07-03-2018, 06:52 PM | #51 | |
Re: Palf's 1981 GMC
So to speak. |
07-06-2018, 03:39 PM | #52 |
Re: Palf's 1981 GMC
Been beating my head a while on this AC stuff, but I think I finally found the issue with the new compressor. From measurements and visdual you can see the factory recommended belt is too skinny. The 3/8" wide belt recommended would sit at the bottom of the compressor pulley and never touch the sides. It actually shock/wobbled in the pulley, causing it to screech,slip and eventually break.
I replaced it with a 1/2" wide V-belt and it fits the pully great. works on the engine pulleys also. Hopefully you can see the difference in the pictures. So far it seems to be fine. I picked up some pusher fans that I also am going to run evenetually to help cool the condenser so it will cool even better.
07-06-2018, 03:42 PM | #53 |
Re: Palf's 1981 GMC
Next part of the week's projects was to install a factory front sway bar. It's not super huge (1 1/16") but way better than what was there. It really helps the ride/handling even with the small bar.
I also put on a new front air dam, the deeper 4x4 version. I think it really helped clean up the front end look.
07-06-2018, 03:54 PM | #54 |
Re: Palf's 1981 GMC
Last of the projects was fixing up the windshield wipers washer system. I had an old generic pump lying around, so I hooked it up. Even though I replaced the wiper motor too, I went with the generic one for 2 reasons. 1-my factory plugin connector would not plug into the washer motor. 2-I never really like the factory washer motors. They seem to die quickly .
The other thing I did was to get a set of wiper arms off an 86 (or 87...I can't remember now) C10. They have the washer squirters built into the arms and they had a much better blade connection method. I had to drill out/open up the little slot in the cowl to allow the hose to come thru. Other than that they go right on to the older assembly mounts. They work good. The 80's style wiper arm covers were on the truck so I reused them since I need to touch up the flat black paint on the lower portion of the wiper arms. Now back to driving it.
07-06-2018, 03:57 PM | #55 |
Re: Palf's 1981 GMC
You've been busy! But yeah the belt should never touch the bottom of the pulley, I'd bet that you have solved your problem.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
07-06-2018, 04:33 PM | #56 |
Re: Palf's 1981 GMC
Great work Bill, all good updates/repairs.
I need to do a washer motor and blower resistor in the daughter's pickup.
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
07-06-2018, 04:56 PM | #57 |
Re: Palf's 1981 GMC
Very good updates...and a nice diagnosis for the belt issue!
07-06-2018, 07:36 PM | #58 | |
Re: Palf's 1981 GMC
Thank you
07-07-2018, 09:50 AM | #59 |
Re: Palf's 1981 GMC
Thanks for sharing your up-sized belt idea. My compressor has a slight wobble/groan at idle that no amount of realigning has stopped. Maybe this is the fix.
Romans 10:9 - The Truth |
07-07-2018, 10:07 AM | #60 |
Re: Palf's 1981 GMC
Good stuff!
Just a Hillbilly in the Hood http://67-72chevytrucks.com/vboard/s...d.php?t=622194 |
07-07-2018, 02:32 PM | #61 |
Re: Palf's 1981 GMC
Cleaning up the shop mostly today, but did do one little update on the truck. Since the only thing running to it any more was the gas tank vent, I decided to remove the Vacuum/charcoal canister. Truck is a little slow filling, so figured the canister in its 37 years was a bit clogged, so out she went. That thing weighed a bunch. I can't ever remember getting a truck that still had one, so the weight kinda surprised me.
I added a motorcycle vent so that no dirt daubers or whatever gets in and clogs the vent line up. The fill is not real bad on the 81, but I had no fill issues at all on my 83 using the cycle vent, so hopefully this will improve it some.
07-07-2018, 04:17 PM | #62 |
Re: Palf's 1981 GMC
I was pondering this very issue this morning...great idea...gonna copy...
07-14-2018, 02:54 PM | #63 |
Re: Palf's 1981 GMC
07-28-2018, 05:53 PM | #64 |
Re: Palf's 1981 GMC
Beautiful and HOT day for a good cruise to a car show. Soooooooooooo glad I have AC. One of the car clubs was having a car appreciation day show north of here at a state water park. Lots of nice rides The GMC ran flawlessly. That swaybar sure helps the ride and handling. Few shots, plus the link to the photos I took today.
https://photos.app.goo.gl/LjqQ5WeVQCisVY9m8 Oh did I mention it is SO nice to have AC!
08-12-2018, 07:01 PM | #65 |
Re: Palf's 1981 GMC
Not much done on truck lately. between woeking on wife and son's cars, plus the pilgrimage to my home land in Pittsburgh the truck rested. After visiting family a few days, we took the round about way to Mississippi thru Niagara Falls. My wife and son had never seen them. So we had fun on both sides of the falls.
