Old 10-16-2014, 09:44 AM   #51
reaper71
reaper71's Avatar
Re: "Project Orangepeel" 52 A.D
These are the inner and outer lip for the fender to bolt to.
As well as the smaller panel replaced
reaper71 is offline   Reply With Quote
Old 10-16-2014, 09:48 AM   #52
reaper71
reaper71's Avatar
these two are of the toe board as I made the panel and it was installed.
Old 10-16-2014, 08:10 PM   #53
FarmerSid
FarmerSid's Avatar
Nice patch making. I enjoy it.
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 10-17-2014, 10:03 AM   #54
reaper71
reaper71's Avatar
These pics are of the inner toe board and kick panel replaced.
As well as the passenger side being cut out.
Old 10-17-2014, 10:12 AM   #55
reaper71
reaper71's Avatar
Here is some shots of the inner cab section. I used Eastwood rust encapulator then maid my new patch. Using a hole punch I popped holes around the piece so I could spotweld it in place.
Old 10-17-2014, 09:46 PM   #56
Advanced Design
Advanced Design's Avatar
Nice work Reaper...be good for another 60 years!
Advanced Design is offline   Reply With Quote
Old 10-18-2014, 10:30 AM   #57
reaper71
reaper71's Avatar
Yeah I hope so!! No sitting in a field for yrs either..
Old 10-18-2014, 10:35 AM   #58
reaper71
reaper71's Avatar
These are of the floor pan removed,patch panels and the lower A pillar replaced
Old 10-18-2014, 10:46 AM   #59
reaper71
reaper71's Avatar
These few are of the floor being replaced. a pic of the body mount I made, I used 2x3 tube and welded in. The last pic is of the cab patch, I cut this out do to a large crease down the center of the stock piece (damaged during tow bringing her home)
Mark...
Old 10-20-2014, 09:31 AM   #60
reaper71
reaper71's Avatar
First pic is of the cleaned up area for the new patch.
Old 10-20-2014, 09:36 AM   #61
reaper71
reaper71's Avatar
these two are of fitting the panel and getting it tacked in.
i did not show it but i made a panel that was welded in from the backside to block off the vent.
Old 10-20-2014, 09:43 AM   #62
reaper71
reaper71's Avatar
these next few shots were of welding all done and the metal finish done. the last pic (real fuzzy sorry!) shows the block off plate over the vents. and the inner panel that needs to be replaced.
Old 10-20-2014, 09:45 AM   #63
reaper71
reaper71's Avatar
#2 pic.
Old 10-20-2014, 09:47 AM   #64
reaper71
reaper71's Avatar
#3 pic
Old 10-20-2014, 07:09 PM   #65
Advanced Design
The butt weld came out really nice! Well done!
Old 10-20-2014, 08:17 PM   #66
reaper71
reaper71's Avatar
Thanks A.D.
Old 10-21-2014, 09:26 AM   #67
reaper71
reaper71's Avatar
This is of the new panel i made for the inner kick panel.
Old 10-21-2014, 09:28 AM   #68
reaper71
reaper71's Avatar
The panel all welded in.
Old 10-21-2014, 09:31 AM   #69
reaper71
reaper71's Avatar
This is the new toe board I made..
Old 10-21-2014, 09:35 AM   #70
reaper71
reaper71's Avatar
Toe board all welded in..
Old 10-21-2014, 09:37 AM   #71
reaper71
reaper71's Avatar
Quick shot of the repairs from the front..
Old 10-22-2014, 09:23 AM   #72
reaper71
reaper71's Avatar
This is the drivers side floor removed and shows the 2x4 tube witch is now my new cab mount. (has rubber under it)
Old 10-22-2014, 09:25 AM   #73
reaper71
reaper71's Avatar
Fitting the new piece viewing from passenger side.
Old 10-22-2014, 09:29 AM   #74
reaper71
reaper71's Avatar
Floor pan replaced and mounts all done
Old 10-22-2014, 11:57 AM   #75
69CST-V
69CST-V's Avatar
Looks great....keep it up.
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
