Old 03-26-2017, 08:28 PM   #51
vin63
It's Better With Nitro
vin63's Avatar
Re: What did you do to your truck today part IV
Did the initial trimming of the carpet and temporarily laid it in place to check on a few contours that still need to be smoothed out with the heat gun.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 03-26-2017, 09:54 PM   #52
rvrfoot
Installed my new pulleys.Name:  DSCN0779.jpg
rvrfoot is offline   Reply With Quote
Old 03-27-2017, 02:55 PM   #53
Northwest Outlaw
Northwest Outlaw's Avatar
Finished fabricating and installed my new exhaust, reinstalled freshly painted grille after adding middle insert "Chevrolet" piece that was missing.
Video: https://youtu.be/XyORTgEMcdA
1961 Chevy Apache "BoomStick"
-First build, lots of plans, little experience. What's the worst that could happen?
http://67-72chevytrucks.com/vboard/s...d.php?t=694506
Northwest Outlaw is offline   Reply With Quote
Old 03-29-2017, 08:34 AM   #54
Victweezy
Hey guys, I'm new here!
Thought I might share a bit from my current build. It's a 60 C10 with the hog nose hood, 383 SBC with a BDS 6-71 blower backed up by a 700r4 that is all beefed up to handle the torque.
I'm well into this build and have been plagued by leaky brake lines that has cost me lots of time. Today I managed to get the proportioning valve to stop leaking, finished up the power steering pump and some of the tubing for it, fabricated a tensioner for the alternator, set up the geometry for the TV cable, and installed the speed chain. It's ready for the front clip to be installed now. That will be tomorrow.
Today was day 9 of wake up, thrash all day until it's time to work, work all night, chug a beer, sleep for a few hours, repeat.
Victweezy is offline   Reply With Quote
Old 03-29-2017, 02:08 PM   #55
wolfsden
wolfsden's Avatar
Looking great!
1963 Chevrolet C-10
wolfsden is offline   Reply With Quote
Old 03-29-2017, 11:14 PM   #56
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Painted up the starter for the 292 today.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 04-02-2017, 11:38 AM   #57
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Didn't get a chance to post yesterday, but I got the interior firewall and cab floor primed and painted.
Old 04-02-2017, 01:12 PM   #58
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Stripped Clyde down yesterday for some paint work and metal repair.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-02-2017, 02:28 PM   #59
Railroadman
Railroadman's Avatar
Finally got the intake manifold off the 283. One of those 20 minute jobs that took far longer - had 2 bolts rounded off and hard to get at.
Can already see the next "fun" - tried a couple lifters, and they don't want to come out of the bores. Not sure yet how bad the bottoms are mushroomed over. The truck itself has either 247,000 or 347,000 on it and I have no idea what work, if any, the engine has had over the years.
But that's what makes it fun!
Railroadman is offline   Reply With Quote
Old 04-02-2017, 06:49 PM   #60
forestb
forestb's Avatar
Yay got new tail light brackets installed. Boo the tail light don't work. The blinker and the break light do but the not the tail lights. I think it is not getting a good ground but am not sure.
forestb is offline   Reply With Quote
Old 04-03-2017, 08:02 AM   #61
Victweezy
Most importantly, I got it started for the first time with this engine!
What didn't I do this weekend would probably be a better questions. Because I made all the AN lines, installed power steering, Wiring, dimpling, wrapping, bracket making, more wiring and throttle linkage, rad plumbing, installed the starter, seats and dog house, exhaust, and only a bit of tuning... I took Friday off work to try to get out on the road that night for a cruise, and was derailed by a leaking thermostat housing, and a dead battery. Had to do the push of shame one last time back into the garage.
But as you can see the front clip got installed too. Today when I wake up it's time to tune it up, and she should be on the road again.
Thinking I'm going to rock it with out a hood for a bit, so I don't have to cut up the double hump hood just yet.
Old 04-03-2017, 03:30 PM   #62
Northwest Outlaw
didn't fix my alternator issue, so i didn't drive to the car club BBQ...
