Old 11-28-2014, 03:13 PM   #51
skymangs
skymangs's Avatar
Re: Cecil the 1953 5 window / S-10 / 5.7 TPI
I just ordered the new gauge from Speedhut. Shawn is graciously allowing me to use his truck as a test bed for some new Idea's I've been kicking around. I plan on replacing the original speedometer head with the new Speedhut electronic speedo. I will re-use the original faceplate, and have my graphics shop custom make me a vinyl decal to replicate the original look of the speedometer, but match the Mph marks of the Speedhut gauge. The new vinyl decal will go to 90mph, as the original did. The new speedo will have integrated bright and signal indicators as well.
If this works out as well as I expect, it will be my new standard for LS swaps.
skymangs is offline   Reply With Quote
Old 12-01-2014, 05:41 PM   #52
oossuuu754
oossuuu754's Avatar
Went by today to see Chris and see how Cecil was progressing. It was nice to get my gloves a little dirty and help him test fit the cab on the S-10 chassis. Chris has some ideas to get him to an overall goal of 7 inches off the ground. Stay tuned.
---Shawn
Cecil-1953 5 window build thread
Skymangs..Chris of Old Sarge customs had a shop fire and was severly injured. To help with the medical bills and expenses a fund has been set up here....http://gofundme.com/c49h5mjx8 More details are here...http://67-72chevytrucks.com/vboard/s...=1#post7253189
oossuuu754 is offline   Reply With Quote
Old 12-01-2014, 05:54 PM   #53
steve aleve
I'm definitely tuned in. This thing is going to be nice!!! I do have a couple questions. First off I think it was mentioned that the target height was going to be 5" above the ground. Why did this change to 7". Secondly what would be the lowest you would recommend for a static drive height 5"? 4"? etc? (when I say height I am referring to running board above the ground) is this what you are referring to also? Lastly there was mention of having to "get creative" to get it this low. What are the obstacles when shooting for this height? Gas tank? tunneling? radiator? raised bed floor? any others?
steve aleve is offline   Reply With Quote
Old 12-01-2014, 06:17 PM   #54
oossuuu754
oossuuu754's Avatar
Not sure if Chris will be able to chime in on what the lowest he would recommend for a static drive but I know that his Son's truck is only about 4 inches. Main reason we are having to change our goals is because of the massive tires I am running. With the 18x8s and 20x10s I have 29 and 31 inches of tires and wheels. Gas tank will be an issue if we go much lower. Chris is going to get the drop spindles in this week and then we have decided to go with a drop in the rear In addition to the 3 or 4 inch blocks. Looks like we will have to raise the bed a 2 or so inches but I don't want the bed much higher as I still want it look like a bed and not a wooden tonneau cover.
---Shawn
Old 12-01-2014, 07:57 PM   #55
skymangs
skymangs's Avatar
Shawn didn't mention that I cut an additional inch out of the cab mounts this morning. That makes the forward stands just over 2" off the frame. Any closer we will run into trans and fuel tank clearance issues. I'm going to order a set of drop springs for the rear to suck it down some more. May go with 1" drop springs up front as well. I'm still shooting for 5", but I dont want to kill the ride just to get it low.
Lowest I would recommend would be 4.5" clearance at the front edge of the running board. Any lower, you will start to have speed bump problems.
Old 12-01-2014, 08:03 PM   #56
steve aleve
Thank you guys for the responses. I appreciate it. 4.5 it is!!! lol. I'm anxious to see how this thing turns out! For mine, I have 3" blocks for the rear and 2" spindles up front. I also have some drop leafs and drop springs for the front that I wasn't sure if I was going to use for that same reason. I don't want it to ride poorly.
Old 12-01-2014, 08:04 PM   #57
skymangs
skymangs's Avatar
Obstacles are bed height, pinion angle, trans clearance, steering shaft geometry, and ride quality. I was considering "Z'ing" the back half, but it would have raised his bed height too much. As it stands, once the drop springs go in the rear, the frame will need to be "C" notched.
Old 12-01-2014, 08:07 PM   #58
skymangs
skymangs's Avatar
Remember Steve that your overall tire height really alters your ride height. PM me for my number if you would like the formula for 4.5" ride height.
