12-11-2012, 06:11 PM | #51 | |
Re: Can My 305 Tow?
12-11-2012, 07:04 PM | #52 |
Re: Can My 305 Tow?
hitch up and don't look back
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] 1999 k3500 crew cab dually 6.5tdi/4l80e |
12-12-2012, 12:08 PM | #53 | |
Re: Can My 305 Tow?
I'm sure we've all heard the term, "just because you can doesn't mean you should" But we all have to work with what we have, so long as it doesn't become a safety concern for yourself and others on the road, that's when I disagree. Much more traffic and faster speeds on the roads today than there was 40 years ago, just not as safe as it used to be. |
01-03-2013, 12:15 AM | #54 |
Re: Can My 305 Tow?
Well I found out what my little 305/350 combo can do earlier today. It can definitely do the pull but if theres any hills dont even try it unless your 305 is rebuilt and not ready to throw a rod like mine. It pulled nicely on the highway up to 65mph on flat land with no problem. My trans has been acting up for the last month and Im pretty sure todays little escapade has finished it off...
Long live SLIM ------------------ At least try to buy American |
01-03-2013, 02:17 AM | #55 |
Re: Can My 305 Tow?
305 will tow fine! i have a 305 in my dually and ive hauled tons of stuff. ive had the bed full of shingles with a duall axle dump trailer behind with 8 ft sides on it full to with plywood and shingles, drove up a steep hill at the dump and bad mud with all that 2wd. itll be fine, just pan ahead to brake and give your self room, just use common sense on distance. it works just not as fast lol good luck!
'82 c10 shortbed drag truck '82 GMC 3500 Dually DD scrap truck '55 Chevy 210 4 door sled '65 VW Bug Rat Rod |
01-03-2013, 05:48 AM | #56 |
Re: Can My 305 Tow?
Towed with my 85 and a vortec 4.3 with 4 barrel and duals. 3.08 rear. Towed a 3000 pound no brakes trailer, Volkswagen race car, tools and spare parts, up and down hills in Pa. Va. and to N.C. from Maryland. Just drove careful, left room to stop, and hoped it didn't rain. Once towed trailer with my daughters 5200 pound diesel Olds Toronado on it after she chased her boyfriend down the street and halfway through a house with it.
It strained, it grunted but it just towed away, just not fast. Lied to the toll taker on the Pa. turnpike. He said "Does that thing have brakes", and I replied, "Of course". Rain can kill you when towing. Once I flat towed the V W racecar with a towbar and V W vanagon to a local race, and it rained on the way back. I looked over to my left and saw the racecar going sideways next to my van. Slicks don't grip in rain. |
03-01-2014, 05:31 PM | #57 |
Re: Can My 305 Tow?
Is this not recommended cause of the size of the truck, size of the motor or a combination????
03-01-2014, 05:55 PM | #58 | |
Re: Can My 305 Tow?
that trailer has got to be a 11,000 GVW 28' enclosed that on its own weights 6000 lbs. The 1/2 ton standard wheelbase truck has a max rating of 7000 towing, a long wheelbase truck will pick up maybe a 1000 lbs over the SWB. I will not have an issue towing a trailer of 7000 lbs with my 74 C10 SWB. Understand that it has the big brakes front and rear and is a heavy half truck with a electric trailer brake controller. No way would I even consider a towing a car trailer with a car on it that did not have trailer brakes.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." Last edited by 406 Q-ship; 03-01-2014 at 06:02 PM. |
03-01-2014, 07:09 PM | #59 | |
Re: Can My 305 Tow?
Pulling this..... With this... With these wheels... Kinda of a mutt but I would be towing probably once a week locally.
03-01-2014, 11:57 PM | #60 |
Re: Can My 305 Tow?
Beyond brakes,suspension, and overall engine power, you have to take tire rating into consideration.
I foresee bad things happening if you do much towing on those tires. They probably do not have an acceptable load rating for what you want to do. |
03-02-2014, 01:01 AM | #61 |
Re: Can My 305 Tow?
I had a 86 K10 with a 305 4 speed and 3.08's. Caught a deal on a 10k home built equipment trailer (read HEAVY). It kind of wanted to be the leader of the convoy. Was better when the brakes got sorted out (brakes on both axles). Also it was real finicky with the tongue height. I put it behind my 93 K2500 and it made a world of difference. Did the 1/2 ton pull it, yes. Was it proficient, not really. A regular car trailer behind a 1/2 ton, yes, with due care. That's the key. The most important component in a towing situation is common sense. Think ahead.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
03-02-2014, 06:34 AM | #62 |
Re: Can My 305 Tow?
I may add my rear brakes on my 1985 C-10 and axle (3:70) came off a 1978 "Big 10" they are huge, 11 inch or bigger and I think 3 wide. I don't think the load rating on the tow vehicle tires make much difference, as the tongue weight of the trailer should not exceed 20% of the total towed weight.
It would be nice if everybody had a dually, but we don't. |
03-02-2014, 10:05 AM | #63 |
Re: Can My 305 Tow?
Those U Haul trailers have automatic brakes on them so armybyrd wouldn't have a problem hauling his car if he had a trailer like that. Uhaul won't rent you a trailer unless your truck is certified for the weight you are hauling. When I use my half ton I have to fib and tell them I am hauling a ford fiesta. If you know of a lighter car, that would be even safer, like a Mini cooper or Cobalt or something.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
03-02-2014, 10:11 AM | #64 |
Re: Can My 305 Tow?
this thread is odd. you guys do know that there where big rigs that made a 100 hp and had 6 bangers back in the day. ive pulled a car with a 4.3 v6 truck a heavy car at that. i pulled my 66 back with a 01 truck thats a 4.8 from indiana at 65-70 mph. car weighs 3800. your only pulling 5-6k with most cars or trucks on a trailer. now if you trying to jerk 10k around yes you want a hd truck. brakes i do like having but i can still go down the road without them. have many times before. a half ton is a 7k limit your 1-2k under that with anything but a real heavy truck or suv. no you dont need a weight dist hitch either for an open trailer either.
03-03-2014, 10:55 AM | #65 |
Re: Can My 305 Tow?
Like I said earlier I hauled a dual wheel car trailer and my daughters 5200# Olds diesel Toronado 100 miles back from Virginia where she had speared a house chasing her unfaithful boyfriend. At the time I had a 4.3 six in my '85 half ton with a turbo 400. If you're hauling a lot of weight you surely MUST plan ahead and hope no idiot pulls out in front of you.
03-03-2014, 10:58 AM | #66 | |
Re: Can My 305 Tow?
03-03-2014, 12:26 PM | #67 |
Re: Can My 305 Tow?
With a th350 transmission I'd watch the trans temps or maybe just go ahead and install a small cooler, it will benefit you in everyday driving. A th350 with any mileage on it is something to safeguard against hurting, they don't like much heat - it'll shorten it's lifespan.
