#51 |
Re: New shop for the Blazer, truck, boat, camp, etc...
Awesome shop for sure.
#52 |
Thanks! More rain for this weekend, but next weekend looks promising for being able to move in and wire it up. I'm keeping my fingers crossed.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
#53 |
I'm green with shop envy... That thing looks killer.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint "Cool ain't ever cheap and cheap ain't ever cool" |
#54 |
I guess I need to play catch-up for a bit. The weekend before Easter I didn't get anything done on the Blazer, but I did get a pile of dirt that was behind my shop moved up to the shop driveway to fill in low spots that were holding water. More importantly, without the pile of dirt behind the shop, I could use the brother-in-law's little tractor to finally install the A/C that I've had for almost a year! I need to do some more insulating in the shop to get the A/C to keep it really cool in there, but it is definitely an improvement, now that it is starting to get warmer.
#55 |
![]() Join Date: Jul 2012
The ac will be really nice this summer.
Is the ac a large through the wall self contained unit? Kinda like motels and some hotels have, though larger? I’ve never seen one. |
#56 |
![]() Join Date: Apr 2005
AC is nice! You will definitely be more productive,
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#57 |
Yes Doug, it is self contained but technically not through the wall. These units are typically used in industrial settings and only require a hole in the wall for the return and supply ducting. I just cut the hole big enough to fit the whole unit because of the corrugation of the tin making it harder to mount it flat to the wall. It is a 5 ton unit and all I had to do after mounting it was run 220V power and wire up a thermostat. I used a wi-fi enabled thermostat so that when I am coming home from work in TX, I can use my phone to start cooling off the shop.
Rob, it definitely helps!
