08-21-2016, 01:04 PM | #51 |
Re: 49, bagged, 6.0, patina, the works
Thanks! Its a small studio apartment up top but its comfortable for me. Ceilings are 12" if I remember correctly.
'49 3100 Build | 6.0 LSX, bagged, patina, the works |
08-21-2016, 01:14 PM | #52 |
Hey Nick it's looking great! Did you fab your rear notch and bag mounts yourself? Funny thing about the Code504 kit . I called them and the girl I talked to said they don't recommend bags. Knowing what you know so far any idea why? She told me the kit drops the body 2 inches. That seem about right to you? Thanks for all the pics!
08-21-2016, 02:03 PM | #53 |
Stance looks really good there Nick!
08-21-2016, 05:02 PM | #54 |
Awesome progress so far man for sure gonna follow this one man
big_moss bagged 51 3100 build |
08-21-2016, 08:10 PM | #55 |
FWIW, I have a lift in my shop with only an 8 foot ceiling.
Rob
My '47 C.O.E build |
08-21-2016, 10:38 PM | #56 |
Yeah, but didn't you cut holes in the ceiling or similar for it to clear? I was mostly amazed that a tuck-under garage under a house would have that tall of a ceiling!
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
08-29-2016, 06:21 AM | #57 |
The truck looks amazing!!
09-09-2016, 03:52 PM | #58 | |
09-22-2016, 09:37 AM | #59 | ||
Its 100% doable (as you can see haha) but I'm guessing thats why they don't recommend it. As far as the body drop, its hard to tell because I never set the truck up on the frame on a stock suspension setup. I started fabbing up the rear shocks/mounts the other day. Ill get some photos once I have the drivers side shock installed. For now, one of me looking like I have no clue what I'm doing (true statement).
09-22-2016, 09:41 AM | #60 | |
Quoting this to this page so everyone can see what the truck looks like as of right now.
09-22-2016, 09:53 AM | #61 |
Looking good...
Mark...
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
09-24-2016, 12:15 PM | #62 |
Is there a lot of adjustment with the kit, or will you have to modify the kit to move the cab back?
10-18-2016, 10:10 AM | #63 |
looks great so far! I saw on another thread that he put spacers on the front to widen the stance. do you think yours needs it?
10-18-2016, 11:15 AM | #64 |
Hi Nick!
Nice build, don't know how i missed it before now. My TF is also getting a 6.0. It's an LQ4 out of an Isuzu box truck that was totaled at 81,000 miles. Because it came from that I got a 4l85e trans. Not sure if the 80 vs. 85 trans is any different externally? I'm being told the 85 is a bit stronger for the heavier loads the NP van carried but I don't know in what specific way. The Trans does stick up a bit more in the cab but a factory stock 4 speed trans floor cover will handle it instead of the stock 3 speed cover. Looking forward to seeing how you finish your engine's "look"? Right now I am planning to give my engine a conventional SBC look using a Holley intake and Delmo valve cover adapters with Mooneyes or Edelbrock finned valve covers and a large/tall foam air cleaner. But of course this could all change as it gets finalized. Best, Dan
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
10-20-2016, 08:17 PM | #65 | |||
As far as finishing the motor, I'm a big fan of the "modern look old truck" style so I plan on using the plastic vortec engine cover to clean things up and hide the intake mani. Although, I REALLY do like Delmo's line of products to make these things look like a true SBC. I'll be sure to follow your build!
10-21-2016, 09:15 AM | #66 |
Hey Nick, Liking the build.
To save fabrication time of having to make a new tunnel you could go with the floor mount shifter from lokar like the one below. I used this style on Blakes 67 and will not go back to the tail mounted one again! It saves alot of room and if the body ever has to come off you just take off your linkage and the shifter stays with the rig. I already bought one for Orangepeel just my 2 cents. Mark...
10-25-2016, 08:40 AM | #67 | |
10-25-2016, 09:07 AM | #68 |
It's always good when you can direct it where to go without having to kick the tires.
If you have any other questions feel free to PM me, I've worked on a few of these. What is your plan for the dash....stock or custom? Mark...
10-25-2016, 09:11 AM | #69 |
Haha thats the story of my life for the past 3 years. I most definitely will, thank you. Dash will be stock with all dakota digital goodies and painted probably an off white along with the remainder of the interior and the wheels.
10-26-2016, 09:48 AM | #70 |
This is the Dash and steering wheel I did for mine, all hand made.
I was just curious to see what other Guys are doing on the interior. Mark...
12-10-2016, 08:28 PM | #71 |
Have you made any progress recently?
01-17-2017, 12:47 PM | #72 |
I got sidetracked with another small build which is now sold and will fund the rest of this build. Really excited to place a big order here to attempt to finish this thing by July.
Would love to see some different steering shaft ideas when it comes to LS's within S10 chassis. I have an idea but am open to different options.
01-25-2017, 05:02 PM | #73 |
Intake Manifold disassembled waiting for new injector orings and a few other things before reassembly. Also added purge solenoid block off.
Finished the other rear shock mounting. Suspension is all done for now. Nissan d21 hardbody shocks worked out to be the perfect amount of travel Tons of parts coming in the mail so this weekend should be big progress. Motor will be completely reassembled with accessories/intake mani/headers and dropped back between the frame rails. Speedway upper control arms came today and the rest of all the new steering components should be here this weekend minus the notchless tie rods from MMW. Once the motor/steering is in, onto the fuel system.
01-25-2017, 09:41 PM | #74 |
I was planning on running the Proforged S10 steering setup- but I am running drop spindles and close to the same drop setup as you. What's the deal with notchless tie rods? Are they necessary with drop spindles?
01-25-2017, 10:33 PM | #75 | |
S10 NO NOTCH / NO TOE STEERING SYSTEM I'm running it on my static S10 Blazer and Bagged 49 3100 on S10 chassis. It's a great piece. |
