Old 11-01-2013, 07:33 PM   #51
NEWFISHER
NEWFISHER's Avatar
Re: My 65 step build and first chevy
I like the c10 pumpkin! +1 on oven cleaner, get the spendy stuff
NEWFISHER is offline   Reply With Quote
Old 11-01-2013, 07:45 PM   #52
gimmy 64
I am close by in Menifee. if you need help or some parts just pm me. you are doing a nice job on the truck
gimmy 64 is offline   Reply With Quote
Old 11-02-2013, 11:15 PM   #53
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Cool truck!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 11-10-2013, 07:44 PM   #54
step65
Thanks gimmy 64 appreciate the offer will keep you in mind when I am part searching.
step65 is offline   Reply With Quote
Old 11-10-2013, 07:45 PM   #55
step65
Originally Posted by T.J. MCCAULEY View Post
Cool truck!
Thanks T.J. still lots of work
Old 11-10-2013, 07:47 PM   #56
step65
Thanks Newfisher I saw your truck very nice you work fast. I did get the spendy stuff just have not tried it out yet.
Old 11-10-2013, 08:04 PM   #57
step65
Well got started on bed again. Here is a patch I had to do, bed was pretty messed up here metal was all stretched.
Old 11-10-2013, 08:08 PM   #58
step65
Here it is pretty much finished and bolted fender up to start work on it.
Old 11-10-2013, 08:13 PM   #59
step65
Also got the new rear bed sill mounted and welded up. Took awhile to get everything lined up. Tailgate was something else I worked on.
Old 11-10-2013, 08:17 PM   #60
step65
My tailgate had 3 sides that had been broken loose from the welds. Pretty sure this truck was hit in rear before just by how bad the rear sill was.
Old 11-10-2013, 08:19 PM   #61
step65
Here it is all welded back and sanded down. Man did that take a long time.
Old 11-10-2013, 08:24 PM   #62
step65
Pretty much that is all I have been doing lately. The whole bed is now down to metal. Now it is weld grind sand cuss weld grind sand. Lol What a mess this makes as well. When I pull the cab it will be going to media blasting.
Old 11-10-2013, 08:27 PM   #63
step65
So does anyone know what year this bezel came off of that I got? The one on the left is what was on the grill I bought the one on the right is one I picked up on ebay, it appears to be a cast part where the one on left appears to be a pressed part. The cast one is heavier and a lot nicer and hoping I can find another. Was there a certain year that they used cast bezels?
Old 11-10-2013, 08:29 PM   #64
step65
here is a front view
Old 11-10-2013, 10:51 PM   #65
NEWFISHER
NEWFISHER's Avatar
Good work on the tailgate. My truck didn't come with one when I bought it. I thought no problem, ill pick up a used one and bolt it on....wrong! A gate wouldn't even fit the back. Had to push out the bedsides over an inch, grind all the bondo out of the rear channel, repair a gate then decide to go with a new Mar-k one. Then respray the back half of the truck and the new gate to blend the color into the bedsides without repainting the whole bed. I feel your pain. Hang in there, it gets better.
Old 05-26-2014, 01:31 PM   #66
step65
Well finally got back to working on the truck for the last month or so. A week after the Thanksgiving holiday I ended up in hospital with abdominal pain. Ended up having to have emergency surgery to remove some small intestine that had lost blood flow and died. I now have a 8 inch scar from below the belt line to just above navel. Took me a few months to heal up and then a few months getting the muscles built back up that were cut. Feeling pretty much back to normal now.
Old 05-26-2014, 01:35 PM   #67
step65
Here is a few pics of new headers and also got the wires and looms for the Mallory unilite distributor.
Old 05-26-2014, 01:38 PM   #68
step65
Patriot Clippster Headers H8021-1 they are suppose to bolt right in but there is a fitment problem by motor mounts. I am thinking about the new CPP mounts suppose to get you another inch or so of clearance.
Old 05-26-2014, 01:41 PM   #69
step65
Here is bed after sealer primer I let it dry a week then used red scotch brite lightly before paint
Old 05-26-2014, 01:49 PM   #70
step65
Here is the bed with single stage Acrylic Urethane I chose a dove gray for finish color. This is my first paint job. I know it is not perfect but overall I am happy. I thought single stage with no metal flake would be best to do first. There is a lot to this painting lol. I sanded a few times off primer that had terrible orange peel before I finally got the hang of it. I am going to just pinstripe a black line around letters on tailgate. That is it for now next is patching doors and front fenders then pull cab for media blasting. This body work takes a long time. I see trucks all the time for sale that say the drive line is all rebuilt the hard part is over just needs paint not sure that is a true statement Lol.
Old 05-26-2014, 04:50 PM   #71
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
That engine is freaking awesome!!!! WOWZA!!!!!!!!!!!!
Old 05-26-2014, 07:44 PM   #72
step65
Thanks TJ I hope to hear it run by end of the year.
Old 07-27-2014, 04:44 PM   #73
step65
Changed my mind on the paint color sanded bed all down and went with a darker Gray.
Old 07-27-2014, 04:48 PM   #74
step65
Here is photos of the rocker repair. I did clean up all rust and used undercoating before putting back together.
Old 07-27-2014, 04:53 PM   #75
step65
Here are photos of one of the fender patches. On both fenders when I removed the bolt on bottom of fender the threads disintegrated so had to replace inner bracket as well. You can see where I cut in the middle of the hole to align old bracket with new this worked really well. I used the fender seal bracket to verify all was lined up. I was actually able to find new pinch pins so installing the brackets will be a snap.
