Old 03-25-2019, 05:07 PM   #51
lowbrow454
Active Member
lowbrow454's Avatar
Re: Blazer Chalet #0661
Originally Posted by notsolo View Post
Nice project, looking good....Ripped is not what you want to see when looking at that door, maybe some updated waterproof building materials...Aztec pvc comes in 4'x 8' sheets, 3/8" ...1/2"...as well as 3/4" boards etc ....just a thought...Very cool shop with some interesting displays.....
Thank you! I had thought about using some different material but haven't looked into Aztec I'll have to check it out. My mom and step-dad are really into antiques and hit-and-miss engines. The shop is loaded with all kinds of fun stuff.
Originally Posted by Ryan_S View Post
Just read the tread tip to tail. Great looking build! I'll be following along from here on out. I'll be interested to see what you come up with for the trailer. Will it be painted to match?
Thanks! The trailer is a ways off but can't help planning that out too. It will be painted to match but I'll most likely do it myself rather than have a bodyshop do it. Want to try and incorporate some squarebody into it to go along with. Thought about step side tail lights, blinker lights, and trim. Things like that. Originally was going to use a short bed and make it into a trailer but determined this to be little too big and bulky for our use.
'75 C10 SWB 454
'75 K10 SWB "The Gilded Turd"
'77 K5 Blazer Chalet #0661 Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=776072
'79 K10 Bonanza
lowbrow454 is offline   Reply With Quote
Old 03-25-2019, 11:21 PM   #52
Zoomad75
K5Camper
Zoomad75's Avatar
LED lighting is the way to go. Much brighter output at a quarter of the current draw and no heat. I changed my overhead lights out with some RV style units and I could have them both on full brightness and they barely pull a half an amp.
Amazon has a ton of choices to look over for full replacement fixtures, but if you want to maintain an original look you should be able to buy LED replacement bulbs to retrofit with.
I know K5Nutt who is restoring his Chalet Camper spent a large chunk of coin having a new door custom built to his spec by some RV firm and installed by a Boat repair facility for their expertise in fiberglass repair. But it looks like yours could be repaired.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 03-27-2019, 01:11 AM   #53
lowbrow454
Active Member
lowbrow454's Avatar
I talked with him a little about his. From the pics his looks real nice. The door can probably be rebuilt but the latch might be a loss. The problem is the trim around the camper door frame is cracked and pretty messed up. Camper shop hasn't had any luck finding some, that style seems to be discontinued. We'll see what they come up with for options.
'75 C10 SWB 454
'79 K10 Bonanza
Old 03-27-2019, 01:41 AM   #54
lowbrow454
Active Member
lowbrow454's Avatar
Most the the interior is stripped out except for the cupboards. Pulled the carpet out to reveal the rotted floors. Honestly surprised it wasn't worse. Kinda funny when you walk on the floor with the carpet on you don't think about the floor. After the carpet is pulled you think you're gonna fall through any sec.
'75 C10 SWB 454
'79 K10 Bonanza
Old 03-28-2019, 10:31 PM   #55
Zoomad75
K5Camper
Zoomad75's Avatar
Yikes! Makes me glad mine don't have a floor! How does the plywood attach? Does the fiberglass shell go all the way around to the bottom? Never seen one torn down that far.
Rob Z.
Old 03-29-2019, 03:16 AM   #56
lowbrow454
Active Member
lowbrow454's Avatar
The fiberglass goes all the way to the bottom and there is a seem where the ends meet. Not sure if it attaches with adhesive or just sit there. I'll find out more after the cabinets are removed. The camper bolts down in the bed through the bolt holes that are for the the seats.
Looking into replacing it with a composite material. Plywood with poly would probable be fine but the composite stuff is resistant to fungus, mold and absorption. Plus it's about 45% lighter than plywood. May not add up ton of weight difference but I''ll take what I can get with this turd.
'75 C10 SWB 454
'79 K10 Bonanza
Old 03-29-2019, 12:51 PM   #57
77blazerchalet
former Chalet owner
77blazerchalet's Avatar
Interesting. Always wondered what was under the carpet in these. I've seen photos of guys' gutted shells, but never a camper unit disassembly process like yours. Never got that far with my former Chalet #1747. It had better-than-average original carpet, but that back step-down area seemed too 'bendy' for my preferences. Dead, rotted plywood, no doubt. Chinook used really lousy quality wood. Be sure to show what you find inside your rear door. I had an RV shop fix mine (outer fiberglass skin had turned way too fuzzy), but they threw away the wood before I could see it.
Over at the Yahoo Chalet forum, I have a photo collection of my fixes of the cabinets. I took apart the passenger side one inside the interior, but reinstalled it as a complete unit, as seen in the pic below.
Name:  Closet re-inforcement.jpg
Former owner of Chalet #1747. Current caretaker of the very old BlazerChalet.com website.
77blazerchalet is offline   Reply With Quote
Old 03-31-2019, 11:37 AM   #58
82Diesel
Following along the progress! Super neat!
