Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 09-01-2016, 09:01 PM   #51
rayray767
Re: 1972 Medium Blue Highlander Blazer Resto
Nice one Pete ! I'll be watching
rayray767 is offline   Reply With Quote
Old 09-01-2016, 09:58 PM   #52
IronCanine
I'm trying....
IronCanine's Avatar
This is a great service Pete. Let me add my Kudos and Thanks.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 09-04-2016, 12:53 PM   #53
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks guys for the good words and for following along. Here are some additional pics - sorry for the poor handwriting
DeadheadNM is online now   Reply With Quote
Old 09-04-2016, 12:54 PM   #54
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Harness grounds...
Old 09-04-2016, 12:57 PM   #55
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Hoses (upper rad is from my K1500 - OEM hose was on the Blazer but the p/n was too faded to photo)
Old 09-04-2016, 01:00 PM   #56
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Zip ties and heater hose bracket at RH fender
Old 09-04-2016, 01:03 PM   #57
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Steering damper at tie rod. Factory install for 1972 MY only. Measured from end of tie rod tube itself. Location of gear ratio tag at front differential. Misc other under hood pieces.
Old 09-04-2016, 01:07 PM   #58
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Gas pedal/cowl related...
Old 09-04-2016, 01:08 PM   #59
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Wiper arms...
Old 09-04-2016, 04:00 PM   #60
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Excavated the build code on the transmission: Y2B 08D . By my reading it's a Cleveland (Y) built TH350 from 1972 (2) February (B) eighth day (08) from the day shift (D). As such, the date fits for the original transmission and helps to support a February 1972 assembly month for the Blazer.
The engine block code is V0207TFJ and breaks down as follows: Flint (V) built in February (02) seventh day (07) 350 cu in for c/k pickup 4bbl application with automatic transmission (TFJ).
Old 09-04-2016, 07:07 PM   #61
rayray767
Very educational photos you got there Pete.
Thanks for taking the time to lay everything out like that
I'll be saving these photos into my notes
I think others will be doing the same ...
Old 09-05-2016, 10:19 AM   #62
OLDYELLOW
OLDYELLOW's Avatar
Agree, very valuable info. Thanks!
OLDYELLOW is offline   Reply With Quote
Old 09-05-2016, 07:46 PM   #63
skrenly
skrenly's Avatar
I see another TOTY in the making.
skrenly is offline   Reply With Quote
Old 09-23-2016, 03:06 AM   #64
1972BackInBlackC10
1972BackInBlackC10's Avatar
following this build
1972BackInBlackC10 is offline   Reply With Quote
Old 09-25-2016, 07:39 PM   #65
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks for following along and all the good words!
Finally able to pull the motor and tranny - will have both rebuilt and reinstalled. I've kept them bolted together and am using the depicted Moto-Feet stand (USA made) with rubber casters to wheel them about the garage.
After pulling the Blazer to the concrete pad I realized that my tow hook was flipped the wrong direction - doesn't work as well that way
Old 09-25-2016, 07:44 PM   #66
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Here's a summary photo of the clips used to affix the fuel/brake/charcoal can lines to the frame. Also included is an example of the harness clips used along the LH frame rail
Old 09-25-2016, 07:53 PM   #67
DeadheadNM
Carpe manana
DeadheadNM's Avatar
The re-plated parts turned out well. Here are some examples. I've got the bumpers, trim strips, t-case shift handle and a few other parts in El Paso now for chrome plating.
Old 09-25-2016, 07:54 PM   #68
DeadheadNM
Carpe manana
DeadheadNM's Avatar
More
Old 09-25-2016, 07:58 PM   #69
DeadheadNM
Carpe manana
DeadheadNM's Avatar
It seems the case that OEM inspection covers for the TH350 during at least the 72 model year were plastic. Here's an example - that removed from my blazer is the same.
Old 09-25-2016, 10:23 PM   #70
gringoloco
A guy with a truck
gringoloco's Avatar
Same on my '72
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-03-2016, 09:10 PM   #71
1972 Jimmy
1972 Jimmy's Avatar
Pete,
Project looks awesome!
I was wondering if you can send me contact information to the company that did the zinc plating for you.
I want to get a couple pieces of my own done. :-)
Eric
1972 Jimmy is offline   Reply With Quote
Old 10-03-2016, 11:59 PM   #72
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks Eric! PM sent...
Old 10-08-2016, 09:33 PM   #73
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Baby steps.
A friend traveling to El Paso was gracious enough to transport some items for chrome plating, which were completed this week. Steve, one of the front bumpers is that from your ochre C30 truck. The rear panel trim and NP205 shift handle turned out nice.
Also go the Blazer off to the body shop. Anxious to see what's under the paint.
Old 10-08-2016, 10:32 PM   #74
IronCanine
I'm trying....
IronCanine's Avatar
Looks good Pete. Seems like big steps to me.
Old 10-13-2016, 12:18 PM   #75
bambbrose
Looking forward to watching the body work progress. I would love to have this specific color combo, and a highlander to boot. Great choice for a resto.
bambbrose is offline   Reply With Quote
