05-02-2013, 08:31 PM | #51 |
Re: 1960-1962 Lower control arms
one more pic of the fancy bumper towing set up lol and i started to clean the frame where i was gonna notch more pics....
nOtHiNg LiKe ThE gOoD oLe ChEvYs.... |
05-02-2013, 08:34 PM | #52 |
i made a template for the notch to see how big i was gonna go and i got my notches all cut....
05-02-2013, 08:37 PM | #53 |
is gonna be a pita to get the welds inside the frame lol im gonna have to cut a little more from the top so i can get the torch in there and than brace it really good....
05-05-2013, 02:18 PM | #54 |
Great work bro !!! I know you did some more work on this bad boy this weekend .... any more pics ??
05-06-2013, 12:37 AM | #55 |
Great work! What kind of set up are you going to go with?
05-07-2013, 09:44 PM | #56 |
Glad I found out about this one!!! I'm watching both bro!!!!
Korwin 77 C10 Silverado Sharkbite LWB Build 67 Chevy C10 Frame Off 06 Dodge Magnum 2.7v6 aka swag wag! 2010 Honda Accord 2.4I4 DD aka Liquid Metal |
05-07-2013, 09:44 PM | #57 |
lol... yes this last weekend i got both of notches all welded up..... and i also welded up a cross bar to tie in the notches together here are some pics....
05-07-2013, 09:48 PM | #58 |
and one of the truck on the ground....
05-07-2013, 09:50 PM | #59 |
It's beautiful!!! Awesome craftsmanship at its finest!!! great job bro!!!
05-07-2013, 09:56 PM | #60 |
just in case some of you are wondering how the notches got welded basically the center section didn't get cut until the red lines and blue lines were fully welded so it could support the frame the blue represents the other side of the frame as if you were standing between the frame rails and the black was the last thing that got welded once the center section was cut and it was braced from the top of the frame.... and of course the yellow lines is the section that was cut off...
05-07-2013, 09:57 PM | #61 |
thanks bro means alot.....
05-07-2013, 10:03 PM | #62 |
thanks for following bro im jumping back on my 73 soonest im finished baggin this one..... im just bagging this one there is no bodydrop or anything crazy he's super happy with the way it sits but im sure he's gonna want to go lower so he may be back for the Z later lol...
nOtHiNg LiKe ThE gOoD oLe ChEvYs.... Last edited by luifer76; 05-07-2013 at 10:16 PM. |
05-07-2013, 10:08 PM | #63 |
are you talking about the rear set up? most likely we gonna run the bags where the stock springs go and weld bag plates up and down and make sure we center the bag to keep the trailing arm twisting to a minimun, modify the track bar, put some longer u bolts and we gonna add a 2 inch lowering block...
05-08-2013, 08:25 PM | #64 |
Nice Bro !! hey where in cali do you live . Im in el centro but got fam in vista !! do you do any side jobs .....????
05-08-2013, 08:44 PM | #65 |
im in Lancaster bro...
05-08-2013, 08:45 PM | #66 |
now and than i do depending on how busy i am at work...
05-12-2013, 10:26 PM | #67 |
need to update this thread..... here is the progress that was done this week a couple hrs each day after getting off work that's all i get since once it gets dark we stop i dont want to disturb the neighbors but thursday and friday my days off we went to town and got some serious work done.... pics coming up
05-12-2013, 10:30 PM | #68 |
he decided he wanted me to run the bags on the trailing arms where the stock spring goes and just add the lowering blocks to the rear axle which he's gonna do on his own time and he finally order the ubolts btw so here is what was done i welded some upper and lower round plates to center the bags i used the same bolt hole on the trailing arm from the factory..... also got a five gallon air tank...
05-12-2013, 10:33 PM | #69 |
we got the track bar modified and enlarged it a little bit and and all the air ride stuff installed i asked him what he wanted to do with the bed floor and he said cut the center section he said he wanted to have access to the air ride stuff in case he need it to repair/ replace anything so i said ok..... here are some pics of the truck on the street...
05-12-2013, 10:36 PM | #70 |
be careful what you wish for lol....
05-12-2013, 10:40 PM | #71 |
here is some with the bed still no lowering blocks once he puts them is gonna even better but he kind of likes the stance it has now....
05-12-2013, 10:42 PM | #72 |
couple more...
05-12-2013, 10:42 PM | #73 |
and this last pic he sent it to me yesterday evening after he picked it up from here now is his garage.....
07-10-2013, 01:06 AM | #74 |
you have some mad skills bro !!!
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
07-10-2013, 01:42 AM | #75 |
But Found Her 25yrs Later!
Thank you so much for documenting your work with all the pics.
I will be referencing this thread when I go to do my 65 that is on a 62 frame. Posted via Mobile Device
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
