Old 01-26-2015, 07:25 PM   #51
lower50's
lower50's's Avatar
Re: My 52 GMC Build
I like this shot
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 01-28-2015, 05:49 PM   #52
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Made a switch box for the air ride out of stainless steel.
Also got the front clip body mounts made. I'm putting one on each side. Inside the fender.
1951 MG TD
Old 01-30-2015, 08:42 AM   #53
lower50's
lower50's's Avatar
Re: My 52 GMC Build
I'm soon going to start making my box. I have the front, a tailgate and the fenders, just making box sides and stake pockets. Can any of you guys give me the dimensions of the box sides. I know the box is 78" long and 50" wide. I need to know how tall the vertical sides are, how long the 45 degree angled part is, what the tube diameter is and top of fender to tube. Also dimensions of stake pockets
Thanks a bunch
1951 MG TD
Old 01-30-2015, 10:25 AM   #54
05snopro440
05snopro440's Avatar
Re: My 52 GMC Build
Thanks a bunch
Attachment 1356748
The bed height you should be able to find in here: GM Heritage Centre information pack
If you just want the heritage centre page, here it is.
The rest I'll let someone with the right year answer. My 46 has a different bed.
My 455 Buick powered '46 GMC Build Thread
My '46 GMC on Photobucket
05snopro440 is offline   Reply With Quote
Old 01-30-2015, 11:25 AM   #55
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks so much 05snopro440. I found a few dimensions gets me closer.
1951 MG TD
Old 01-30-2015, 01:26 PM   #56
yahoos
yahoos's Avatar
Re: My 52 GMC Build
Cool Build!
yeah buddy
yahoos is offline   Reply With Quote
Old 02-05-2015, 03:02 AM   #57
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Got my battery box's made. The battery's are 7.5"X 12"X 7.5" and are 50lb each. The outside of the box's are 50", so I can bolt the box side's right to them and gives me 1/2" extra for battery's. The sheet metal is to protect from tire projectiles and is 1/8" thick.
1951 MG TD
Old 02-05-2015, 11:28 AM   #58
05snopro440
Re: My 52 GMC Build
Attachment 1359314
Attachment 1359315
Attachment 1359316
Well, we know those battery trays won't fall off.
They look very robust, nice work!
Old 02-05-2015, 05:47 PM   #59
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: My 52 GMC Build
Nice work for sure! You'll want a stout battery box in case of a tire blow out. Keep up the great work!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 02-06-2015, 12:48 AM   #60
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Go big or go home right.
Thanks guys. The whole truck is coming along just the way I wanted.
I pick up my air tanks, compressors and valves tomorrow.
1951 MG TD
Old 02-06-2015, 11:14 AM   #61
jed971959
Re: My 52 GMC Build
nice build
did you get the box side measurements you needed
if not let me know I have my 49 box in my garage
I can get what you need
jim
jed971959 is offline   Reply With Quote
Old 02-06-2015, 08:43 PM   #62
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Originally Posted by jed971959 View Post
nice build
jim
Thanks Jim I did get what I needed. When I picked up my air compressors from "air assisted" today, they are working on a 1950 chev so I just measured it.
1951 MG TD
Old 02-06-2015, 09:50 PM   #63
Dieselwrencher
Re: My 52 GMC Build
What's your eta on the truck? You've got to be getting excited?
Ryan
Old 02-07-2015, 09:17 AM   #64
lower50's
lower50's's Avatar
Re: My 52 GMC Build
ETA: From my original goal, I have a year and a half left to get it done. Everything is coming together much faster than I originally thought, but still lots to do. Yes so excited !!!!!
1951 MG TD
Old 02-09-2015, 07:51 PM   #65
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Well I went to get my air goodies friday. They look so cool now I just have to mount them. They are Viair 480c compressors, 24" spun aluminum tanks (4gal) and Accuair VU4 valve
1951 MG TD
Old 02-11-2015, 10:47 PM   #66
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Got tanks, compressors, and valves mounted. Just a bit more pluming and some wiring and then test.
1951 MG TD
Old 02-12-2015, 06:56 PM   #67
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Got it all wired up today, then tested. Just one leek. The compressors are quite quiet up to 200psi, with 150psi in the front bags it lifts the truck 5.5" that should work. I can lift it up to that height without the compressors turning on too. Got all the wires and hoses close to where they will end up once I have the frame finished. The gauges will end up on the transmission hump in front of the shifter, once I have it built.
1951 MG TD
Old 02-17-2015, 09:08 AM   #68
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thought I would post the box side measurements I got, hope it will help someone.
Name:  box side 1.jpg
1951 MG TD
Old 02-18-2015, 12:09 AM   #69
Dieselwrencher
Re: My 52 GMC Build
It looks really nice! Are those viair 280's?
Ryan
Old 02-18-2015, 08:23 AM   #70
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks Dieselwrencher!! No they are Viair 480's 200psi
1951 MG TD
Old 02-18-2015, 01:50 PM   #71
Dieselwrencher
Re: My 52 GMC Build
Dang, that's sweet. I didn't see the post where you got them the other day for whatever reason. They definitely should be quick.
Ryan
Old 02-18-2015, 02:25 PM   #72
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Ya they are fast. Takes just over 1 min to fill my 8 gal from 165psi to 200 psi
1951 MG TD
Old 03-03-2015, 10:02 PM   #73
Firstgenfan
Re: My 52 GMC Build
Badass!!!!
Firstgenfan is offline   Reply With Quote
Old 03-05-2015, 12:15 AM   #74
rhd_c10
rhd_c10's Avatar
Re: My 52 GMC Build
Looks great
my rhd build.. http://67-72chevytrucks.com/vboard/s...d.php?t=468712
1964 CHEVROLET BISCAYNE 350CI/TH-350
1968 CHEVROLET C-10 SWB LS1/4L60E
rhd_c10 is offline   Reply With Quote
Old 03-06-2015, 06:13 PM   #75
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Been a while had to do some house and daily driver repairs.
Got my box sides bent up. Started trimming for wheel clearance.
Chopped 3" off the bottom of the fender to get it to the height I'm going with.
It's all just clamped now I had to see what it would look like.
The rear is being bolted to my battery boxes and brackets off the frame for the front.
1951 MG TD
bagged, build, diesel, gmc, hot rod