First picture is a retreat near my sisters out side of Pittsburgh. Rest are at the falls. My son dangling in Canada. No issues except 3K+ miles in the baby bus (wife's CRV) in 8 days is rough for my size 14s and legs. No issues and Canada let me in and out, twice. Just had to remember the 40 on the sign was not the 40 on the CRV numbers. Luckily I didn't get caught Back to trucking things this week I hope.
08-12-2018, 10:31 PM | #66 |
Re: Palf's 1981 GMC
Nice pics!
08-13-2018, 06:57 PM | #67 |
Re: Palf's 1981 GMC
You where only 2 hrs away from me in the Canada land.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
09-04-2018, 03:55 PM | #68 |
Re: Palf's 1981 GMC
Saturday the Jimmy and I made trip to Baton Rouge again. It wasn't too bad, The weather stayed mostly dry on the way there. Luckily on the way back it did not rain at all because the truck died on me at a rest stop. It acted like battery went dead and wouldn't jump. After a few tries with jumps and all, a young kid came by and offered to give me a jump. Even though it had failed several times already, we tried again. Same thing. When The kid was pulling off the jumpers, he noticed something I had missed.
Yep, The ground cable had vibrated loose and came disconnected from the block. Thank the Lord for the extra eyes to see what I overlooked. Bolted it up and on the way again. Just about an hour in hot sweaty (but no rain luckily) weather. Once I got home, I undid the bolt with booger-ed threads and replaced it with one that is good. Some lock-tight and double nutted it to the bracket. Let's see it come off now (I hope it doen't take that as a challenge) Yesterday and today while waiting for our Tropical storm, I did some electrical. I had a HD Relay/Headlight harness in the stash from the days of my 70. So I worked it into the 81's stsyem and now the cruddy/corroded factory headlight sockets are gone. Things look like the work very well now. My front park-lights/turn signals were also very cracked, faded and crumbling, so I put on some new ones. They are aftermarket customs. They look way better than what I had. Hopefully they will hold up a good while before they fade on out. When I was digging in the stash for the headlight harness, I also noticed my air horns, so since the one remaining original horn barely bleeped, I hooked up the new horns. Way better. You will now hear me! Glad I dug thru and found all this old stuff (some of it is10-12 years since I bought it..
09-30-2018, 10:16 PM | #69 |
Re: Palf's 1981 GMC
The truck and I have been mostly playing the last several days. Officially today was the start of our 8 day event called Cruising the Coast. Had a few small meets and shows leading up to it also
Here are links to some of the photos I took. Cruising the Coast 2018 C10 Mississippi Meet It's a random mixture. Most are trucks (some not Chevys). The 2 showing are my truck and another guy from the club I am in. Blue 81's both of them, mine does NOT have the topper. Time to go rest up for day 2.
10-01-2018, 09:27 PM | #70 |
Re: Palf's 1981 GMC
A couple from today's gathering I thought were worth showing.
First one is one you don't see to often, square step with the fender spare, I LOVE it. 2nd : Square crewcab with step bed 3rd: Love the graphics on this one.
10-14-2018, 08:31 PM | #71 |
Re: Palf's 1981 GMC
Had a great time at Cruisin' the Coast. Put on about 600 miles during the week. Only issues I had was the power steering belt broke. Soon as I found one, it was back going again. I was surprised how cool the engine radiator and all were, especially since we were in the mid 90's and high humidity all week. Truck is a blast to drive. I did an autocross in it and needless to say, 6 popper, 250 CID, T350, 2.73 rear gear and 31x10.50 tires do not make a good combination. I stunk as far as I was concerned. Not sure what a good time was but I was at 87.1 secs. I believe old guys in walkers were faster.
I have been acquiring parts for it. Besides a better and working gauge cluster, I picked these up this week. Offenhauser 4bbl manifold and a Holley economaster 450 cfm (L-7455) carb. Carb was free from a friend, so after a rebuild if I don't like it I'll probably get an Edelbrock 500CFM. Still have a few more things to gther up before I do the head swap and upgrades, but I am getting there. Pretty much till November I will not do anything but drive it. Got one mre big event I want to have it together for in 2 weeks,
10-14-2018, 08:51 PM | #72 |
Re: Palf's 1981 GMC
Very cool on the Offy intake!
10-15-2018, 06:55 PM | #73 |
Re: Palf's 1981 GMC
Nice score on the parts
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
10-27-2018, 09:28 PM | #74 |
Re: Palf's 1981 GMC
Great day. 3 hr cruise over to LA to meet up with a bunch of truck heads. Truck ran great. 1st time the wife was able to attend an event with me. She enjoyed the drive and day also.
Picture of me with the GMC, the other 2 were a great view to see starting the day. Pictures I took today.
10-28-2018, 04:36 PM | #75 |
Re: Palf's 1981 GMC
Looks like a great day with nice trucks! Thank you for sharing.
