07-03-2018, 08:40 PM | #51 | |
Re: Help a NOOB - A continuing saga
I managed to get a timing light on it and wish I read your hint first. My eyes were bugging trying to read my last pen mark from two years ago. But it appeared 14-15. I shut it down, and removed the vac lead and plugged it. I think I read maybe 10 (I willl mark it better tomorrow). Then I noticed it was idling high, close to 1200. I dropped it down to close to 800 ( it didn't really sound like it wanted to run lower). And I think the timing read about 9ish advance. I'm using one of those dig. advance ones, so only using the zero marks. Regarding the carb, I definitely don't trust myself, and I think if its wrong maybe I should try to have them compensate me somehow. It was JUST rebuilt to the tune of $300+. Another thing I saw while it was running was fuel puddling at top of accelerator pump. Just can't be right. Oh and I actually thought about adding an inline filter when I got the carb rebuilt, but got completely sidetracked with everything else that went wrong. I don't have one, just the one at the carb. With mechanical fuel pump is it typical to do it ahead of the fuel pump down below? |
07-03-2018, 08:41 PM | #52 | |
07-03-2018, 08:44 PM | #53 | |
07-03-2018, 08:47 PM | #54 |
Thank you all! I knew I'd find great wisdom here. Like looking at a picture and seeing a distributor out of place. Invaluable knowledge and experience here! I hope to keep learning.
07-03-2018, 09:38 PM | #55 |
Moderator
The fuel puddling in the accelerator pump is a sure sign of a carb that has excess fuel float height and is flooding...
Mark the balancer and tab, set it to 12 degrees, vac port blocked for advance unit... Even if it idles at 1000 in neutral, that will come down to 800 when in Drive... When you get timing set, throw a vacuum gauge on a full manifold port source...not the timed source for the dist vacuum...and tell us what the vac reading is... I would try and get some money back from that shop...that carb "overhaul" simply is not correct... I always add an inline fuel filter between fuel pump and carb...reduces chances of dirt entering new carb. I would seriously look at an Edelbrock Performer 600 carb with electric choke...you would need a adapter plate...or perhaps a reman Quadrajet from a local auto parts store... Stay cool mate Aussie..aussie...aussie... |
07-03-2018, 10:19 PM | #56 | |
07-03-2018, 10:57 PM | #57 |
Bingo! Highlander (available only on Custom Deluxe models, and it's a highlander if it has one of the 4 offered plaid seat covers) - and a paint/trim combo I've never, ever seen before... Orange w/Avocado plaid. Nice! Thanks for posting.
07-03-2018, 11:53 PM | #58 |
Who Changed This?
I wouldn't worry too much yet about where the #1 plug wire is on the distributor cap. That's a refinement "back to stock" that can wait for the moment, if you've gotten the thing to run better. People stab the distributor wrong all the time, myself included, and just move the wires accordingly until it runs. The difference is that I would go back and make it right to stock. AussieinNC has it exactly right, your carburetor is flooding. Fuel spilling out the accelerator pump rod hole is a classic symptom of that. IMO, first order of business is to take the carburetor back to the shop. If you can remove it yourself without voiding the "warranty" I'd recommend that. Flooding that much fuel into the engine can badly dilute the oil. In fact, I'd recommend checking your oil level, and sniffing the dipstick (away from the engine) for gasoline fumes.
MEANWHILE, is there someone on this board who can steer this poor fella to a reputable shop in his area!?
07-04-2018, 12:30 AM | #59 |
The best shop out there you can find is in yourself. You have already proved your abilities.
Quote: A few hours later, however, was a different story. I had fashioned a clip out of a beer can and connected the choke back up to the linkage. I had also checked the oil, and added a little. I think that's all I did, and the darn thing was difficult to start. And I had to feather it or keep some throttle to keep it running. I can't think what could be so different from when it ran fairly well a few hours earlier. The complete tech specs are listed here in the technical section. Everything else is on the internet. Read here: Crankshaft Coalition: https://www.crankshaftcoalition.com/...Coalition_Wiki The internet is a tool that will serve you well, so people chose to ignore it. Me personally find I save big time bucks by doing my own work. Most of the people here are more than willing to lend a helping hand, just ask and ye will receive. My truck is nearing 50 and a rust bucket, yet it runs like a rapped ape. People still **** when I hit it in traffic. |
07-04-2018, 11:23 AM | #60 | |
For the manifold vacuum. Is this port ok to use? The one that was unplugged when I got it back. (Yes I did plug it, they had a plug on the port that they should have connected the choke vac to, so I put it on this port when I connected that choke can) It's about 20inches at this port Last edited by ncpetersc; 07-04-2018 at 11:32 AM. Reason: Added reading |
07-04-2018, 11:34 AM | #61 |
Here's a pic, it rose to about 20 after I took it and stayed there.
07-04-2018, 12:43 PM | #62 |
You have great vacuum, the engine is in good shape.
Check out that Crankshaft Coalition Page there is an entire write up on Hei dist. and vacuum advance. I picked up an adjustable vac adv can and it allows me to dial it to the engine and conditions I drive. |
07-04-2018, 01:02 PM | #63 | |
Any recommendations for next steps? I'm thinking maybe I can try to tune the carb idle. Maybe use the adjust for max vacuum then adjust idle iterative method? |
07-04-2018, 01:26 PM | #64 |
Did you know that your mechanical advance in the distributor starts to come in near 800 rpm. At 950 rpm yours likely is. That means your 12 initial isn’t likely accurate. Could be closer to 5 degrees.
