Old 01-31-2014, 06:07 PM   #51
SCHRUMGMC
SCHRUMGMC's Avatar
Re: Truck runs ad then shuts off
Cracked me up.Where the truck is sitting, I can not charge it up to get it running.The Generator was checked and fixed before I put it in..I'm honestly thinking its the Voltage regulator because its the Original V-R and I've read some things on the Signs of them going bad.I don't understand how things can go so well and then ****ty because when I polarized the V-R it didn't do anything.What is the best type of Voltage regulator I need to get ?
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 01-31-2014, 06:14 PM   #52
Indian113
Indian113's Avatar
OrrieG, You are a saint! I wish I had your patience .
Indian113 is offline   Reply With Quote
Old 01-31-2014, 08:58 PM   #53
OrrieG
OrrieG's Avatar
Standard VR-22 seems to be the one for 50 and early 60 35 watt 12v systems. They are priced from $12-16 on the internet. Rockauto was the cheapest. but i did not check shipping. NAPA carries Standard parts if you have one close.
OrrieG is offline   Reply With Quote
Old 01-31-2014, 09:54 PM   #54
SCHRUMGMC
SCHRUMGMC's Avatar
Seems a little fishy to be $12, because you get what you pay for right?..I have a NAPA down the road, Thanks Orrie for all of the info its greatly appreciated
1971 GMC Sierra
1959 GMC 100
Old 02-01-2014, 03:56 PM   #55
OrrieG
OrrieG's Avatar
Standard is a respected brand been making parts for at least the last 50 years. If you go to NAPA and get anything electrical is it usually Standard or Dorman. If you order aftermarket ignition or light switch, lamp sockets most likely they will come in Standard packaging, that is why I encourage people to look at NAPA first. They are inexpensive because the design is 60 years old, it is low wattage to match the generator and relatively simple. I do not know if they still make them in the US of if they are off shore. Rockauto was at $12 but probably has about $6 S&H, NAPA was at $16. Other brands are more expensive, but I guess it is based on cost to produce lower quantities (Standard probably made a qazillion when it cost $2 to make one) or selling where there is limited availablility.
Old 02-02-2014, 03:06 AM   #56
SCHRUMGMC
SCHRUMGMC's Avatar
Just thought of something I am using a 12 Volt battery and the System is a 6V? and it says that if I do it for so long it will die?
1971 GMC Sierra
1959 GMC 100
Old 02-02-2014, 03:56 AM   #57
meter swinger
meter swinger's Avatar
Your rig being a 59 will have a 12v system.
meter swinger is offline   Reply With Quote
Old 02-02-2014, 03:57 AM   #58
SCHRUMGMC
SCHRUMGMC's Avatar
but it has a Generator?.Nothing has been switched over. I see what your talking about..I thought the Gen was always 6 V...I'm going to leave the truck in the barn and pull the MGB out of the pasture and onto the driveway to clean it up
1971 GMC Sierra
1959 GMC 100
Old 02-02-2014, 12:12 PM   #59
meter swinger
Yep, 12v system with a generator. If you think you are having issues maintaing a charge, and your battery is fresh, check the battery cables and connections. If the wire is old and breaking at the connectors cut out the broken part.
If you replace them entirely, welding cable makes really nice battery cable.
Old 02-02-2014, 12:24 PM   #60
SCHRUMGMC
SCHRUMGMC's Avatar
I have someone sending me a E brake pulley which I need badly.I am going to step back from it for a while.Going to see if I can get my Uncles MG up and running
1971 GMC Sierra
1959 GMC 100
Old 02-02-2014, 02:25 PM   #61
OrrieG
OrrieG's Avatar
I think generators where standard until around 1963 on cars and trucks. My 60 Impala had a generator but my 64 Chevelle came standard with an alternator that still used a voltage regulator.
