Old 11-27-2016, 08:03 PM   #51
LockDoc
The Older Generation
LockDoc's Avatar
Re: Rear Axle Ratio Charts For 1967 - 1972 GM Trucks
Originally Posted by garyd1961 View Post
Thanks for posting this but I have a question. My axle code is TDE which just shows 3.07 gears. I thought my rear TDE was posi traction. The rear is not in the truck but if I lock one axle and the yoke in place the other axle will not turn. I thought this meant posi traction.
Use a floor jack and lift both rear tires off the ground. Spin one tire. If both tires turn the same direction you have posi if one tire moves forward and one backward you have an open rear end.
LockDoc
Leon
Old 11-27-2016, 08:52 PM   #52
garyd1961
LockDoc
The rear isn't in my truck but it turns one axle opposite of the other. I know it's an open rear now and I have been looking at an Eaton Truetrac. I plan to put the open rear in for now and to rebuild the one I'm taking out latter.
garyd1961 is offline   Reply With Quote
Old 11-28-2016, 12:51 AM   #53
fist5366
This might be a stupid question be where exactly do measure from to compare to the stock rear end . I can find a width online and I tried to measure but it's a pain cause it's in the truck.
fist5366 is offline   Reply With Quote
Old 11-28-2016, 12:56 AM   #54
LockDoc
LockDoc's Avatar
I believe it is from flanges where backing plates bolt on. It can be tough when they are still in the truck....
LockDoc
Leon
Old 11-28-2016, 02:36 AM   #55
fist5366
Thanks I'm just trying to figure out what it's out of. It seems wide but when I measured today it was pretty close to 60" which makes me wonder why it seems so tight. I was told it was out of a 76 blazer but now I have no clue, it is 6 lug
Old 02-13-2017, 01:39 PM   #56
5 Driver
If the truck has posi-traction, would it most likely be listed as an option on the SPID?
5 Driver is offline   Reply With Quote
Old 02-14-2017, 08:17 PM   #57
LockDoc
LockDoc's Avatar
Sorry, I missed this somehow....
Normally they would be an option and listed on the SPID, unless it was added later by someone. The posi rears also had a plastic tag on the fill plug with instructions to use positraction fluid in them. That could be missing though.
LockDoc
Leon
Old 02-14-2017, 08:29 PM   #58
5 Driver
LockDoc
No apology needed.
Thats what I thought...wishful thinking I guess.
Thanks,
Old 07-21-2018, 11:41 AM   #59
JDSurge
Thanks guys for showing the axle charts. My Blazer was a RAW, so 3:73 is the axle ratio but what about the numbers stamped to the right of the RAW? Mine is W (then what looks like the upper part of a '3' ) 47
So W 347 ?
Thanks.
JDSurge is offline   Reply With Quote
Old 11-26-2019, 09:41 PM   #60
davischevy
davischevy's Avatar
Here is the stamp on my rear axle. RAY for 3.07 open. I'm going to guess it was built on the 251st day of the year, 1st shift.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 11-26-2019, 09:48 PM   #61
LockDoc
LockDoc's Avatar
Larry,
I always thought it would be the 25 day of the 1st month. Don't know for sure.
LockDoc
Leon
Old 11-26-2019, 09:58 PM   #62
davischevy
davischevy's Avatar
Where is Keith Seymore when we need him?
other Larry
Old 11-26-2019, 11:19 PM   #63
jcwren
Having a RAY code, that's a 1972 KE 10 3.07 open rear end. There's a letter in front of the 251. It's very faint, and looks like a W, which would mean it was built in Warren, MI. 251 would be September 7th (the Julian date, which is the day of the year), and the 1 is the 1st shift.
1970 C10 LWB Stepside
1971 Dodge Dart
1993 Buick Roadmaster Estate Wagon
jcwren is offline   Reply With Quote
Old 04-21-2021, 09:35 PM   #64
Romo912
My 67 gmc starts with a HA
Romo912 is offline   Reply With Quote
Old 04-21-2021, 10:47 PM   #65
LockDoc
LockDoc's Avatar
That would be the 3.73 ratio non-posi then.
