Old 03-14-2016, 10:05 PM   #51
Arts712828
Re: 1988 Gmc crew cab build
I am going to run 265 40 22's over all size is the same as 235 85 16
Arts712828 is offline   Reply With Quote
Old 03-16-2016, 10:17 PM   #52
Arts712828
Well the hard part is done now to clean and start to put it back together
Old 03-23-2016, 11:49 PM   #53
Arts712828
Well if all go's right the motor will be in this weekend , Lot's of work finding all the parts to move the ac and alternator up and make some parts, also nice to know that with the after market motor mount that with the 47rh trans will sit right on the trans cross member with out having to move it at all just used a stock 4 speed auto trans mount, This is such a easy swap todo.
Old 03-24-2016, 11:47 PM   #54
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Truck is gonna be a beast
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 03-26-2016, 09:16 PM   #55
Arts712828
And bamm it's got a cummins in it !!!!!
Old 03-27-2016, 12:10 AM   #56
COS399
COS399's Avatar
Looks good.
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 03-27-2016, 11:36 PM   #57
918733
Did you have to make any firewall mods
http://67-72chevytrucks.com/vboard/s...d.php?t=616455My 55 first series build
918733 is offline   Reply With Quote
Old 03-28-2016, 07:36 AM   #58
Arts712828
did not have to mod the fire wall , with the motor mounts I got it sits on the stock chevy fraim horns and didn't have to move the trans cross member , just had to use a trans mount for a 4 speed auto to get the mount to bolt to the 47rh trans
Old 03-29-2016, 10:50 PM   #59
Arts712828
Ok have a have a question about these trucks. The vacume line the run the heater controls , that is like the size of a pincle lead , dose it also feed the cruise control ?
Old 04-03-2016, 12:38 AM   #60
COS399
COS399's Avatar
I'm surprised that nobody has chimed in yet. Mine doesn't have cruise control so I'm not sure. Sorry.
Old 04-08-2016, 12:26 AM   #61
Arts712828
Man I tell ya all this little stuff to make this motor work is killing my time frame and pocket book
Old 04-08-2016, 01:03 AM   #62
ruffrida2005
I hear ya. I thought about doing a 12 valve or 6.0 swap. But then I decided I have a good 454 already in the truck.
Paul
Old 04-09-2016, 11:40 PM   #63
75Dually
75Dually's Avatar
Just read throught your forum. This is going to be a killer truck. Seriously dig the interior! How far are you going to lower it? Whay other plans do you have for it?
75Dually is offline   Reply With Quote
Old 04-10-2016, 05:03 PM   #64
Arts712828
Going to do a 3,4 drop on it still want to tow and put a small camper on it
Old 04-10-2016, 05:10 PM   #65
75Dually
75Dually's Avatar
You can tow and put that camper on it even better with a bagged truck. More overall control and easier to load and unload.
Old 04-18-2016, 10:18 PM   #66
Arts712828
Well still working on the little stuff to get this thing rolling , I am down to a fan shroud , and shift linkage and the exhaust finding I will have to custom make a down pipe out of a 1st jen pipe them we will make some noise.
Old 04-24-2016, 11:01 PM   #67
Arts712828
Well after having to put a new lift pump on it we have a running truck again, wow what a lot of little **** to make this a runner, Had some kids tell me they wanted to do the same thing to there truck I told them they need at lease $5000 and time to do this swap, now just to get some exhaust put on it and start driving it . Here a pic with the new grill and hid head lights
Old 04-24-2016, 11:14 PM   #68
COS399
COS399's Avatar
Looking good. I would recommend dropping your tanks, removing the electric fuel pumps and extending the draw straw if you haven't done it. Keep us posted with updates.
Old 04-24-2016, 11:19 PM   #69
Arts712828
all read did the tanks
Old 04-24-2016, 11:26 PM   #70
COS399
COS399's Avatar
Ok. That tan interior looks really nice.
Old 04-29-2016, 12:15 AM   #71
Arts712828
well did some short trips and all went well so tomorrow I will put 100 miles on it driving to work and home hope all go's good the boss will be pissed if I am late
Old 04-29-2016, 03:07 AM   #72
345HP87SSAC
The interior shots look great!!!!
345HP87SSAC is offline   Reply With Quote
Old 04-29-2016, 07:13 AM   #73
BigBlockBurris
BigBlockBurris's Avatar
The truck and swap are AWESOME!!!!!
What motor mounts did you use?
Thanks!
BBB
BigBlockBurris is offline   Reply With Quote
Old 04-29-2016, 07:28 AM   #74
Arts712828
The motor mounts I used were from crossmember.com
Old 04-30-2016, 12:59 AM   #75
Arts712828
well after the trip today I have some thing to work on , regear the rear diff 4.10's way to low truck only will do 55 , new cooling fan thats not bent , fan grazed the radiator and now it leaks , and service the trans I think the filter is some what pluged up , shift good at slow speed but on the freeway slips in 3rd at high rpm , and there is some random knocking noise from under the truck
