Old 09-01-2014, 12:55 PM   #51
uxdesigner
Re: IT HAS BEGUN!!!! kinda......
Great build!
uxdesigner is offline   Reply With Quote
Old 02-02-2015, 11:49 PM   #52
mattcrp1
mattcrp1's Avatar
I finally got my griffin ls swap radiator mounted as well as the fan and shroud.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 02-02-2015, 11:54 PM   #53
mattcrp1
mattcrp1's Avatar
I am very happy with the way it fits. It looks like it came from the factory this way. Using the factory 4 core or big block rubber radiator cushions with the small block radiator retainer was the way I needed to go. My truck did not have the retainer and I bought one off of a member of the forum.
IG mattcrp1
Old 03-01-2015, 12:43 AM   #54
mattcrp1
mattcrp1's Avatar
I got a lot done recently. I have my new master cylinder installed and sent the drive shaft off to get cut. I got my cooling system filled and temp sender installed. I made the mistake of not filling the upper hose to back fill the cooling system. I had read that others have had difficulty bleeding the air out of other swaps with modified radiators. I got my pcm mounted as well and I am on the tail end of the wiring meld between the body and ls harness. Ill post pics soon.
IG mattcrp1
Old 03-01-2015, 11:07 AM   #55
mattcrp1
mattcrp1's Avatar
This is the pm mounted and temp sender in the heater hose.
IG mattcrp1
Old 04-05-2015, 08:56 AM   #56
MalibuSSwagon
Nice job.
MalibuSSwagon is offline   Reply With Quote
Old 04-17-2015, 11:57 PM   #57
mattcrp1
mattcrp1's Avatar
So after a few months of side jobs I finally saved enough for a used 2002 silverado aluminum drive shaft and had it shortened. After that I had to find the correct conversion U-joint. The drive shaft came with the 4l60 yoke, and that saved a few bucks.
I probably saved $100 going this way over a custom shaft. If I had to do it over I would have looked longer for a factory '76 shaft and had it shortened. The conversion joint took a little time for me to figure out.
I have also been messing with the exhaust. I am going with a 2.5" y-pipe into a magnaflow 3" muffler and single pipe out. I am so close to ripping this thing around the block
IG mattcrp1
Old 12-21-2015, 03:14 PM   #58
mattcrp1
mattcrp1's Avatar
Its been a while, been super busy with work, family etc.. Got the Y-pipe done and finish welded. Sorry I am having trouble loading the pic from instagram.
IG mattcrp1
Old 12-21-2015, 03:15 PM   #59
mattcrp1
mattcrp1's Avatar
Moderator, can you move this to the 73-87 builds forum? thanks.
IG mattcrp1
Old 01-17-2016, 12:32 PM   #60
mattcrp1
mattcrp1's Avatar
Well for the first time since I have owned it and possibly 15 years or more, my truck has finally moved under its own power. I got the exhaust finished and the wiring done as well as the air cleaner mounted. I found that I need to be extra careful with my oil pan as i am very low. More pics to come.
Matt
IG mattcrp1
Old 01-17-2016, 12:33 PM   #61
mattcrp1
mattcrp1's Avatar
I ran 2.5 pipe into a magnaflow y adapter and then a 3 inch single out to a magnaflow flow muffler. it sounds great and I could not be happier with the sound.
IG mattcrp1
Old 01-17-2016, 12:34 PM   #62
dman1982
dman1982's Avatar
Matt
Looks awesome man, I moved my 78 under its own power yesterday too
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 01-18-2016, 01:49 PM   #63
SaltyC20
SaltyC20's Avatar
Looking at your thread it has been a long time coming. Congrats.
1968 Chevy C20
SaltyC20 is offline   Reply With Quote
Old 01-18-2016, 03:18 PM   #64
mattcrp1
mattcrp1's Avatar
Thanks guys.
IG mattcrp1
Old 01-18-2016, 04:57 PM   #65
mattcrp1
mattcrp1's Avatar
One more shot.
IG mattcrp1
Old 01-24-2016, 12:36 AM   #66
mattcrp1
mattcrp1's Avatar
So I had my little helper shaking the wheel and I noticed the excessive movement in the area of the steering box to frame. I pulled the leaking box off and found a nice crack. Stop drilled, v-cut it, welded and started smoothing it out. I got a new box ready to go in. I plan on getting the reinforcement plate to go behind it.
IG mattcrp1
Old 01-25-2016, 02:52 PM   #67
N2TRUX
Happy to be here
N2TRUX's Avatar
Great build up, thanks for sharing.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-25-2016, 03:25 PM   #68
mattcrp1
mattcrp1's Avatar
Thanks for moving the thread.
IG mattcrp1
Old 01-25-2016, 04:26 PM   #69
mattcrp1
mattcrp1's Avatar
Here she is up in the air waiting for my summit parts to arrive. I found that the pit man arm had some play in the joint and the smittybuilt frame plate. My rag joint seemed ok, but if I get time I'll try and get a jeep shaft.
IG mattcrp1
Old 01-29-2016, 06:59 PM   #70
Odaroloc
Odaroloc's Avatar
Keep it up!
1971 GMC Sierra Grande 2500 2wd "Sadiee" Caddy 472/TH400 Project "Sadiee"
1969 Chevy C/10 Build "Maisie" Thread coming soon
Odaroloc is offline   Reply With Quote
Old 02-29-2016, 12:46 AM   #71
mattcrp1
mattcrp1's Avatar
So I finally found a good deal on a CTS-v pan and pick up. Here is the reason, the tape is hard to see but the truck pan hangs just under 2" below the cross member. The new pan is is 2" shallower.
IG mattcrp1
Old 02-29-2016, 12:01 PM   #72
mattcrp1
mattcrp1's Avatar
Just got notice that my reinforcement plate for the steering box shipped so hopefully I can get this this thing on the ground soon.
IG mattcrp1
Old 03-01-2016, 09:43 AM   #73
mattcrp1
mattcrp1's Avatar
I figured before I finished grinding on the frame and welding the plate (that does not fit very well) on I would swap the pan out. I got the old one out and swapped out the pick up. After looking at the old pan and pick up there was some sludge but no metal or chunks of unknown debris. I am pretty happy with that. Swapping this pan with the engine in the frame is a P.I.T.A.. Here you can see the depth difference of the CTS-V and truck pans.
IG mattcrp1
Old 03-02-2016, 09:13 AM   #74
dman1982
dman1982's Avatar
[QUOTE=mattcrp1;7504824]I figured before I finished grinding on the frame and welding the plate (that does not fit very well) on I would swap the pan out. I got the old one out and swapped out the pick up. After looking at the old pan and pick up there was some sludge but no metal or chunks of unknown debris. I am pretty happy with that. Swapping this pan with the engine in the frame is a P.I.T.A.. Here you can see the depth
With my k10 no clearance issues with the pan lol
But with the oil pan swap I believe you have to do some shimming on the timing cover...not a 100% sure but worth looking into
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-02-2016, 10:43 AM   #75
mattcrp1
mattcrp1's Avatar
Thanks dman I'll check it out. How is your swap going? I cant wait to start driving mine.
IG mattcrp1