You need to get the idle down near 700 rpm. Have you fixed the flooding carb yet? Any tuning you do is meaningless until you do. |
07-04-2018, 01:51 PM | #65 | |
Here is a highly recommended source specializing in Q-Jets. They can also tune the carb to your application. FREE QUOTE: https://cliffshighperformance.com/request-a-quote BTW: Nice Truck! Sounds like you're on the right track to get the issues resolved. If you can get your money back from the place that rebuilt it, you may have most of the money needed for Cliff's to get it right! Good luck & Happy Independence Day to all!
1968 C10 LWB Fleet-Wood, 2-WD, 327, 4-Bbl, Auto, 12-Bolt, Bone Stock. >POOF!< Sold 9/8/2018. New owner is local to Waynesboro PA and will take excellent care of her. He also owns a 69 Z28 SS Option car. 1998 Camaro SS, LS1, A4, 3.42. Free Tune - Stock 13.08 @ 106.55 >Lightening Strikes Again!< Sold 9/9/2018 she too will be well cared for as 1 of 45 produced in blue, with Auto and no T-roof. Last edited by Mikes68C10; 07-04-2018 at 02:04 PM. |
07-04-2018, 01:52 PM | #66 | |
I will lower the RPM and double check the timing. Thanks! |
07-04-2018, 02:02 PM | #67 |
Your motor seems to be in good shape from what we can tell over the internet. A new carburetor and a HEI distributor should fix most of your problems.
07-04-2018, 02:41 PM | #68 |
Moderator
Good to see you are making progress..now that it will at least run and sort of idle...getting the carb right is next step....
You need to either...get the shop to refund you for the junky job they did on the carb...or...put it down to experience and grab another carb, either an exchange rebuilt one from an auto parts store or maybe google guaranteedcarburetors. They have rebuilt Quadrajets for $198 inc shipping... "not a plug...just a simple parts assist admins" One critical thing you should add is an inline fuel filter between the pump and the carb... Once you have the carb right, set your idle to about 700, block off the vac advance and set timing to 12...BTDC...reconnect the vac line and set your idle to 700...in Drive....MAKE SURE SOMEONE IS IN THE DRIVERS SEAT WITH THEIR FOOT ON THE BRAKE while you set the idle in drive. Good point made earlier about fuel dilution by gas flooding the carb...once you get the carb right, and before you drive it on the road...change your oil and filter... You are doing great...there are a lot of us on here more than willing to help... |
07-04-2018, 02:44 PM | #69 |
Moderator
I see a couple of guys are recommending you buy a new HEI dist...suggest you put that on back burner for a little while, as there are a couple of "tricks" you need to do when installing a new HEI dist in a points based truck.
HEI is a good idea for later on, but lets get it running carb wise first... |
07-04-2018, 03:56 PM | #70 |
Love the truck. You'll get the issues sorted out soon enough and will enjoy driving the old girl around.
Maybe it is just my eyes, is there not a bolt securing the passenger rearside of the carburator down? Maybe the carb is not securely attatched to the intake manifold? Looking at the photo from post 60. |
07-04-2018, 04:26 PM | #71 | |
1968 C10 LWB Fleet-Wood, 2-WD, 327, 4-Bbl, Auto, 12-Bolt, Bone Stock. >POOF!< Sold 9/8/2018. New owner is local to Waynesboro PA and will take excellent care of her. He also owns a 69 Z28 SS Option car. 1998 Camaro SS, LS1, A4, 3.42. Free Tune - Stock 13.08 @ 106.55 >Lightening Strikes Again!< Sold 9/9/2018 she too will be well cared for as 1 of 45 produced in blue, with Auto and no T-roof. |
07-04-2018, 04:29 PM | #72 |
Where's my beer?
On CorvetteForum.com there's a guy Lars out in Colorado who rebuilds Quadrajet carbs and does an incredible job. I think he has a couple of week turn around on his jobs. His email is V8fastcars@msn.com. He also is practically a genius a tuning an engine and getting them to run great, and is very willing to share his knowledge. Shoot him an email describing your problems, and maybe discuss a carb rebuild with him. Do some research on him, and you'll find nothing but praise for his work.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
07-04-2018, 04:54 PM | #73 |
All about them K’s
Yep she’s a highlander! Avacodo plaid trim! Nice looking truck!
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
07-04-2018, 06:34 PM | #74 | |
Thanks again! It's way better than it was. Still taking steps backwards it seems, but I'll post the latest in another post. Regarding the oil, I checked and level seems ok, but I do think the dipstick smelled like fuel. I'll try to remember to refer back to this when I get the carb taken care of. I gotta figure out how to proceed there. The concensus seems to be that it is just wrong. Thanks to all for tips on where to potentially get a rebuild or a new one. Fuel filter: It's a hard line going into the carb. Recommendation on where exactly to add one? Thanks again, and happy 4th! |
07-04-2018, 06:42 PM | #75 | |
My vacuum gauge was still connected and when it made the hissing/sucking sound it bounced around 15. If I put my hands over the carb it settled back to 20 and the rpm went up. I suppose this may just be another sign that the carb is messed up? At the lower rpm I did readjust the timing. It looks like my advance kicks in around 950 or so. So it was close. But I put it at 12 at around 700 rpm, so hopefully accurate now. |
