Old 09-16-2016, 04:34 PM   #51
JohnKimble
Re: 85 White Whale
Rear windshield in. Windshield guy didn't bring a front gasket, so smog will be on hold until Monday when he comes back.
JohnKimble is offline   Reply With Quote
Old 09-16-2016, 04:50 PM   #52
Matt Man
Matt Man's Avatar
Re: 85 White Whale
Looking great! I got way more than that in mine and it still isn't painted... who is doing your glass install?
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 09-16-2016, 05:12 PM   #53
JohnKimble
Re: 85 White Whale
A local glass man, friend of a friend I guess. I can PM you his contact if you need it, Sacramento area.
New front antenna windshield, front chrome gasket, rear black gasket, plus install on rear window. $200!
Old 09-16-2016, 05:17 PM   #54
Matt Man
Matt Man's Avatar
Re: 85 White Whale
UG I wish he was closer! Even though my rubber seals are all new, the upper right corner on my front windshield isn't sitting flush. I'm about 50 miles southeast of Los Angeles. Are you going to do any work on the interior?
Old 09-16-2016, 05:36 PM   #55
JohnKimble
Re: 85 White Whale
The interior is okay for now. I'd like to get the seat reupholstered, and install a carpet. Retro stereo would be cool too.
I need to order some wiper arms and get a new motor for the windshield washer fluid reservoir.
I used some "303 aerospace protectant" on the interior and it really made it look much better, even though the dash is cracked and the door panels need some love. I'd like to respray my gauge bezel but that will come at a later time.
Old 09-19-2016, 07:25 PM   #56
JohnKimble
Re: 85 White Whale
Front and rear glass are in. Passed smog. Spent 2 1/2 hours at the DMV, but it's finally registered and on the road.
Wiper arms, blades and washer pump motor are ordered. Fender trim should be on this weekend.
Old 09-19-2016, 07:33 PM   #57
JohnKimble
Re: 85 White Whale
Old 09-19-2016, 07:57 PM   #58
MTCK
MTCK's Avatar
Re: 85 White Whale
Looks great!!!
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 09-19-2016, 08:54 PM   #59
cochino12
It followed me home?
cochino12's Avatar
Re: 85 White Whale
Originally Posted by MTCK View Post
Looks great!!!
^^ what he said
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 09-25-2016, 09:25 PM   #60
NewType72
NewType72's Avatar
Re: 85 White Whale
Holy cow just rolled right on through that one didn't ya!! Looks incredible, very tidy build
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 09-26-2016, 07:07 PM   #61
JohnKimble
Re: 85 White Whale
First coat of Herculiner drying.
Anyone know if a faulty windshield washer switch inside the turn signal lever could keep the washer fluid pump from activating??
Old 09-30-2016, 08:49 PM   #62
JohnKimble
Re: 85 White Whale
Sprayed the engine down with some degreaser, it cleaned up well. The bed liner is cured and came out nice as well.
I narrowed my washer fluid spray problem down to a faulty switch. Tearing into the column is a PITA, but it needs to be done. Also bought a new turn signal lever.
Old 09-30-2016, 08:50 PM   #63
JohnKimble
Re: 85 White Whale
Much cleaner.
Old 10-01-2016, 02:09 PM   #64
MTCK
MTCK's Avatar
Re: 85 White Whale
Very nice work looks great. I love (hate) tearing these columns apart!
-Marcus
Project Plow Truck
Old 10-01-2016, 08:53 PM   #65
JohnKimble
Re: 85 White Whale
Thanks. Wiper switch didn't come today, so I'm hoping on Monday. Getting the switch plug through the column is going to be a real pain. I'm debating on carefully removing each wire from the plug itself and pulling it through using the string I've already fished through. If anyone has any suggestions on how to go about it, I'm all ears!
Old 10-03-2016, 08:50 PM   #66
Greenlee
Greenlee's Avatar
Re: 85 White Whale
The truck looks killer! Nice work.
I changed my wiper switch a few years ago. I used the string method if I remember correctly. I can't really remember exactly how I did it.
Greenlee is offline   Reply With Quote
Old 10-03-2016, 09:49 PM   #67
Greenlee
Greenlee's Avatar
Re: 85 White Whale
Old 10-03-2016, 09:51 PM   #68
JohnKimble
Re: 85 White Whale
Thanks!
I ended up cutting the plug of entirely, feeding the wires through the column, and soldering each of the wires back together.
Old 10-13-2016, 10:26 PM   #69
JohnKimble
Re: 85 White Whale
In the process of adding an aux input to the factory stereo.
Old 10-15-2016, 12:11 AM   #70
JohnKimble
Re: 85 White Whale
Got the aux input installed and works well. I have 8 more aux jacks if anyone needs one. PM me and I'll toss one in an envelope.
Old 10-15-2016, 12:05 PM   #71
Matt Man
Matt Man's Avatar
Re: 85 White Whale
How do you like the raptor liner? I am wanting to do a diy bed liner for my truck over my winter break. How well did that aircraft paint remover work?
Old 10-15-2016, 01:22 PM   #72
JohnKimble
Re: 85 White Whale
It's actually herculiner. For under $70, I like it a lot. Time will be the test, but as of now it has a nice gloss black look to it.
The aircraft paint remover is messy. And will burn your skin on contact...but it works. Paint it on and wipe off everything it touches down to bare metal. Saved a lot of time stripping the little nooks and hard to reach places in the bed.
Old 06-11-2017, 08:45 PM   #73
JohnKimble
Re: 85 White Whale
Got some 31's installed this weekend.
Old 06-12-2017, 02:09 AM   #74
MTCK
MTCK's Avatar
Re: 85 White Whale
Looks tough. What are they?
-Marcus
Project Plow Truck
Old 06-12-2017, 02:12 AM   #75
JohnKimble
Re: 85 White Whale
Radar Renegade m/t. Never heard of them but they have some decent reviews online. We'll see how they fair. $500 mounted and balanced.
