Old 11-22-2013, 04:14 PM   #51
atvpro
atvpro's Avatar
Re: Frame Off 72' Blazer Restoration
Finishing up the rust repair on the seat mount.
atvpro is offline   Reply With Quote
Old 11-24-2013, 06:01 PM   #52
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Cool build!
ChuckDriver is offline   Reply With Quote
Old 11-24-2013, 07:16 PM   #53
Chulisohombre
Chulisohombre's Avatar
That's a clean repair there. Can't tell it was touched. Except the fresh paint of course.
Chulisohombre is offline   Reply With Quote
Old 11-25-2013, 10:47 AM   #54
1972CST
1972CST's Avatar
What would be the pros and cons of boxing an original frame compared to using a cut down 3/4 ton frame?
I thought the 3/4 ton used 56" rear springs instead of 52"?
The weak frame seems to be a plague to these first gen K5's.
Awesome upgrades! Great informative build!
1972CST is offline   Reply With Quote
Old 11-25-2013, 06:40 PM   #55
txgp17
I pondered this also.
txgp17 is offline   Reply With Quote
Old 11-25-2013, 07:56 PM   #56
atvpro
atvpro's Avatar
The problem with boxing in makes it harder to keep things original and if you think about all the cross members, the brake cable, and mounting rods and etc. The really nice thing about the way I have done this is you can't tell it was done.
The only difference between the 3/4 ton conversion and the original frame is thickness and fishplate you can't even see which because of where the fishplate is located makes it even stronger exactly where it needs to be.
When this project is all finished I don't think anybody will be able to tell the difference unless I told them.
Old 11-25-2013, 08:00 PM   #57
atvpro
atvpro's Avatar
These pictures show the process - start to finish - of repairing a rusted out area of the rear of the bed on the 72' K5 project.
Old 11-26-2013, 08:28 PM   #58
atvpro
atvpro's Avatar
More rust repair. This is a little spot underneath the passenger front seat.
Old 11-26-2013, 11:54 PM   #59
gringoloco
A guy with a truck
gringoloco's Avatar
Good work here. Watching...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-28-2013, 11:42 AM   #60
juicer25
Looks great! I'd love to come by and check out your operation sometime.
juicer25 is offline   Reply With Quote
Old 11-28-2013, 01:31 PM   #61
lowrodderchev
lowrodderchev's Avatar
that's some great work on those patch jobs
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 11-28-2013, 03:24 PM   #62
caseymp2001
I trust everything ATVPRO does have seen his work first hand with me being there to help. This is the reason I trust ATVPRO to do my work while I am away overseas. While dropping off my Blazer he handed me the keys to the green and white crew cab told me to take it home. If you’re looking for a shop to do any kind of work I would take it to ATVPRO. I could have spent my hard earned money on a blazer already “restored” and hope I know what is hiding underneath. This way I know what I am getting and everything has been documented and is up to my standard. This has been a hassle free experience while being deployed to Afghanistan. If you have any other questions feel free and PM me so we can keep this build thread on track.
caseymp2001 is offline   Reply With Quote
Old 01-02-2014, 03:00 PM   #63
atvpro
atvpro's Avatar
Very important engine building tech tip:
For those of you that are restoring a motor you probably will be using your stock cast iron intake manifold. More times than not most guys have it boiled, sometime bead blasted, than just repaint, this is what you are missing.
Old 01-02-2014, 03:18 PM   #64
Chulisohombre
That's a lot of gunk under there.
Old 01-02-2014, 03:54 PM   #65
gringoloco
A guy with a truck
gringoloco's Avatar
What do you use to re-attach the heat shield?
-Chris
Old 01-03-2014, 09:26 AM   #66
JMac11
JMac11's Avatar
Most of the time the pins are reuseable, I have threaded and loctited screws in too. Remove them by tapping a thin flat chisel under them and they ease right out.
JMac11 is offline   Reply With Quote
Old 01-09-2014, 02:18 AM   #67
oldschool18
oldschool18's Avatar
very nice build you got going on there.
_________________________________
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Members Met......2003Silverado (Dave)
oldschool18 is offline   Reply With Quote
Old 01-26-2014, 09:59 AM   #68
caseymp2001
Just a small update.
Old 02-03-2014, 01:22 PM   #69
Dean'smeanmachine
Dean'smeanmachine's Avatar
cool build
Dean
1972 Custom Camper c/20 5.3 LS swap in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=610187
in God we Trust
Dean'smeanmachine is offline   Reply With Quote
Old 09-04-2014, 06:33 PM   #70
ChuckDriver
Making any progress here?
Old 09-23-2014, 08:16 AM   #71
HARDCORECASH
Also curious how this build is going.....
HARDCORECASH is offline   Reply With Quote
Old 03-13-2015, 04:07 PM   #72
atvpro
atvpro's Avatar
Finally getting pieces out of the paint.
Old 03-13-2015, 04:29 PM   #73
IronCanine
I'm trying....
IronCanine's Avatar
Nice...the older pics don't seem to come up in your threads anymore...if I remember correctly, wasn't this a bronze truck originally? Love the blue and it looks great...the bronze Blazers are looking good to me lately, so that may have altered my recollection.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 03-14-2015, 08:56 AM   #74
Chulisohombre
That's a pretty blue. Looks pretty close to the stock baby blue. I went slightly darker on mine with true blue.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Old 03-14-2015, 10:48 AM   #75
atvpro
atvpro's Avatar
Yes it was originally bronze.