1979 Pontiac LeMans 231/Th350
1982 Chevrolet Silverado K10 6.2 Diesel/700r4
1984 Buick Regal Limited Sedan 4.3 V6 Diesel/200r4 (Hens teeth rare)
1991 Chevrolet Silverado K2500 5.7/700r4
1999 Chevrolet Base LS K2500 6.5TD/4L80e
82Diesel is offline   Reply With Quote
Old 04-01-2019, 11:55 PM   #59
lowbrow454
Active Member
lowbrow454's Avatar
Thanks!
'75 C10 SWB 454
'79 K10 Bonanza
Old 04-11-2019, 06:23 AM   #60
lowbrow454
Active Member
lowbrow454's Avatar
So after the camper was mostly stripped down it was time to put it on the worlds second smallest trailer and take it in for fiberglass work. When taking it to storage it was shimmed on the rails and strapped down. The storage was only a few miles away and on back roads so this wasn't a big deal but the camper shop is 30 miles away so this wasn't gonna fly.
We lifted up the camper and put 2x6's across the rails of the trailer and lined them up with the body mount holes. Then drilled holes through the 2x6's and the rails and bolted them together. Then drilled holes through the 2x6's where the camper bolted through the Blazer floor and another board on the top side since the fiberglass was cracking and not very stable. Bolted that together and was surprisingly very sturdy. Threw a couple straps on for good measure and it was off to paint.
You can see on the bottom side of the camper what the color is supposed to be.
'75 C10 SWB 454
'79 K10 Bonanza
Old 04-15-2019, 03:20 PM   #61
LT7A
Good work on carefully attaching the camper for transit. It's easy to get in a hurry on those kinds of things.
Old 05-01-2019, 09:45 AM   #62
82Diesel
Looks like it coming along!!
Old 05-08-2019, 10:58 PM   #63
lowbrow454
Active Member
lowbrow454's Avatar
Thanks!
'75 C10 SWB 454
'79 K10 Bonanza
Old 05-08-2019, 11:06 PM   #64
lowbrow454
Active Member
lowbrow454's Avatar
Been super swamped lately but found a moment to throw up some pics from the camper shop. Body work underway.
'75 C10 SWB 454
'79 K10 Bonanza
Old 05-09-2019, 03:12 PM   #65
68Timber
I know the pieces fit
68Timber's Avatar
This will be fun. I've never seen one of the campers restored.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 05-09-2019, 06:36 PM   #66
82Diesel
Wow, Great work on the camper! I wouldn't doubt once she's all done easily doubled in Collectors Value!
Old 05-12-2019, 08:02 AM   #67
lowbrow454
Active Member
lowbrow454's Avatar
Thanks!
'75 C10 SWB 454
'79 K10 Bonanza
Old 06-02-2019, 03:13 AM   #68
lowbrow454
Active Member
lowbrow454's Avatar
Roof was pretty trashed too. New wood glassed in.
'75 C10 SWB 454
'79 K10 Bonanza
Old 06-03-2019, 04:37 PM   #69
77blazerchalet
former Chalet owner
I never got around to peeking under the roof liner in my former Chalet #1747 or poking at it. Was there a complete plywood sheet covering that underside framework? Like practically all other Chalets & Casa Grandes I've seen in various ads, the vinyl sidewall material in mine was shrinking away from the corners, pulling the staples out of what looked like really lousy plywood. Wish I had gotten photos when the RV place rebuilt my back door, everyone else who's rebuilt their doors said the wood frame inside the fiberglass skins was total junk.
Old 06-04-2019, 01:12 AM   #70
lowbrow454
Active Member
lowbrow454's Avatar
No plywood sheet on the top, just a strip that runs the boarder where the canvas staples to about an inch wide and the cross bracing. Hopefully it'll hold up a little better being fiberglassed in.
My door is definitely in bad shape too. Wood is rotted and the honeycomb insulation is all but gone. Can't believe that's all they used.
'75 C10 SWB 454
'79 K10 Bonanza
Old 06-04-2019, 01:49 AM   #71
lowbrow454
Active Member
lowbrow454's Avatar
Headliner moving right along. Pics are from the camper shop so they're a little blurry.
'75 C10 SWB 454
'79 K10 Bonanza
Old 07-06-2019, 01:03 AM   #72
lowbrow454
Active Member
lowbrow454's Avatar
Camper is back from paint. Can't wait to get it back on. Top was in pretty bad shape, lots of stress cracks. Tinted bed liner was used to help fill in and seal the top.
'75 C10 SWB 454
'79 K10 Bonanza
Old 09-11-2019, 07:17 AM   #73
lowbrow454
Active Member
lowbrow454's Avatar
Not much progress, waiting on the Blazer to get out of paint jail. Should be out soon. Hopefully be in paint next week. Few pics from the body shop.
'75 C10 SWB 454
'79 K10 Bonanza
Old 02-11-2020, 10:13 AM   #74
lowbrow454
Active Member
lowbrow454's Avatar
Finally got some more work in. Starting to tear out the rest of the camper. As everyone else said who has been through these, they are very cheaply made and flimsy. Wanting to keep the original layout and make it look factory but will need lots of bracing and better materials.
'75 C10 SWB 454
'79 K10 Bonanza
Old 12-31-2023, 10:25 PM   #75
72shorbox
Old thread, wondering what happened. Why did the posts just stop?
72shorbox is offline   Reply With Quote
