Old 02-14-2013, 03:27 AM   #51
69CST-V
69CST-V's Avatar
Re: 1951 Chevy / C4
Great work X.
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 02-15-2013, 10:58 PM   #52
xpickup
xpickup's Avatar
Re: 1951 Chevy / C4
Wheelie, Thank you. It makes it nice when you can just make it rather than buy the stuff. I was fairly easy to do.
99 to Life, Thank you. I will have to figure out the hours. I have them all wrote down. I too can not wait to see it with the body back on it.
4544speed, Thank you. Yes it should be a rigid frame.
oldman3, Thank you. I working on it. HAHA
69CST-V, Thank you.
I had off today so I got some more steel this morning. Then made up the templates so I could plasma cut the pieces out. It worked out great. I welded them all together then, so on Sunday I should get them finished fit and welded on the frame. Then cut out the old section of the frame. Next is to start mounting the rear end. Here are my latest pictures.
Shannon
xpickup is offline   Reply With Quote
Old 02-16-2013, 12:23 AM   #53
oldman3
oldman3's Avatar
Re: 1951 Chevy / C4
Those are some nice pieces, will be rock solid when your done, nice work....Jim
oldman3 is offline   Reply With Quote
Old 02-16-2013, 01:33 AM   #54
Homebuilt Hotrods
Homebuilt Hotrods's Avatar
Re: 1951 Chevy / C4
Sweet build as usual!
Garage Built
Homebuilt Hotrods is offline   Reply With Quote
Old 02-16-2013, 01:50 AM   #55
48 GMC BURB
48 GMC BURB's Avatar
Thumbs up Re: 1951 Chevy / C4
Shannon
Sweet work as usual
How's it feel building a airlume ? This thing will never leave the family!!
I'll be back in the States mid April.
I'll bring the motor & Trans up then.
I have the mastercylinder & booster from the donner vett if that will work.
The tank will need a GM sending unit & I'll have to check & see what the guys are using, a stock in tank pump or if their is a external in-line that will work.
Ken
48 GMC Burb
51 Chevy AD 3100/C 4 byShannon
74 Chevy P 10
48 Double Duty
04 SS Burb
01 Springer HD
48 GMC BURB is offline   Reply With Quote
Old 02-17-2013, 09:35 PM   #56
xpickup
xpickup's Avatar
Re: 1951 Chevy / C4
oldman3, Thank you. Yes, thanks to Ken, I now changed my mind on the frame on the 54. I love the lok and as you said it is rock solid.
Homebuilt Hotrods, Thank you.
48 GMC BURB, Thank you. I am glad it is staying in the family. It will be a great thrasher. Ok on the motor and tranny. I will have to check on the size of the vette booster and see if it will fit, but if so we can use it. Sounds good on the tank. Let me know on the pump and the sending unit for the gauges.
Today I put the notch in. I was rolling and hardly took any pictures. I cut some notches in the frame so that I could put the higher rear end notch in. Then welded it all in and then cut out the old. It worked out great. I rather do it that way so there is no worry on lining it up. I did put some temperary braces across the back and some going to the ground for some support. Nothing moved. Then cut out some fish plates to strengthen the joints. So soon I will be setting in the rear. I can not what to put the wheels on it and put it back on the ground.
Shannon
Old 02-17-2013, 11:29 PM   #57
99 to Life
99 to Life's Avatar
Re: 1951 Chevy / C4
lotta work there, lotta great work
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 02-18-2013, 12:51 AM   #58
oldman3
oldman3's Avatar
Re: 1951 Chevy / C4
Shannon, really like the way you installed that kick-up, then removing old section, fish plates really add to it, nice job....Jim
Old 02-18-2013, 01:07 PM   #59
98layinframe
98layinframe's Avatar
Re: 1951 Chevy / C4
Nice work on that kick up, clean and flows nicely with the frame shape.
91 s10 - bagged bodydropped 4", 350/700R4, narrowed reared, cantilever rear air bag setup
1951 chevy 3100 - in build/acquiring parts process. Have full C4 Corvette suspension front and rear, tpi 350, 700r4, 18" torque thrust II wheels
98layinframe is offline   Reply With Quote
Old 02-18-2013, 03:28 PM   #60
Larry Lindley
Re: 1951 Chevy / C4
very good on rear notch.
Larry Lindley is offline   Reply With Quote
Old 02-18-2013, 09:59 PM   #61
shadow1967
shadow1967's Avatar
Re: 1951 Chevy / C4
Nice Job!!
Build for my 1959 Fleetside...
http://67-72chevytrucks.com/vboard/s...d.php?t=518308
shadow1967 is offline   Reply With Quote
Old 02-19-2013, 01:21 AM   #62
48 GMC BURB
[QUOTE=xpickup;5895293]oldman3, Thank you. Yes, thanks to Ken, I now changed my mind on the frame on the 54. I love the lok and as you said it is rock solid.
Shannon
What kind of a friend would I be if I didn't point out that you deserve a KOOL pickup too !!
I plan to auto x it at Good guys & SCCA events, should be fun. We will see how much of the Vett stuff I can break !!
The more I see, the more metal envy I develop !!
Ken
48 GMC Burb
74 Chevy P 10
48 Double Duty
04 SS Burb
01 Springer HD
Old 02-20-2013, 12:35 AM   #63
shadow1967
shadow1967's Avatar
Re: 1951 Chevy / C4
Shannon
How long did it take you to weld the new pieces up? Thanks, I'm thinking of doing that on another project.
