quote
Old 02-09-2013, 08:59 AM   #57
no moa
no moa's Avatar
Yup happen to me to, but the whole truck wants what he said it was.
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 03-24-2013, 01:44 AM   #58
cjohnson6772
Ok so a lot has been happening since the last update. I wound update rebuilding the old block .030 over. Finally got it back from the engine shop. Got the truck in the shop this weekend and got the front end off. The old running gear out and put the new 370 ci and 4L80e in place. Gotta upload some pics for you guy.
To anybody running a 4l80e: my trans case is actually touching the lip on the bottom of the forewall slightly. How did you get around this? Bend the lip? What is the minimum clearance I should be comfortable with. Also: i only have approximately 3/8 clearance on top of the teams for basically it's whole length. Is that enough?
Old 03-24-2013, 01:25 PM   #59
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Mine is pretty close as well. I seem to recall doing some bending or trimming on that area...but not sure how much. I didn't grind on the trans case...but there are places it could be trimmed down a bit. I've fought with vibration issues but believe my setup to finally be fixed through re-adjusting pinion angles and getting a new d-shaft built. Seems I somehow warped/bent the other one (also new) to be .030 out in the center and .025 out on one end?
I think part of the solution is to get the tall trans hump...and 3/8" is all I have in areas...
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 03-25-2013, 09:45 PM   #60
cjohnson6772
Well I think I've found the solution. I think I'm going to swap my engine adapter plates to move the engine down 1/4 to 1/2. I am using the POL engine stands and trans x member. Just looked and the x member won't even work for a 4L80e. The yoke hits the trans x member. I think I'm going to cut it and "U" it. I just read through both your threads. Amazing truck. Whose trans x member did you use with your 85e?
Old 03-25-2013, 10:16 PM   #61
djracer
djracer's Avatar
Have you tested the header fitment?
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 03-25-2013, 10:17 PM   #62
thotfulspot
Hopefully my 2001 LQ4 will look better when I pull it apart. I plan on swapping heads and intake anyway so it's just the short block I have to worry about.
thotfulspot is offline   Reply With Quote
Old 03-25-2013, 10:32 PM   #63
cjohnson6772
No I'm really dreading it. I pretty much refuse to cut my frame and the engine is WAY far back. Back of driver head is maybe 2" from firewall. Excited about the way it is tucked up in there if I can get the headers to fit and the whole thing dropped down to alleviate the trans issue. Very pissed about the crappy POL tubular x member. Will NOT work with a 4L80e. Poor design imho. Wish I had bought CPP. Live and learn I suppose.
Old 03-25-2013, 10:40 PM   #64
cjohnson6772
Well that was my plan too
I hope you have better luck man. Mine is beyond snowballing at this point. I'm just throwing money at it hoping the problems disappear...
Old 03-25-2013, 11:03 PM   #65
thotfulspot
Mine looks cleaner and I saw the vehicle it came out of. I know, you've heard that before. I'm just going to use the short block and put L92 heads, LS3 intake, and a cam in it this year. Was planning on stroking it next year but I'll force myself to do it this year if I have too.
Old 03-26-2013, 04:51 PM   #66
68GMCCustom
Hey thanks. Dropping the motor is a good way of correcting the angle if you have the room to do it. I have the CPP x-member.
Kurt -
Old 03-28-2013, 11:35 PM   #67
cjohnson6772
Couple of questions. I went to change my power steering lines over on the pump tonight and I've run into an issue. I swapped the big adapter in the back of the pump with no problem, but the way the original 72 hardline is bent actually hits a boss on the side of the block and won't go in to the new pump. Which lines are you guys running?
I've also seen where some guys are using the new truck LS radiator hose. I'm using the factory 72 radiator and it seems that the hose is too small to fit. Are y'all using an adapter or am I missing something?
Old 06-29-2013, 11:25 PM   #68
cjohnson6772
Ok so I may have missed adding a few updates along the way, but here is current state:
