Old 03-10-2020, 04:49 PM   #51
Hart_Rod
Hart_Rod's Avatar
Re: This Dummy Needs a Headlight Buzzer
Originally Posted by TKCR View Post
I’m usually in the yards once the weather warms up. Problem is, I’m after seats and interior parts, and I never get around or forget to grab these. I will try and remember these this year. They are super easy to remove.
Thanks! Any recommendations on getting a good quality cloth seatcover for my 87 bench seat?
Hart_Rod is offline   Reply With Quote
Old 03-10-2020, 05:28 PM   #52
TKCR
TKCR's Avatar
Sent you a PM
Old 03-14-2020, 09:02 AM   #53
Hart_Rod
Hart_Rod's Avatar
I finally picked up a module and installed it last night. It works great! Thanks for the tip!
Old 03-14-2020, 12:35 PM   #54
TKCR
TKCR's Avatar
Old 07-26-2021, 01:33 PM   #55
Hart_Rod
Hart_Rod's Avatar
I acquired a couple more trucks. Anyone got a couple more of these modules laying around?
Old 07-26-2021, 04:22 PM   #56
LDO
LDO's Avatar
Let me check my parts bin. I believe I can hook you up my friend!!
LDO is offline   Reply With Quote
Old 07-26-2021, 05:50 PM   #57
Wgesnerjr
Wgesnerjr's Avatar
I had a couple of these from different cars. 91-96 Caprice/Roadmaster and 93-02 Camaro/Firebird
Some had a solid tone sound while some had a ding-ding sound. I prefer the ding-ding sound over the tone one.
Also one of the Roadmaster ones I found had a separate plug for the Turn-signal minder. I used it and just cut the extra plug off and still works great.
FYI - I put it in my '85 Custom Deluxe and it was already wired for it. Just snapped in and worked. My buddy was so impressed that we wired one into his '74 Camaro! That was more wiring than just snapping it in!!
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 07-26-2021, 06:19 PM   #58
LDO
LDO's Avatar
Sorry Rob. Didn’t find any in my stash of parts. Guess I gave them all away already. Sorry I couldn’t help.
Old 07-27-2021, 10:55 AM   #59
Hart_Rod
Hart_Rod's Avatar
Thanks for looking Bob!
Do you have any left?
Old 07-27-2021, 10:58 AM   #60
Wgesnerjr
Wgesnerjr's Avatar
I don't think so.
Next time I'm at Pull a Part, I will look for one.
Jay Gesner
Atlanta, GA
LS 5.3, 4L60E
Old 07-27-2021, 07:19 PM   #61
Hart_Rod
Hart_Rod's Avatar
I don't think so.
Thank you! Pull a parts here have nothing...🙄😩
Old 07-27-2021, 07:51 PM   #62
VWNate1
VWNate1's Avatar
Question A Possible Solution :
Take the GM part number and try junkyarddog.com or Amazon, The bay of E etc....
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
Old 09-21-2021, 01:33 PM   #63
TKCR
TKCR's Avatar
Just saw one on eBay
https://www.ebay.com/itm/88-94-Chevy...-127632-2357-0
Old 09-21-2021, 07:34 PM   #64
Hart_Rod
Hart_Rod's Avatar
Purchased. Thanks!
Old 09-21-2021, 09:38 PM   #65
TKCR
TKCR's Avatar
Purchased. Thanks!
Your welcome.
Old 09-15-2023, 08:14 PM   #66
1774btcrew
1774btcrew's Avatar
Originally Posted by hatzie View Post
GM integrated this function into the seatbelt warning buzzer along with the key in the ignition with driver door open buzzer.
The Headlamp warning option is RPO T63.
The "extra wire" in the RPO T63 equipped trucks is from the instrument panel lamps. I believe the ground is from the key inserted switch in the column.
I know this is a super old thread but I know you know wiring better than anyone else on here. Do you know what year c10s that this is a direct plug and play? I am guessing the 1981 and newer squares but it would be nice if it worked on some of the other ones. As usual, thanks for your knowledge in advance.
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 09-29-2023, 11:33 AM   #67
Hart_Rod
Hart_Rod's Avatar
Anyone know the part number for the "Ding dong" modules? The solid ton is extremely annoying...
Old 09-29-2023, 07:14 PM   #68
hatzie
Moderator
hatzie's Avatar
At least as far back as 1976 the seatbelt and key-in-ignition buzzer could be outfitted with the headlamp warning.
You'd have to add the wire from the parking lamp side of the headlamp switch to the buzzer jack IIRC.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 10-03-2023, 07:31 PM   #69
62K10newb
Originally Posted by ron350 View Post
This is how I have a 22535998 chime module hooked up on my 75 C10 to let me know that my lights are still on.
When I open the door with the head lights or parking lights still on the module will chime. I had to hook this up after coming out of stores to find a dead battery because I forgot to turn the lights off.
Run a wire from the door jamb ground switch to pin 3 and over to pin 6 on chime module.
Run another wire from the top plug on the head light switch to pin 7 on the chime module.
The top pin on the head light switch has 12 volts on it when the parking lights or headlights are on.
By using the door jamb switch as ground for pin 3 & 6 the module does not need 12 volts constant power to make a chime.
Found a 7-pin model on eBay (22533568), wired it up on my 62’ K10 as described and I now have a nice chime for my headlight warning.
Thanks for all the help.
62K10newb is offline   Reply With Quote