LockDoc
Leon
Old 06-08-2021, 06:23 AM   #66
OregonNed
OregonNed's Avatar
Interesting and helpful thread. I'm currently having the rearend in my '68 rebuilt due to many many issues of wear and the cross pin bolt was broken and barely hanging on. I have not sought out the stamped code on the axle housing, but It does have a 3.07, open carrier in it. Along the ring gear are the numbers to confirm the ration, as well as "72" stamped on it. Would this indicate gear possibly transplanted from a 72?
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 06-08-2021, 09:23 AM   #67
LockDoc
LockDoc's Avatar
I don't think they were date coded but I'm not 100% sure about that.
LockDoc
Leon
Old 06-08-2021, 12:01 PM   #68
70cst
70cst's Avatar
Great info ... Thanks
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 08-31-2022, 03:42 PM   #69
'68OrangeSunshine
'68OrangeSunshine's Avatar
I have saved these from different places so they don't match each other. I saved them as image files and they are all different resolutions and sizes. They really need to be typed into a document file so the size and style of font matches on all of the charts. Unfortunately I don't type good enough to do that so we will try it this way. I just hope they are all readable with the image size restrictions for the board. I think I have them sized close to the maximum that the board allows. Disregard the C14 designation in the '67 chart, it should be C10.
In case someone is thinking Photobucket or some other photo hosting service, I won't do that for two reasons. One, I am not going to sign up for an account & Two, If the photobucket account is ever closed the thread will be worthless because their won't be any pictures of the charts in it, just empty boxes ...
Thanks.
LockDoc
Subscribing
Old 08-31-2022, 07:33 PM   #70
sfont66
sfont66's Avatar
Very good info
Subscribed
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB.
Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project
sfont66 is offline   Reply With Quote
Old 09-01-2022, 10:16 AM   #71
factorystock
factorystock's Avatar
The charts do indicate what GM offered, but, GM could have offered more ratios to fill the bill more precisely. We had to wait for the square body years for the 3.42 ratio for C 10's and the 3.73 ratio for C 20's.
factorystock is offline   Reply With Quote
Old 09-01-2022, 05:35 PM   #72
'68OrangeSunshine
I ran the numbers on 2 differentials I have.
One, [TPF 1204w] which I had on my '68 C/10 Stepside, but was damaged in a side impact collision, I thought we pulled off a '69 GMC shortbed fleetside. It had been under my Stepside since the Mid '80s. 3.73 Eaton posi. Chart says 1970, not '69, but who can tell the years by looking at a GMC?
The diff I replaced it with [HR 0316w] is [going by the charts] off a '67 P/10 4.11 open.
It was a longbed because the 5' handbrake cables didn't work on my 115'' wheelbase C/10. The guy who sold it to me said it came off a '65 or '66 truck. I had it rebuilt with new axles, bearings and 3.73 gears. Still breaking it in.
Old 09-01-2022, 06:01 PM   #73
pjmoreland
pjmoreland's Avatar
The rear end that was in my truck when I bought it was one of the wider units from a 1970. It had 1970 written on it in yellow paint marker, probably from a wrecking yard. It also measured at the wider width found on 70-72 rear ends. Code stamped on the top of the passenger side axle tube was TDA 11 06 W2, which translates to 1970 3.73 built November 6th. There was also a date code cast into the differential housing that read J 31 9 which translates to October (J) 31st, 1969, which would be appropriate for an early-built 1970 model year.
pjmoreland is offline   Reply With Quote
Old 09-01-2022, 06:15 PM   #74
pjmoreland
pjmoreland's Avatar
I purchased a replacement rear end that had the following codes:
HA 05 06 W = 1967-69 3.73 May 6th
D 17 8 = April 17th, 1968
The odd thing is that I pulled it out of a 1967 Suburban. I'm guessing it wasn't the original rear end though due to the date code on the differential casting. The cool thing is that it is a reasonable date for my '68 truck that was built in the summer of '68.
Old 09-02-2022, 07:57 PM   #75
badpeanut
Not a bad nut after all..
badpeanut's Avatar
I have a 1970 leaf-spring 6-lug 3:07 posi, which is "TPO 0422". I decode this as:
  • TPO=CA 10 3.07 posi
  • 0422=April 22
What is the meaning of CA vs CE?
At first I thought it might be leaf spring rear suspension vs. coil spring rear suspension, but I see the same with K-series so this is ruled out.
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
