Old 02-21-2015, 03:12 PM   #51
tim's68gmc
tim's68gmc's Avatar
Re: 1968 Gmc ground up restoration
Yesterday we got the engine set down on the chassis and it sure looks nice. Got the radiator core support sand blasted.
vehicle's I own 1968 gmc 3/4 ton camper special
1972 gmc jimmy
1972 Chevrolet nova
1947 ford 1.5 ton dully
1997 f-350 1 ton
2007 Chrysler 300 with hemi
tim's68gmc is offline   Reply With Quote
Old 02-23-2015, 10:15 PM   #52
tim's68gmc
tim's68gmc's Avatar
Primed and painted more parts over the weekend.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 02-25-2015, 09:17 PM   #53
tim's68gmc
tim's68gmc's Avatar
Well i started messing with the box today removed both wheel wells gonna replace them. When i was removing some of the old bolts i noticed that the back support had some welds driver side welds were cracked and missing the bolts to hold on the quarter panel nice. Question i have is are the welds from the factory or someone added them.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 02-26-2015, 12:39 AM   #54
swamp rat
swamp rat's Avatar
The welds are factory, all the fleet beds have them, usually you grind that off and unbolt a side to remove.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 02-26-2015, 12:39 AM   #55
leadfoot067
horsepower junkie
my 67 had welds in those locations...you gonna re-use that side trim?
67 short wide box,350/700r4/3.73posi
71 olds cutlass "S" mom bought new..12.30s@113MPH
leadfoot067 is offline   Reply With Quote
Old 02-26-2015, 09:53 AM   #56
tim's68gmc
tim's68gmc's Avatar
Ok thanks.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 02-26-2015, 09:54 AM   #57
tim's68gmc
tim's68gmc's Avatar
not sure yet if we are gonna reuse trim or no trim.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 03-02-2015, 11:22 PM   #58
tim's68gmc
tim's68gmc's Avatar
Today we started messing around with the drivers door and looks like I will be replacing the whole bottom of the door, of course it didn't look that bad when i bought the truck so I thought. gutted the door out and man the screws were rusty but didn't break a single screw. the track material broke into many pieces trying to remove it.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 03-16-2015, 09:49 PM   #59
tim's68gmc
tim's68gmc's Avatar
did some more sand blasting last week we have started moving on to working the sheet metal pieces. will be replacing the back end of the fender due to some one hammering in the rusty area and then filling with looked like a couple pounds of bondo.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 03-16-2015, 09:53 PM   #60
tim's68gmc
tim's68gmc's Avatar
Scored some great parts today, got what i would call rust free cab withe factory rocker panels. Also got a few nice pieces for the truck. The pictures are of the drivers side of the cab.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 03-16-2015, 09:56 PM   #61
tim's68gmc
tim's68gmc's Avatar
Passenger side of the cab and even has a slider window.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 03-16-2015, 09:58 PM   #62
tim's68gmc
tim's68gmc's Avatar
More pictures of the cab the inner cowling looks great
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 03-16-2015, 10:00 PM   #63
tim's68gmc
tim's68gmc's Avatar
No rust in the heater box area and no rust in the drip rails
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 03-16-2015, 10:04 PM   #64
tim's68gmc
tim's68gmc's Avatar
Scored the drivers inner wheel well for $20 at the swap meet last saturday. Today I got a fender, wheel covers for the box, a nice front wall for the box and a good fender which just needs a new front nose.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 03-16-2015, 11:41 PM   #65
leadfoot067
horsepower junkie
did you get that stuff at the 4x4 swapmeet? i only picked up a few small things...
Old 03-17-2015, 12:42 AM   #66
swamp rat
swamp rat's Avatar
Looks like a cab i seen in Olympia! I really think you should concider removing the outer rockers if you have not already, its amazing how much rust can be hidden on these trucks..
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 03-17-2015, 09:43 AM   #67
dads longhorn
dads longhorn's Avatar
Wow, I'm so impressed with all the work and progress made. Would you please do my truck next? If you want to share, what do you expect this restoration to cost? It's also nice that you have your own shop .
dads longhorn is offline   Reply With Quote
Old 03-17-2015, 10:59 AM   #68
tim's68gmc
tim's68gmc's Avatar
no didn't go this year. Got most of these from franks in oly.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 03-17-2015, 11:01 AM   #69
tim's68gmc
tim's68gmc's Avatar
i did get them from olympia. i will be checking into the rockers before i get to much into the cab.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 03-17-2015, 11:02 AM   #70
tim's68gmc
tim's68gmc's Avatar
thanks and i think i will be looking at around $10,000 to complete the truck i hope.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 03-17-2015, 06:44 PM   #71
collin70k/20
collin70k/20's Avatar
Awesome Project hope your having fun and the pics are great!
collin70k/20 is offline   Reply With Quote
Old 03-21-2015, 12:06 PM   #72
tim's68gmc
tim's68gmc's Avatar
We swapped the old green rusty cab for the nice white cab
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 03-21-2015, 12:19 PM   #73
Oly72C20
Looking good!
Oly72C20 is offline   Reply With Quote
Old 03-21-2015, 12:19 PM   #74
tim's68gmc
tim's68gmc's Avatar
After putting the cab on the cart we started taking everything out from under the dash which included two white lights that were hooked up to the door buttons. I personally have not seen this before. We also took out the a/c unit that was installed in place of the glove box.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
Old 03-21-2015, 12:22 PM   #75
tim's68gmc
tim's68gmc's Avatar
This is the a/c unit after we removed it.
1972 gmc jimmy
1972 Chevrolet nova
1997 f-350 1 ton