Old 02-20-2013, 09:11 PM   #64
shadow1967
shadow1967's Avatar
Re: 1951 Chevy / C4
What metal thickness did you use?
Old 02-23-2013, 09:54 PM   #65
xpickup
xpickup's Avatar
Re: 1951 Chevy / C4
Well it has been a while since I have been on here. I was sick as hell with the flu. Now I am finally feeling better. I will be back at it tomorrow.
oldman3, Thank you. It really does work out well doing it that way. It should be nice and strong.
98layinframe, Thank you. That was the plan. Keep everything nice and consistant looking.
Larry Lindley, Thank you
shadow1967, Thank you. The metal is 1/8 and it took 8 hrs to make the templates, plasma cut everything out, form the filler pieces, weld it all up, and grind it all up. It worked out great.
48 GMC BURB, Thank you. Fun, Hell yes! You better not break the rear in the truck. I did not know if you knew but that is a Dana 44, which is the horse power one. I know one thing I WILL have a frame like yours! And yes you are a good friend for letting me do this thing. I do seem to out do myself on each build. Boy I can not wait to do mine. The panel will never be finished. I have to keep at least one on the road while working on the other. Too many years on working on stuff and not driving anything.
Shannon
Old 02-23-2013, 10:33 PM   #66
Wheelie
Re: 1951 Chevy / C4
Hell ya, notch looks great. Keep it up!
My '59 Build Thread
Wheelie is offline   Reply With Quote
Old 02-24-2013, 09:28 PM   #67
xpickup
xpickup's Avatar
Re: 1951 Chevy / C4
Wheelie, Thank you.
Finally back in the garage. Cut and fit the rest of the small boxing plates and the welded them in. I also welded in the drivers side fish plates. Then after that check to see that everything was level and layed out the floor to set the wheel base and to check everything for being square. I used a plumb bob to check and set everything and then used chalk lines on the floor. A little secret is the use clear spray paint to spray over it so it does not blow away. That is if you have a ****ty floor like mine(not one with epoxy or painted). Everything checked out great. I set the wheel base at 117" so the rear wheel are centered in the wheel wells. I cut out the bat wing mounts and have it set up with them. Next is to make a fixture to go across the top if the frame and bolt through the spring holes to pull the outer axles up to ride height. Then I will make sure at ride height that it is where I want it. I am going to put a tube in to catch the nose of the rear and tie it into the transmission cross member. Then comes the 4 bar on the sides. I need to get new metric blots and make some crush tubes to put in the frame so they will bolt through it. I have to figure out the shock mounts next. But hopefully it will be a roller next weekend. Here are some pictures.
Shannon
Old 02-24-2013, 09:30 PM   #68
xpickup
xpickup's Avatar
Re: 1951 Chevy / C4
more
Shannon
Old 02-25-2013, 12:26 AM   #69
oldman3
oldman3's Avatar
Re: 1951 Chevy / C4
Looking good...Jim
Old 02-25-2013, 09:15 PM   #70
99 to Life
99 to Life's Avatar
Re: 1951 Chevy / C4
looking great, so how wide is that rear end? not sure if you posted that or not.
Old 02-25-2013, 10:08 PM   #71
Homebuilt Hotrods
Re: 1951 Chevy / C4
Wow you made quick work of that frame. Looks very nice.
Garage Built
Old 02-26-2013, 06:46 AM   #72
48 GMC BURB
Shannon
Glad to hear you'r feeling better !
The frame is sweet & looks like it's getting close to needing some tires n rims!
Man can they get pricey quick !
48 GMC Burb
74 Chevy P 10
48 Double Duty
04 SS Burb
01 Springer HD
Old 03-03-2013, 09:50 PM   #73
Wybrow
Re: 1951 Chevy / C4
This is easily my favourite build on here. Great work.
Wybrow is offline   Reply With Quote
Old 03-03-2013, 11:06 PM   #74
xpickup
xpickup's Avatar
Re: 1951 Chevy / C4
oldman3, Thank you
99 to Life, Thank you. I did not measure the rear from flange the flange. I do know that it is the narrower rear (earlier style) with the later style wheels. I measures outside to outside of the tires 68" which is narrow. The front with s10 rims on measures 69" which is fine. I will check and post the width on the rear.
Homebuilt Hotrods, Thank you .Yes I h ve been thrashing on it.
48 GMC BURB, Thank you. Yes feeling a lot better. You will need some different wheels. I will see if I can borrow Billys wheels to check the fit. I do love the look of the frame. I do not think I can give it to you! HAHA
Wybrow., Thank you . Glad you like it.
Well been busy with it . I layed out the floor and took a tube and mounted 2 plumb bobs on it to line up the rear. I now have it mounted in the frame. I made a rubber bushinged nose mount and tied it into the tubing. Then when I did the side 4 bars I use the factory brackets and made crush sleeves to weld through the frame. Then I reamed the 4 bar bushings to 1/2" instead of being metric. The bolts are grade 8 , which I always use for suspension stuff. I still have to fabricate the coil over mounts fo rthe outer hubs and the frame. That will be this week. I did put it back on its wheels because I had to see what it looked like. The rear wheels will be a couple inches higher. I am very pleased with it. Here are some pictures
Shannon
Old 03-03-2013, 11:08 PM   #75
xpickup
xpickup's Avatar
Re: 1951 Chevy / C4
more
Shannon
