Old 08-13-2016, 05:34 PM   #51
HeloCrewChief
HeloCrewChief's Avatar
Re: 55 C4 Suspension/Nailhead Build
Made a little more progress. I'm now waiting on my headers to come in and for my rack & pinion to come back from being converted to a manual application. I ordered new cab mounts, window regulators, and one piece window kit. Got everything in except the window kit which is on back order. I also had Fleetpride make me a new driveshaft. Set the Cab on the frame and I'm so happy with the stance. I was afraid it was going to sit really low which is not what I was after.
1970 C10 to K20 conversion
1974 GMC Jimmy
1968 50th Anniversary Short Bed
1968 Chevelle
1964 Comet Caliente
1990 W250 Cummins
HeloCrewChief is offline   Reply With Quote
Old 08-13-2016, 05:37 PM   #52
HeloCrewChief
A few more
1974 GMC Jimmy
1968 Chevelle
1964 Comet Caliente
1990 W250 Cummins
Old 08-13-2016, 07:00 PM   #53
Kim57
Kim57's Avatar
Looking real sharp.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 08-13-2016, 07:43 PM   #54
jjzepplin
jjzepplin's Avatar
Absolutely loving this build!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 08-13-2016, 08:27 PM   #55
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Looks good!
ChuckDriver is offline   Reply With Quote
Old 08-13-2016, 09:35 PM   #56
murd969
Looking good. I like the build.
1956 Chevy 3100 C4 Suspension Build
Instagram: murd969
murd969 is offline   Reply With Quote
Old 08-14-2016, 09:09 PM   #57
HUSSEY
HUSSEY's Avatar
Cool build and I commend you on your unique engine selection...not just another SBC (like my current motor) or LSX (like my future motor). I always though those motors just looked cool with the way the valve covers sit on them.
My 49 AD Build / S10 Chassis -- Thread -- Pictures -- S10 Conversion Mounts
HUSSEY is offline   Reply With Quote
Old 09-11-2016, 12:42 PM   #58
HeloCrewChief
Cot my transmission dip stick situated as well as the coil mounted. Not too happy with the coil mount but, was limited on where I could mount it and still have linkage and distributor clearance. I also got the new plug wires ran along with the MILR plug wire covers. The Sanderson headers were a great fit and curious to see how their no gasket design works. Still waiting on my rack & pinion and steering column. I'm having a little trouble with the CPP brake booster pedal clearance which I outline in another thread but, I think I'm close to a solution.
1974 GMC Jimmy
1968 Chevelle
1964 Comet Caliente
1990 W250 Cummins
Old 09-11-2016, 01:35 PM   #59
Kim57
Kim57's Avatar
Looks real sharp.
Kim
My build thread
Old 09-11-2016, 04:02 PM   #60
ChuckDriver
Very cool!
Old 09-25-2016, 08:31 PM   #61
gotmotors
gotmotors's Avatar
What great build. Man that's a nice mill, can't wait to hear it with the headers and injection.
On the rear sway bar you may have to notch the last bed sill so the arms of the sway bar don't hit on compression. It will fit just fine under the bed wood. I have a similar setup.
Jim
My 55 build
http://www.trifive.com/forums/showthread.php?t=97044
gotmotors is offline   Reply With Quote
Old 11-18-2016, 12:36 PM   #62
HeloCrewChief
All the brake lines and hoses have been ran and hooked up. Feels great to have that part out of the way. Also installed my alternator bracket and alternator. The bulk of the fuel line has been ran as well. I got my weber setup back from Jim Inglese and the linkage and fuel hose is all set up and ready to go. He also rejetted them and he says I should just be able to fire it up and go with minimal adjustments. I need to figure out a rear bracket for my transmission kickdown and throttle cable to sit into. Still waiting on my rack and pinion which has been a bummer.
1974 GMC Jimmy
1968 Chevelle
1964 Comet Caliente
1990 W250 Cummins
Old 11-18-2016, 06:44 PM   #63
Kim57
Kim57's Avatar
Looks good.
Intake set up is very cool.
Kim
My build thread
Old 11-18-2016, 10:29 PM   #64
Advanced Design
Advanced Design's Avatar
Impressive! Nice brake lines too.
Advanced Design is offline   Reply With Quote
Old 11-23-2016, 05:58 AM   #65
RockinKees
RockinKees's Avatar
Very nice indeed!!!
Beautiful engine!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 12-14-2016, 11:32 AM   #66
murd969
Your build looks great. I used the C-4 front and rear suspension on mine. I narrowed the rear 2.5" which allowed me to run 20x10 wheels with a 5" backspace. It was definitely worth narrowing to allow the wider wheels.
Instagram: murd969
Old 12-27-2016, 08:08 PM   #67
HeloCrewChief
Made a little more progress. I received my rack & pinion back so, just waiting for my paint to dry on it so, I can throw it in tomorrow. I also received my radiator but, I'm having some difficulty getting it installed with the supplied brackets. Will also have to track down an ultra slim electric fan as I only have about 2" of clearance between radiator and pulley.
1974 GMC Jimmy
1968 Chevelle
1964 Comet Caliente
1990 W250 Cummins
Old 12-28-2016, 10:51 AM   #68
Kim57
Kim57's Avatar
Looking real nice.
Kim
My build thread
Old 12-28-2016, 04:04 PM   #69
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
AMAZING! Truck looks killer buddy
--Josh
Old 12-28-2016, 08:04 PM   #70
HeloCrewChief
Steering column in and just loosely threw the steering wheel on to get an idea of how it will feel in the cab. I like how it feels but, will not finalize the steering column position until my seat arrives. I think the 15" Corvette wheel is a nice touch of old and new and the flatness puts the steering wheel further away from me which I like.
1974 GMC Jimmy
1968 Chevelle
1964 Comet Caliente
1990 W250 Cummins
Old 12-28-2016, 08:06 PM   #71
HeloCrewChief
Lower column mount.
1974 GMC Jimmy
1968 Chevelle
1964 Comet Caliente
1990 W250 Cummins
Old 12-28-2016, 08:06 PM   #72
Kim57
Kim57's Avatar
Nice wheel.
Dash is sweet.
Kim
My build thread
Old 12-28-2016, 10:54 PM   #73
ChuckDriver
Vette wheel looks nice!
Old 12-29-2016, 06:07 AM   #74
RockinKees
RockinKees's Avatar
Nice nice nice!!!
But that dash......Awesome!!
Cheers!! Kees.
Kool Guyz CC
Old 01-28-2017, 09:44 PM   #75
HeloCrewChief
Purchased a rust free bed and pair of doors last week. Got a chance to test fit the bed. I will not need to tub the bed! I test fit it with a set of 15x8 wheels and 275/60/15's with 4.75 BS. I have about 1" on either side of the tire. I will need to relocate one bed brace as it hits the sway bar.
1974 GMC Jimmy
1968 Chevelle
1964 Comet Caliente
1990 W250 Cummins
