Old 02-05-2014, 11:54 PM   #51
Flames97
Flames97's Avatar
Re: 1950 3100 Full Custom **GunMetal**
Wow...moving right along. Looks good.
-Aaron
'15.5 Chevy Duramax LTZ/Z71, LML, CC/SB
'77 Chevy K10, 4" lift, 33-12.50, 350/350
'55 Chevy Short Box (In Pieces)MII,4-link,Bagged,383 Stroker,700r4,3.73posi (SOLD)
My 55.2 Chevy 3100 Build
Flames97 is offline   Reply With Quote
Old 02-06-2014, 12:38 AM   #52
oldman3
oldman3's Avatar
Sweet...Jim
oldman3 is offline   Reply With Quote
Old 02-07-2014, 07:40 AM   #53
vince921
Thank you ! New proportioning valve should be here today so hoping to have the brakes done this weekend ! And the motor back in by the end of next week
vince921 is offline   Reply With Quote
Old 02-07-2014, 10:23 AM   #54
solidaxel
solidaxel's Avatar
What Rear gear is that you have installed?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-07-2014, 10:28 AM   #55
vince921
It's a 370 gear ratio
Old 02-07-2014, 10:28 AM   #56
vince921
Strange center section
Old 02-07-2014, 10:34 AM   #57
solidaxel
solidaxel's Avatar
Is that the way Strange set up the Ring & Pinion or was it done locally?
LS 3 4L70E
Old 02-09-2014, 11:08 AM   #58
vince921
it all came set up from strange
Old 02-14-2014, 09:39 PM   #59
50adrod
50adrod's Avatar
truck is looking good, what running boards did you use? my truck build is very similar, the rear fenders look identical. started it 8 years ago and never finished, sold it 2 years ago and bought it back last month.
http://67-72chevytrucks.com/vboard/s...d.php?t=296770
have you done any of the accuair height sensors yet? I am in the process of mounting the sensors on my 64 f100 build and it is a little challenging to get the proper angle with the amount of suspension travel.
keep up the good work
1971 Corvette convertible 454@ 525 hp
1936 Chevy Truck street rod
1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up
1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html
1950 custom Chevy Truck
50adrod is offline   Reply With Quote
Old 02-15-2014, 10:11 AM   #60
vince921
Thanks man
The rear fenders/running boards and all from superior glass works... i also have the fiberglass smooth hood... but i dont plan on running it .. if anyone is interested in it???
http://www.superiorglassworks.com/Ru...k-p/53t04w.htm
And as far as the accuair i have not i have been researching like crazy and think i found a couple good spots to put them im expecting delivery of all accuair next week.... there not the fastest when it comes to shipping unfortunately.. but im sure well worth the wait. I will be sure to post lots of updates when i get into that !!
Your truck looks killer man!
Old 02-16-2014, 11:52 AM   #61
50adrod
50adrod's Avatar
thanks, accuair makes high quality components, you will be impressed. I did get my front sensors figured out and mounted I can post a picture later if you want. it is on my 64 f100 but all mustang II suspensions are pretty much the same.
Old 02-16-2014, 11:56 AM   #62
vince921
Heck yeah man id love to see how ya mounted em !
Old 02-16-2014, 11:59 AM   #63
vince921
got the engine back in .. all the brake lines ran except the braided line to the rear brakes( have to get some lines made up ) got the tabs welded on the gas tank its not mounted solid!!
Old 02-16-2014, 05:01 PM   #64
oldman3
oldman3's Avatar
Looks great, very nice work..Jim
Old 02-16-2014, 06:56 PM   #65
Rc4mike
Jim. I see u have a trans cooler. Is that enough or will u still run lines to cooler in radiator? I have same engine and trans
Rc4mike is offline   Reply With Quote
Old 02-16-2014, 07:18 PM   #66
79azc10
Wow that truck is really going to be something when done
79azc10 is offline   Reply With Quote
Old 02-16-2014, 11:49 PM   #67
50adrod
50adrod's Avatar
here is how I mounted mine. at first I tried to mount the sensor to the frame but my lower control arm has 4 inches of travel and put the sensor arm in a bind when all the way down. I had to mount the sensor parallel to the lower control arm. It works perfect and has no binding. This is on my 64 F 100 but most all mustang II's are the same. The picture angle makes it look close to the bag but there is over I/2 inch clearance, tight quarters but it will work fine. My 64 F100 build if you want to check it out http://www.ford-trucks.com/forums/12...mark-viii.html
top view right front wheel
full up position, Slam SS 6 bags
full down position
Old 02-17-2014, 07:08 AM   #68
vince921
Awesome that's exactly where I was thinking I'd have to put mine ! Thank
You for the pictures they will surely come in handy
Old 02-17-2014, 11:10 PM   #69
*Kenny
you do great work, cant wait to see more.
*Kenny is offline   Reply With Quote
Old 02-19-2014, 01:01 AM   #70
wickid demon
wickid demon's Avatar
Chassis is coming together nicely. What are you using for the engine wiring harness.
Ryan
My Wickid 54 http://67-72chevytrucks.com/vboard/s...d.php?t=518657
wickid demon is offline   Reply With Quote
Old 02-19-2014, 07:12 AM   #71
vince921
When I purchased the truck from the previous owner he had already purchased the motor/trans/computer probably as a package id assume. But it is a very nice well labeled harness I wish I could figure out where it came from
Thank you
Old 02-19-2014, 10:54 AM   #72
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Looking amazing man. Great work.
--Josh
Old 02-19-2014, 06:36 PM   #73
vince921
Thank you everyone for the kind words finished up the rear brakes today!!! then put it back down on the ground to check for clearances on all the new lines ... now just waiting on accuair which is scheduled for delivery 2/24/14.... until then im just getting some things cleaned up on the cab so i can throw that right back on when the airride is plumbed !!! lots of updates coming soon!!
had some pretty trick rear brake lines made up ..
back on the ground
Old 02-20-2014, 08:12 PM   #74
vince921
nothing really picture worthy but finished up the rear brakes today... and got the shifter all adjusted ... its was horrible before... and ive been doing some small things while waiting for the accuair to arrive ... filled the off center stock column indention in the dash.. and have been grinding and welding away on the bed... ill get some pictures tomorrow of all that!
Old 02-23-2014, 08:21 PM   #75
vince921
Got the Cab back on yesterday ... and then spent the rest of the weekend fixing not so grade A work... found that the passenger side rear cab mount was just about broke/rusted through the floor... didnt get any pictures but patched it top and bottom, then had to notch the floor for the 1350 transmission yoke it only had about 1/32 clearance so instead of pushing it i went ahead and got that done.. and fired it back up to check leaks!... ACCUAIR will finally be here tomorrow! ordered my new brake and gas pedal assembly this afternoon and going to call to have my driveshaft made tomorrow should be a quick turn around time on that !