Old 04-10-2017, 07:11 PM   #63
Northwest Outlaw
Figured out the problem, the '61 dash wiring didn't have the resistance wire circuit for the '63 external regulator wiring. Once i go to the bottom of the problem i tried to make my own patch, and smoked out the regulator. Went with the internally regulated, single wire alternator. Took the front wiring harness and stripped out the un-needed wires, re-taped and have half the bulk with just the horn relay
Then i drove her around all afternoon for the longest driving session with the new engine, trans, suspension and brakes.
https://youtu.be/tNjguboyxIs
Old 04-11-2017, 03:39 PM   #64
chevyfreek
chevyfreek's Avatar
Either that or he didn't wanna lay under the truck to replace the u-joint! HAHA!!
65 C20 "Marilyn"
65 VW Bug "Daisy"
95 4Runner "JoJo"
15 Tacoma "Taco"
Check out my Intsagram https://www.instagram.com/patpetrey/
chevyfreek is offline   Reply With Quote
Old 04-12-2017, 02:38 AM   #65
Victweezy
Well, the supercharger seized up on me during start up the other day... So it was off to a buddy's house who knows a thing or two more about blowers than I do. Found out blowers like to eat fuel, not metal... So after some minor "clearancing" of the case and rotors to remove the damage, I slapped it all back together and made the Maid Voyage after leaving some tire marks about 100 feet long. Two grown men, giggling like school girls as tire smoke billowed behind us.
It was a beautiful day for a cruise down to the local watering hole. She is a little more peppy now with this new 383, blower and tranny that isn't slipping in 2nd and 4th. This week is my car clubs big car show, so it was kind of important to get this thing wrapped up.
Old 04-12-2017, 11:24 AM   #66
forestb
forestb's Avatar
Who ever said that vw's cant be cool.
Old 04-12-2017, 11:40 AM   #67
coopdog
coopdog's Avatar
Originally Posted by shp4man View Post
I called in sick today- bad cold. It's raining here all day. Wife's new car usually occupies the garage, but felt the need to get Ol'Blue out of the rain.
should leave the rain on windows to dry, looks killer the way the wipers cut through water!!!!!! sweet truck
.................._____
__________//___{\____
/__---____//____/__---/
.....(O). ..................(O).
BUILD THREAD K20 http://67-72chevytrucks.com/vboard/s...d.php?t=651601 pages 2-4
coopdog is offline   Reply With Quote
Old 04-12-2017, 04:29 PM   #68
shp4man
shp4man's Avatar
Thanks!
Everybody has to believe in something. I believe I'll have another beer.
shp4man is online now   Reply With Quote
Old 04-14-2017, 08:44 AM   #69
robber grin
Technically it was yesterday... but I drove it to work.
robber grin is offline   Reply With Quote
Old 04-14-2017, 01:15 PM   #70
Northwest Outlaw
Installed a Sunpro Voltmeter in the already molested dash cluster. Had to widen the opening for this 2" gauge to replace a 1.75" Ammeter that was there before.
I also cleaned up the cluster harness on the back, removing unused warning lights and water temp leads, then taping it all back up so it's "tidy".
Luckily for me the truck came with an unmolested dash cluster that is fully intact if i ever want to go back to original.
Old 04-15-2017, 04:19 PM   #71
DPowers
DPowers's Avatar
Pulled it out of storage. Need to clean it up and get the my mirrors back on it.
DPowers is offline   Reply With Quote
Old 04-15-2017, 10:24 PM   #72
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
More sanding...hoping to prime tomorrow.
Old 04-16-2017, 05:48 PM   #73
shp4man
shp4man's Avatar
Finished respraying both doors. Dash is next.
Old 04-18-2017, 12:58 PM   #74
Backpayne
This weekend I finished installing reconditioned head and short headers on my 250, ran new exhaust outside of frame rails, and began fabricating brackets for seats I hot out of a suburban.
I did also give myself a nice bruise above my eye when I dropped exhaust pipe on it.
Backpayne is offline   Reply With Quote
Old 04-18-2017, 01:36 PM   #75
siggyfreud
siggyfreud's Avatar
Made progress on the 4-link install:
siggyfreud is offline   Reply With Quote
