Old 03-14-2014, 10:38 AM   #51
dec010974
dec010974's Avatar
Re: Porterbuilt Stage 1 Front and Rear Kit Chart
muckyp, I had clearance issues with the lower control rubbing/interfering the inner rally wheels and wheel balance weights. I also had to clearance/grind the tie rod area of the drop spindle. For my application, a grinder was my best tool until I decide to buy larger wheels. Im running my stock rally wheels which are 15x8. I used the belltech 3 inch drop spindle, stock lower control arms, & the air bag in the lower control spring pocket. I also used a PB stage 1 lowering kit which relocated the shock mounts. i hope this helps.
dec010974 is offline   Reply With Quote
Old 03-14-2014, 11:57 AM   #52
MattPSU
MattPSU's Avatar
Originally Posted by muckyp View Post
MattPSU - are those 15" wheels on the truck in the photos? If so did you have issues with the wheels rubbing the lower control arms?
Yes, they are 15x7's and they rubbed on the lower control arm which did a great job of shaving my wheel weights. I don't have a picture of the arms, but I do have some pictures of the wheel weights. I can try to take some pictures of the arms this weekend.
Enjoy! - Matt
Matt Criswell - Lyman, SC
1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank
UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE
MattPSU is offline   Reply With Quote
Old 03-14-2014, 10:25 PM   #53
muckyp
muckyp's Avatar
Enjoy! - Matt
I have the same drop spindles and bags in front. Did you grind the lower control arms? I plan a larger wheel but those things are $$$$$, so I need some time prep the wife for the purchase.
70 SWB 454/TH400
muckyp is offline   Reply With Quote
Old 03-15-2014, 05:10 PM   #54
MattPSU
MattPSU's Avatar
I trimmed them with a sawzall & cut-off wheel, then cleaned it up with my grinder.
Old 03-28-2014, 08:26 PM   #55
MRWGN
Just wondering how much lower (if any) having tubular control arms would make it?
I ask because the way the bag mounting happens with the stage 1 kit it brings the mounting surface flush with arm and not recessed into the cup.
Would a set of porterbuilt tubular arms/CPP arms in standard form change those dimensions and make it lower again in the front?
MRWGN is offline   Reply With Quote
Old 03-30-2014, 11:59 AM   #56
King Cary
Thanks for the chart Matt... Awesome lay out for everyone to use as a comparison when building their trucks... I see you're in Lyman S.C., I'm originally from Columbia.
King Cary is offline   Reply With Quote
Old 03-30-2014, 07:48 PM   #57
MattPSU
MattPSU's Avatar
No idea. Maybe Travis or one of the Porterbuilt guys will chime in and let us know. If they send me a set, I'll install them and take some pictures, too!
You're welcome. Small world!
Old 03-30-2014, 09:18 PM   #58
hass18
Does anyone have any pictures of how and where all the air valves and controller is mounted? Just looking for ideas on how to plumb and set up.
hass18 is offline   Reply With Quote
Old 03-31-2014, 09:09 AM   #59
MattPSU
MattPSU's Avatar
Here are some pictures of my air management set up which is Pro Performance's Pro 2 kit. I mounted my valve block, relays, & power distribution block on the cross member that's just behind the axle. The tank is mounted on a 2x2 that spans the rear of the frame where the original rear cross member used to be.
Old 03-31-2014, 09:13 AM   #60
MattPSU
MattPSU's Avatar
I don't have any pictures of the AVS controller but here's one of my gauges inside the cab.
Old 03-31-2014, 09:53 AM   #61
Pro Performance
Pro Performance's Avatar
The PB arms will lower the truck more, by placing that bag mount lower in the a-arm as you described. I don't know the exact measurement, but you will see appx. 3/4" more of drop.
- Travis
Pro Performance is offline   Reply With Quote
Old 03-31-2014, 10:07 AM   #62
hass18
Thanks for the pics. That was where I thought would be the best place to mount.
Old 04-02-2014, 01:08 AM   #63
Carbajal
Carbajal's Avatar
Truck looks good. I like the way it looks That's the setup I'm going to put on my c10. What size tires do you have??
Carbajal is offline   Reply With Quote
Old 04-03-2014, 01:21 PM   #64
clemsonteg
Thanks for the chart. I asked about this about a year ago and this is exactly the information I was looking for. I see in the first few photos you are at 80 psi front and 40 psi rear, but in the last few you list ride height at 60 psi front and 25 psi rear. Is that where you have always kept the ride height, or have you reduced it over time to fine tune the firmness you were after?
clemsonteg is offline   Reply With Quote
Old 04-03-2014, 09:11 PM   #65
MattPSU
MattPSU's Avatar
Your welcome!
Current tires are 275/60R15 on 7" rally wheels. About 27.5" tall. Someday I hope to upgrade to 20's.
At 80psi front and 40 psi rear, the bags are about fully inflated and that's as high as the truck can go. Initially I was thinking about showing the possible difference from fully deflated to fully inflated. I wasn't thinking about ride height which is somewhere in between. The more I drive it, the more I've been able to dial in the ride height which is more like 60psi front and 25 psi rear.
Clemsonteg - Be sure to check out the link to the Upstate GM Trucks Club that's in my signature. We've been getting together about once a month and we had 35 trucks show up in March.
Old 04-03-2014, 10:33 PM   #66
clemsonteg
Matt- thanks for the heads up. I've seen the pics in the regional forum. I definitely want to make it out, I just recently got the front end back on the my truck and got it back on the road. Once I get the kinks worked out I'll feel better about driving it to greenville.
Old 04-16-2014, 02:47 PM   #67
Desert.Chevy
Desert.Chevy's Avatar
Your welcome!
I would like to see some pictures of the three heights, and the psi they have.
Desert.Chevy is offline   Reply With Quote
Old 04-16-2014, 03:50 PM   #68
MattPSU
MattPSU's Avatar
The 4th, 6th & 7th pairs of pictures show you the heights as they are now in various pressures.
The 4th pair of pictures is aired all the way up, the 6th pair is at ride height, and the 7th is aired up.
Hope that helps. - Matt
Old 04-17-2014, 01:03 PM   #69
Desert.Chevy
Awesome Thanks.
Old 08-28-2015, 10:15 AM   #70
jus2qwk
jus2qwk's Avatar
I bought the stage 1 front and added the control arms later and have the stage 2 basic and used CCP trailing arms with blocks... I bought all mine at different times if I could do it again I would have bought it all at once and went with the deluxe kits. but here is the end result. also made some bumpstops for the front because the tire hits the fender. the bump stomps get the tire just off the fender by about 1/4 inch
this is before the bump stops setting on the fenders
Bump stops
here it is all aired out. I changed the rear bump stops so it sets about an inch lower in the rear
Corey Jones Designs
CoreyJonesDesigns on instagram
Ole Silver- 1967 stepside
http://www.hotrod.com/articles/1103c...chevrolet-c10/
http://67-72chevytrucks.com/vboard/s...d.php?t=598758
jus2qwk is offline   Reply With Quote
Old 08-28-2015, 10:17 AM   #71
jus2qwk
jus2qwk's Avatar
whoops put this on the wrong thread... kinda
Corey Jones Designs
Old 08-28-2015, 10:53 AM   #72
darkhorse970
darkhorse970's Avatar
Love the stance! What are the rear tires size and wheel specs?
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 04-03-2016, 06:17 AM   #73
crazycrew
Awesome thread Matt. I don't have a C10 yet, but i'm actively searching and suspension is gonna be one of the first mods. Thanks
crazycrew is offline   Reply With Quote
