Old 07-06-2014, 04:22 PM   #1
SS Tim
SS Tim's Avatar
Do you have a 1972 Plaid Pickup?
Many people know about the Highlander Plaid seat trim option on both Chevrolet and GMC conventional light trucks.
However in an attempt to reach out to those who don't know I am asking people who are not sure, to please check the trim code/s of their trucks. Often the seat covers have been replaced leaving few clues beyond white door panels (again often changed) and seat belts with black dash pad, column and carpet.
So if you could, please let us know if you have (or just found!) a "Hidden Highlander"
The codes to look for are below.
Also just in case SPID reading is new to you the code may have leading and trailing numbers even letters. Reading between the lines may be needed.
Examples 613, _ 613_ _, 613_ _
As far as the SPID description goes, generally you will see "CUSTOM TRIM COMBINA" or the COLOR followed by "...HIGHLANDER P"
This thread is body style specifc so if you have several different body styles please check the other forums for the specific trim codes as applicable. Not trying to cross post this, just touch with all who may have a Highlander.
On a personal note if anyone has a 519/549/581/480 Dark Yellow with the 618 Orange Plaid please post pictures.
Pickups
Custom Deluxe Z62 mandatory option
Avocado 613
Blue 611
Gray 604
Orange 618
Blazers http://67-72chevytrucks.com/vboard/s...d.php?t=635033
Suburbans http://67-72chevytrucks.com/vboard/s...d.php?t=635035
SS Tim is offline   Reply With Quote
"ss tim", highlander, plaid