Old 12-01-2014, 08:39 PM   #59
oldman3
oldman3's Avatar
Chris, I see you have the shop full already. What's the deal with the AD with the I-ROC wheels in the rear. Is that a plymouth sedan, your also working on???....Jim
oldman3 is offline   Reply With Quote
Old 12-01-2014, 11:17 PM   #60
skymangs
skymangs's Avatar
The AD belongs to my buddy Chris. He's doing all the work, just using my shop, tools, power, and heat... Yup, He's a user! Lol
The other one is a 48 Plymouth Deluxe with a Caddy 472 and some hoakie work on the Camaro stub (lots of flex)... Guess what I'll be fixing?
Old 12-03-2014, 03:30 PM   #61
oossuuu754
oossuuu754's Avatar
Chris aka SKYMANGS has been busy this week so I am going to post verbatim what he has said straight of his facebook page
I will note his comments with indentations and quote marks. I want to make sure and give him all the credit for this wonderful work he is doing on Cecil
"Mocking up the driveline. Always a challenge to get it perfectly centered, and level. Tew motor mounts are bolted on, snd I use 1/2" ID 11ga. Tube and 1/2" bolts to mount it to the frame."
---Shawn
Old 12-03-2014, 03:37 PM   #62
oossuuu754
oossuuu754's Avatar
SKYMANGS:
"Once I'm happy with the placement, templates are made for the uprights. They are cut from 3/16" plate and tacked I n place. Then the driveline is yanked to seam them in."
---Shawn
Old 12-03-2014, 03:42 PM   #63
oossuuu754
oossuuu754's Avatar
Chris:
"Here's the driveline in position with the motor mounts all seemed in. I use a jackstand to keep th he tailgate in place, until I can get the trans cross member finished."
---Shawn
Old 12-03-2014, 03:50 PM   #64
oossuuu754
oossuuu754's Avatar
SKYMANGS:
"This is how I do the cross member. First I cut the passenger side, then I trim the driver's side to clear the frame rail. I weld 1.25 11ga. Boxed to create a new shelf. Then I trim the passenger side piece I cut off to fit and re-weld it together."
---Shawn
Old 12-03-2014, 03:53 PM   #65
oossuuu754
oossuuu754's Avatar
SKYMANGS:
"Then the cab goes back on to double check clearances. Tomorrow I'll start working on the brake booster/pedal assembly and steering column."
---Shawn
Old 12-03-2014, 03:58 PM   #66
oossuuu754
oossuuu754's Avatar
Once again I want to give Chris all the credit. He did all of this last Sunday, plus still found time to work on a 48 Buick. Chris you are crazy good and crazy fast. Trust me he has finished up a lot more but I am don't have time right now to post it up. If you cant wait go over to his facebook page, otherwise I will try to get it up tonight or tomorrow.
Thanks again SKYMANGS!
---Shawn
Old 12-03-2014, 06:01 PM   #67
T Hilde
What did the motor come out of? I have the same exhaust manifolds and trying to find a Y pipe.
T Hilde is offline   Reply With Quote
Old 12-04-2014, 06:20 PM   #68
oossuuu754
oossuuu754's Avatar
This motor is our of 5.7L 87 IROC Z28
---Shawn
Old 12-04-2014, 06:29 PM   #69
oossuuu754
oossuuu754's Avatar
SKYMANGS:
"Brake pedal assembly modified and installed. Booster/master located and mocked up. Still no drop spindles, were supposed to be delivered today."
---Shawn
Old 12-04-2014, 06:33 PM   #70
oossuuu754
oossuuu754's Avatar
SKYMANGS
New steering column, I build all my own brackets. This is the upper bracket being made.
---Shawn
Old 12-04-2014, 06:37 PM   #71
oossuuu754
oossuuu754's Avatar
SKYMANGS:
Seat base coming out. Last shot is the drivers floor pan. Rust goes all the way under the seat base. I'll be picking up a new pan later this week.
---Shawn
Old 12-04-2014, 06:42 PM   #72
oossuuu754
oossuuu754's Avatar
SKYMANGS:
"Upper bracket finished. Building the lower bracket. Last one is column installed"
---Shawn
Old 12-04-2014, 08:21 PM   #73
skymangs
skymangs's Avatar
Thanks for taking the time to post these Shawn. I'm having a blast building your truck!
Old 12-04-2014, 08:37 PM   #74
oldman3
oldman3's Avatar
Nice update guys, looks good...Jim
Old 12-04-2014, 10:42 PM   #75
oossuuu754
oossuuu754's Avatar
SKYMANGS:
"Altman ez latches arrived today. They look like a really nice setup"
---Shawn
5 window, 5.7 tpi, chevy truck, rusto mod, s-10 chassis swap
